Old 05-10-2005, 08:55 PM   #5101
POOKYT's Avatar
Originally posted by Mdoc
pooky....I saw all the things bigdog was sayin on the other thread.....yer not gonna just take that are ya...
BigDog is a Wussie!!! Anybody can drive an X-Ray when he gets set-ups from Team Drivers. I'm a gonna spank his azz this Sat. at the Big M Motorfest race and take his trophies!! OH YEA!!!
Brant
EA Motorsports--B-Main Motorsports--Blizzard Concepts--Loose Nuts Racing--BigDog Graphics
My Carbon Footprint is Larger than Yours! :p
POOKYT is offline   Reply With Quote
Old 05-10-2005, 09:00 PM   #5102
RBLove's Avatar
Trader Rating: 72 (100%+)
Originally posted by W.E.D.Jim
Todd, have you tried any set ups without the chassis braces in back? I'm wondering if that might be the way to go on some of the rougher outdoor tracks, none, or only two, etc.?.......I'm wondering after seeing some of the TC4 guys cutting thier chassis braces trying to get thier cars to work here? Since my car has been so good, it might get better?...........Jim
W.E.D. Jim,
If you're running outside with rubber tires it might help ya out. The initial design did not have the rear braces, but after some more intense carpet/foam tire racing they incorporated them into the kit. It's only four screws. I would definitely try it. If anything just so you know what it does. I would expect to see a little more rear traction....
RC America, Xray, Hudy, R1 Wurks, EA Motorsports, ProLevel RC, Ulti Tires America, PROTOform
RBLove is offline   Reply With Quote
Old 05-11-2005, 08:32 AM   #5103
1fastdude's Avatar
Trader Rating: 15 (100%+)
Anyone tried the center one-way? Thoughts???????
★RCAmerica •Xray •Hudy •BSR •Absolute Hobbyz •Gravity RC •PROTOform •Avid •TQ Racing Wire •C & M Motorsports ★
1fastdude is online now   Reply With Quote
Old 05-11-2005, 11:18 AM   #5104
Intelligentsia's Avatar
Does anybody know if the Fusion Battery Bars will fit and have enough clearance?
Intelligentsia is offline   Reply With Quote
Old 05-11-2005, 01:05 PM   #5105
patman22's Avatar
The fusion bars clear mine great. As good or better than some of my other packs.
patman22 is offline   Reply With Quote
Old 05-11-2005, 02:03 PM   #5106
Sweet! Thanks a lot!
Old 05-11-2005, 02:37 PM   #5107
CRASH's Avatar
Trader Rating: 26 (100%+)
Sway Bar Question
The directions for the sway bar kit does not give any info as to how long the tie-rod assembly should be.
Is there a specific length or just thread them together completly leaving no gap between the ball-cups?
Thanks,
CRASH is offline   Reply With Quote
Old 05-11-2005, 02:42 PM   #5108
CRASH's Avatar
Default Diff vs Spool vs One-Way
For a medium to high bite asphalt track with rubber tires Mod which one would be better.
1: Diff
2: Spool
3: One-Way
Last week I ran the car with dual diffs and the center one-way. It was extremely good just needed a little bit more turn in on and off power.
Which one is going to help the most?
Thanks,
Old 05-11-2005, 02:52 PM   #5109
Default Re: Sway Bar Question
Thanks,
Make them even. If your lucky they will even out when pointed in the right orientation, but the trick is to get small tie-rods like the ones on the car so they can be adjusted.
Tony Vega is offline   Reply With Quote
Old 05-11-2005, 03:00 PM   #5110
Greg Sharpe's Avatar
I tried the center one-way with the front diff and also with a spool. Adding the center one-way gave a little more steering both on and off power, but eliminated the brakes all together.
Why don't we endurance race more often?
Greg Sharpe is offline   Reply With Quote
Old 05-11-2005, 03:47 PM   #5111
J.Filipow's Avatar
Thanks,
Adjust your linkage so that the sway bar comes off the swaybar mount/shock tower as close to a right angle as possible...you want that sway bar to be pretty much parallel with the chassis once the linkage is installed. Use a pair of calipers to be sure both left and right linkages are the same length, as are the front and rear linkages.
In addition, you can do yourself a favor by 'threading' set screw hole on the swaybar ball end all the way through BEFORE you install them onto the swaybars. This is definitely make installation of the smaller (0.030 for example) swaybars much easier (and less prone to tweaking/crimping/bending that small guage wire, too).
P1 Brand - "Victory is Black and White" ◢◤◢◤◢◤◢◤◢◤◢◤◢◤◢◤◢◤◢◤
RC America / XRayUSA / Hudy / Motiv / Avid / Vannen Watches
J.Filipow is offline   Reply With Quote
Old 05-11-2005, 07:00 PM   #5112
STARSCREAM's Avatar
just built my new losi ride for the Reedy race....here is my 2 cents on building tips....
it is critical that you tap the spots where the locating pins go....or youll probably be buying a new 050 driver...
also...make sure you file the rear battery slot on the chassis so that the cell is "slammed" perfectly in the chassis....if you get this rite your packs will fit perfect....and be sure to check out Todds tips on the Losi web site...
late
Sean Maybell
Team Associated/Reedy/LRP
STARSCREAM is offline   Reply With Quote
Old 05-11-2005, 08:19 PM   #5113
POOKYT's Avatar
After you guys run the Reedy race I wanna see a bunch of set-up info please! The best my G+ ever handled was after last years Reedy and I used the Cavaliere set-up from there on out. You guys go and kick sum butt for us all!
Brant
Old 05-11-2005, 08:48 PM   #5114
JRM
Default Ditto.
Brant
I'll be there hanging out and taking photos .
Looking forward to a solid Losi performance! Good luck to everyone.
JRM is offline   Reply With Quote
Old 05-11-2005, 09:46 PM   #5115
Antonio Sabato's Avatar
Default Re: Ditto.
Yeah, the new Losi car has been on a tear lately at all the big races. With the dominant performance at the birds and LRP race they are sure to be an unstoppable force. I don’t think the car is only good on carpet but it will be hooked up on asphalt like you won’t even believe!
Antonio Sabato is offline   Reply With Quote
Team Losi JRXS Fast XXXS Australia For Sale/Trade 6 11-19-2007 03:34 PM
F-S Team losi JRXS as new mcskoda Australia For Sale/Trade 6 10-31-2006 02:15 AM
FS:Team Losi JRXS BiggAlz R/C Items: For Sale/Trade 21 03-25-2006 05:47 PM
Team Losi JRXS FS JRXSBear R/C Items: For Sale/Trade 9 01-19-2006 03:57 PM
Team Losi JRXS Jon Carlson R/C Items: For Sale/Trade 3 01-18-2006 08:28 PM
