Old 05-10-2005, 07:12 AM   #5086
Geoff,
I might just take the age prize at 63.
Just completed building my JRXS. Thanks to this thread I was able to address a lot of issues, however I also still have the rear toe problem. Will be trying replacement hubs to see if this cures the problem, and hopefully Todd wil have some answers soon.
Just a note on another problem i noticed during building, the front "C" blocks were off one was 4* whil;e the other appeared to be 2*. Replaced the 2 with a 4 (after dremmiling inside) I had from my XXX S and all is fine.
Also by cutting some of the meet off the front of the servo mounts and using an Ofna S/S I am able to go up to 40 pinion with 128 spur.
Need to purchase new speed control and paint body before I get to drive. Will be using old faithful XXX S till then.
Nuff said!
John T
J Tronzano is offline   Reply With Quote
Old 05-10-2005, 07:39 AM   #5087
63! thats not fair! all those extra birthday and Xmas presents
Geoff
losiboys is offline   Reply With Quote
Old 05-10-2005, 07:56 AM   #5088
Still Bill's Avatar
Makes me the bridesmaid!
Bill
Constantly evolving CRC WGT and WGT-R/T...Carpet & Asphalt...All thanks to Team CRC.
And a pair of Associated B6 buggies for turf and clay tracks.
Still Bill is offline   Reply With Quote
Old 05-10-2005, 08:23 AM   #5089
Antonio Sabato's Avatar
Originally posted by 403forbidden
yeah you are so right!
I wish I would have thought of using that joke first just as much as I wish I was using a 2400 baud modem hahahaha!
Now thatís a classic!
Antonio Sabato is offline   Reply With Quote
Old 05-10-2005, 08:32 AM   #5090
Trips's Avatar
Trader Rating: 16 (100%+)
Geoff,
Yeah right, if you're 63 then I'm 45. Oh wait... I AM 45...
David F
MARSHAL!!
Trips is offline   Reply With Quote
Old 05-10-2005, 10:53 AM   #5091
Now that we have established the age pecking order, does anybody have an answer to this one;
The JRXS instructions state that the new front cd's were specifically designed for running a spool in front, but we should use them for all drive set-ups.
My question, if the new cd's were specifically designed for use with a spool, would it matter if you run regular cvd's when not runnig a spool ie. diff infront ?
Old 05-10-2005, 11:48 AM   #5092
Mike Haynes's Avatar
As far as i know and have tried, you could go right ahead and run a normal cvd, but this will be a little bit smoother in and out of the corners.
Team Associated - Reedy Power - Sweep - Protoform - TQ Wire - Lacher paint
Mike Haynes is offline   Reply With Quote
Old 05-10-2005, 12:04 PM   #5093
EricF's Avatar
The LCD's imo should be used all the time, as they take out all wheel wobble at lock. Which I think will give the car a more consistant, smoother steering feel (not that I'd notice w/ my limited skillz).
Also, anyone know what is ment by setting droop 4mm above ride height. I don't get it
Thanks,
E
EricF is offline   Reply With Quote
Old 05-10-2005, 12:07 PM   #5094
Greg Sharpe's Avatar
Trader Rating: 15 (100%+)
The wording of the manual is a bit sketchy regarding the usage of the LCVD, but the jist is .....
The LCVD allows much steeper angles between the axle stub and axle shaft, which shows the greatest benefit when running a spool, but will be smoothest when running any style diff, in comparison to a standard 1-pin CVD.
Why don't we endurance race more often?
Greg Sharpe is offline   Reply With Quote
Old 05-10-2005, 12:43 PM   #5095
Thanks,
E
To set droop this is used. Il try my best to explain it.
instead of taking off the wheels and using a gauge on the arm, you leave the wheels on the car. Do your rideheigh like normal to say 5mm. Then with the car race ready tighten or loosen the droop screws enough to make the chasis able to go to 9mm off the ground before the tire lifts from the ground.
Old 05-10-2005, 01:02 PM   #5096
STAN STICKLER's Avatar
Originally posted by POOKYT
At what locations on the chassis are you guys using to measure for ride height? Talk to a brutha!!!
Brant
Tech Director
B-Main Motorsports
I usually check mine at the track,OH! Thats not what you meant by location?Try using the bottom of the chassis,thats a start!
http://www.rchobbiesraceway.com/
http://myspace.com/STANLEYSTICKLER
STAN STICKLER is offline   Reply With Quote
Old 05-10-2005, 01:16 PM   #5097
EricF's Avatar
Cool... Thanks for the answer.
E
Old 05-10-2005, 01:26 PM   #5098
karlo511's Avatar
Brant
Tech Director
B-Main Motorsports
right behind the front arms and in front of the rears
karlo511 is offline   Reply With Quote
Old 05-10-2005, 07:54 PM   #5099
POOKYT's Avatar
Thanks Karlo!! I have been running 5.5 of ride heigth measuring from those locations but it just felt like little or no down travel when I was pushing it down on the bench. Just being cautious!
Brant
EA Motorsports--B-Main Motorsports--Blizzard Concepts--Loose Nuts Racing--BigDog Graphics
My Carbon Footprint is Larger than Yours! :p
POOKYT is offline   Reply With Quote
Old 05-10-2005, 07:59 PM   #5100
Trader Rating: 29 (100%+)
pooky....I saw all the things bigdog was sayin on the other thread.....yer not gonna just take that are ya...
Mdoc is offline   Reply With Quote
Team Losi JRXS Fast XXXS Australia For Sale/Trade 6 11-19-2007 03:34 PM
F-S Team losi JRXS as new mcskoda Australia For Sale/Trade 6 10-31-2006 02:15 AM
FS:Team Losi JRXS BiggAlz R/C Items: For Sale/Trade 21 03-25-2006 05:47 PM
Team Losi JRXS FS JRXSBear R/C Items: For Sale/Trade 9 01-19-2006 03:57 PM
Team Losi JRXS Jon Carlson R/C Items: For Sale/Trade 3 01-18-2006 08:28 PM
