Old 05-06-2005, 05:39 AM   #4936
Send a message via ICQ to copter Send a message via Yahoo to copter
JRX-S kits have arrived into Finland (Europe) too. Shipment arrived on Wednesday to our importer and I just picked up my kit couple hours ago from local cargo terminal. Due yesterdays national holiday shipping from another city took 2 days instead of normal 1 day. You can guess that yesterday was quite painful waiting for me while knowing that kit would already be here without this holiday.
RC Sabe has kits and good amount of parts in stock and will ship anywhere in Finland. Maybe into other Scandinavian countries too if needed.
RC Sabe
Ruissalontie 12 / Saippuacenter
20200 Turku
FINLAND
Tel. +358-2-2473222
Open MON-FRI: 10.30-17.30, SAT: 10.30-13.30 (EET)
Email: [email protected]
WWW: http://www.sabe.fi/hobby/
copter is offline   Reply With Quote
Old 05-06-2005, 06:32 AM   #4937
Trips's Avatar
Trader Rating: 16 (100%+)
Todd and/or Ray...
As far as I can tell, the inner hinge pin mounts aren't twisting when I tighten them.. with the locating pins, they really only want to go in one position.
Ray, when you mentioned holding the arm while tightening the screws for the mount, I am assuming you meant that you're hoilding the arm as if you're trying to sweep it forawrd as you tighten the screws (the right rear arm, for the left I'd hold it as if I was trying to sweep it rearward)
If you meant something else, could you please clarify for me?
This rear toe issue is kinda messing up my head at the moment... sorry if I seem to be harping on it, I just want to have the car as "right" as I can get it.
I picked up a set of 1/2 degree rear hubs at the shop, they're XXX-S hubs, can anyone confirm if they fit the JRXS before I open the bag?
Also while I am at it, can anyone confirm that the back of the chassis can be used as a reference to set rear toe, for example, if I stand the car up vertically on the rear of the chassis can I measure rear toe with a camber gauge, or is the rear edge of the chassis not truly perpendicular to the centerline of the car?
Thanks in advance
MARSHAL!!
Trips is offline   Reply With Quote
Old 05-06-2005, 06:37 AM   #4938
Trips's Avatar
Another question...
In looking at the setup sheet in the manual, the shock tower positions "high" and "low" appear. From what I can see, the shock towers on my car only go on one way... How would I change the tower position? Does this require different bulkheads or towers?
Thanks again.
MARSHAL!!
Old 05-06-2005, 06:44 AM   #4939
1fastdude's Avatar
Trader Rating: 15 (100%+)
I can only reply on the hubs and yes XXX works on it. I put them on this week.
★RCAmerica •Xray •Hudy •BSR •Absolute Hobbyz •Gravity RC •PROTOform •Avid •TQ Racing Wire •C & M Motorsports ★
1fastdude is offline   Reply With Quote
Old 05-06-2005, 07:41 AM   #4940
Originally posted by Trips
Another question...
Thanks again.
You will only mount the tower with 1 screw on each side instead of two for the "high" position.
Tony Vega is offline   Reply With Quote
Old 05-06-2005, 07:54 AM   #4941
Trips's Avatar
Thanks Tony...
Not that I'm looking to sound dumb here, but I guess I need to ask then, is the stock position shown in the manual the "low" position, or would mounting the tower down lower with one screw on each side be considered the "low" position...
MARSHAL!!
Old 05-06-2005, 08:01 AM   #4942
1fastdude's Avatar
The low position has 4 screws. You can not mount it any lower than that.
Old 05-06-2005, 08:09 AM   #4943
Trips's Avatar
Thanks, I don't have the car in front of me here or I probably wouldn't have asked that one...
MARSHAL!!
Old 05-06-2005, 08:14 AM   #4944
Tim Johnson's Avatar
_______________________________________________________
Support your Local Hobby Shop, because you can't race on Ebay!
Airtronics|Kyosho|
Tim Johnson is offline   Reply With Quote
Old 05-06-2005, 08:37 AM   #4945
Hi Guys
Any one found a rearly good stock(27t) setup for rubber tires(cs22) on carpet yet, come on Nathan! tell us what your doing
Geoff
losiboys is offline   Reply With Quote
Old 05-06-2005, 10:45 AM   #4946
I will ask Nathan for you, which car - Andy
Andyg01 is offline   Reply With Quote
Old 05-06-2005, 11:00 AM   #4947
deeerrrr JRXS, but I think he was using the prototype at Carpet wars, Andy T now has it.
Old 05-06-2005, 04:32 PM   #4948
Juan Valdez's Avatar
Post
For all you foam tire racers, here's a rollout chart I made up quick today. Its an MS Excel file. Assumes 128 tooth spur and stock 1.83:1 internal ratio. After I finished I realized I could have made it a little more flexible (able to change spur and IR). Maybe I'll do it some other time. Have fun racing this weekend!
TLR 22 3.0 | TLR 22-4 | TLR 8ight-E 3.0 | Tamiya TA07 | Tamiya TA05 | Exotek F1R3
Juan Valdez is offline   Reply With Quote
Old 05-06-2005, 05:13 PM   #4949
Intelligentsia's Avatar
What are some of the option parts currently available that you guys recommend?
I can't find any part numbers for anything. I am really interested in additional spring rates. If you have any part numbers for things, please let us know.
Intelligentsia is offline   Reply With Quote
Old 05-06-2005, 07:12 PM   #4950
YAHOO!!!'s Avatar
anyone recomend or try running a front spool with foam on carpet? Maybe a spool with the 41 tooth pulley?
YAHOO!!! is offline   Reply With Quote
Team Losi JRXS Fast XXXS Australia For Sale/Trade 6 11-19-2007 03:34 PM
F-S Team losi JRXS as new mcskoda Australia For Sale/Trade 6 10-31-2006 02:15 AM
FS:Team Losi JRXS BiggAlz R/C Items: For Sale/Trade 21 03-25-2006 05:47 PM
Team Losi JRXS FS JRXSBear R/C Items: For Sale/Trade 9 01-19-2006 03:57 PM
Team Losi JRXS Jon Carlson R/C Items: For Sale/Trade 3 01-18-2006 08:28 PM
