Old 05-04-2005, 06:20 PM   #4891
losixxxs's Avatar
Originally posted by losixxxs
still need help out with this
i am using dean battery bars and i got them angled with corally conectors on there and they are hitting the top of the chassis how can i solve this?????
and has anybody had issuse witht he front shocks hittint the diff
thanks
later
losixxxs is offline   Reply With Quote
Old 05-04-2005, 06:30 PM   #4892
BillyCaldwell's Avatar
Trader Rating: 32 (100%+)
Send a message via AIM to BillyCaldwell
I have not ran my car yet, but you it appears you will have to vary the spacing behind the shocks depending on your wheelbase.
As for the battery situation, I havent put one in my car yet, gotta get some plugs.
Maclin | VP-Pro USA
BillyCaldwell is offline   Reply With Quote
Old 05-04-2005, 08:40 PM   #4893
TLRacing
Todd Hodge's Avatar
Originally posted by cartmen34
Well, I finally caved. After months of loving the Pro 4 I'm going to try something new. I picked up a JRX-S at the LHS today...
One question though... what is everybody's opinion of the included body? Compared to other popular bodies? Good for carpet? asphalt? both? I've been running the Protoform Mazda6 and Nemesis bodies....
[Edit]:
Nevermind.. I see POOKYT already answered the question just a few posts ago.... duh! sorry!
[/Edit]
I think you will find that the Skoda 2 has more steering than the Mazda 6.
Todd Hodge
Category Development Manager for Losi and Team Losi Racing
Losi and Team Losi Racing, brands of Horizon Hobby
Team Losi Racing, Orion, Nitrotane, Spektrum, Imagine It Graphics, Bradley Fine Line Designs, and Lunsford.
Todd Hodge is offline   Reply With Quote
Old 05-04-2005, 10:44 PM   #4894
Regional Moderator
Darkseid's Avatar
Originally posted by CRASH
Yeah I followed the manual as well and had nothing but problems. Switched to the JR servo arm and problem solved.
Later,
Man, I don't see how you got that thing on! I tried and tried but couldn't get anything other than the 25 anywhere near to going on.
I'm using a servo saver now, so its not an issue, but before that, my 25 slipped and I couldn't get the others to fit.
TLR 22...Tamiya F104...
Old 05-05-2005, 02:42 AM   #4895
Shev's Avatar
A couple of questions...
1. Will a normal 48 pitch spur fit on the car? I've only seen 64 pitch on the websites.
2. Is the spur different to ordinary spurs?
I'm keen to get one of these after my xxx-s, not happy with the pro 4 at the moment. Go the Losi power!
Cheers
Shev is offline   Reply With Quote
Old 05-05-2005, 07:02 AM   #4896
DavidAlford's Avatar
Trader Rating: 31 (100%+)
Send a message via AIM to DavidAlford
PRS has a gear adapter that lets you run aftermarket spurs. As it is now you have to use Losi spurs and I believe they are only making 64pitch at this time.
Hot Bodies/HPI | Jconcepts | Viper RC | Xpert | Sippel Speed Shop | Lawton RC Raceway | SXT
DavidAlford is offline   Reply With Quote
Old 05-05-2005, 07:52 AM   #4897
CRASH's Avatar
Trader Rating: 26 (100%+)
When trying to run the rear camber link as short as possible A hole in the rear hub carrier and the #6 hole in the shock tower do you have to shorten the ball cups to get this to work?
Just checking before I cut the ball cups shorter.
Thanks,
CRASH is offline   Reply With Quote
Old 05-05-2005, 07:55 AM   #4898
Still Bill's Avatar
Crash,
"I'm not speeding........I'm qualifying!"
I have a t-shirt that says exactly that.
Constantly evolving CRC WGT and WGT-R/T...Carpet & Asphalt...All thanks to Team CRC.
And a pair of Associated B6 buggies for turf and clay tracks.
Still Bill is offline   Reply With Quote
Old 05-05-2005, 07:59 AM   #4899
karlo511's Avatar
Thanks,
i ran into the same issue.
karlo511 is offline   Reply With Quote
Old 05-05-2005, 08:06 AM   #4900
mudpuppy's Avatar
Has anyone heard when the new battery tray to fit the 3700 cells is going to be available?
mudpuppy is offline   Reply With Quote
Old 05-05-2005, 08:34 AM   #4901
TLRacing
Todd Hodge's Avatar
Cheers
1. The car takes its own spur gears. However PRS is making a spur gear adapter to accept universal spurs like PRS and Kimbrough.
Todd Hodge
Old 05-05-2005, 08:36 AM   #4902
TLRacing
Todd Hodge's Avatar
Thanks,
Yes you have to trim about 1/8" off of each ball cup.
Todd Hodge
Old 05-05-2005, 08:37 AM   #4903
TLRacing
Todd Hodge's Avatar
It should be ready by the end of May.
Todd Hodge
Old 05-05-2005, 08:53 AM   #4904
Timmy_G's Avatar
Send a message via MSN to Timmy_G
My JRX-S arrived today. First one in Australia as far as I'm aware.
Started putting it together tonight, goes together far better than the old XXX-S G+ did. Am very pleased so far with the only problem being not lining up the holes to slot the small shaft through for the spur gear.
Some superb features, belt / diff height adjustment really caught my eye straight away.
Doesn't look asif I'll be braking my outdrives in a big hurry either, beefy as!!!
Just wondering though, who's broken what at this stage? Are the front arm's a weak point? The rest of the car looks very strong and am wondering if this is going to potentially be a minor downfall.
Tim
Losi, JR Propo ,Spektrum, Novarossi, AT Racing Fuels
Timmy_G is offline   Reply With Quote
Old 05-05-2005, 09:07 AM   #4905
Trips's Avatar
Trader Rating: 16 (100%+)
A page or so back I posted about uneven rear toe-in on my JRXS...
Todd suggested that I check that the inner hinge pin mounts were straight, as far as I can tell they are.
rayhuang suggested holding the arm tightly as I tighten the screws for the hinge pin mounts, I tried this, but saw no change.
I reverted to an old trick I used with the XXX-S, where I reamed the outer hinge pin hole in the hub at an angle so that the setscrew when tightened will hold the hub at the correct angle.
Now my rear toe looks even...
I guess what I'm asking now is what is the best method to get even rear toe... Should I ream the hubs or just use different hubs on each side? I have no issue with either method, I just want to know what the "right" way is to get even rear toe.
I'd even be willing at this point to fedex the car to Losi, maybe I'm just doing something wrong and someone there can let me know... the fact that no one else has mentioned this makes me think that it almost has to be something I'm doing...
Please don't take this as a complaint about the car... I'm very happy with the build so far and I'm really looking forward to its first time out... hopefully this weekend.
Thanks in advance... David
MARSHAL!!
Trips is offline   Reply With Quote
Team Losi JRXS Fast XXXS Australia For Sale/Trade 6 11-19-2007 03:34 PM
F-S Team losi JRXS as new mcskoda Australia For Sale/Trade 6 10-31-2006 02:15 AM
FS:Team Losi JRXS BiggAlz R/C Items: For Sale/Trade 21 03-25-2006 05:47 PM
Team Losi JRXS FS JRXSBear R/C Items: For Sale/Trade 9 01-19-2006 03:57 PM
Team Losi JRXS Jon Carlson R/C Items: For Sale/Trade 3 01-18-2006 08:28 PM
