Team Losi JRXS
Old 10-01-2004, 07:42 AM
  #466
spenzalii's Avatar
Default Gotta hand it to Losi...
Last year they broadsided everybody releasing the Mini-T. So this Christmas, when everyone is building a better Mini (and that Associated one looks nice), they come back with a hella innovative design just in time for indoor electric season. With all the Mini-T's they sold, they should be able to produce the c/f version with little or no problem. Bravo, and I want one...
Although I will admit I'd miss the single belt drive.
spenzalii is offline
Old 10-01-2004, 09:37 AM
  #467
SRS
SRS's Avatar
the chassis will stay cf.
SRS is offline
Old 10-01-2004, 10:19 AM
  #468
Tech Legend
Cain's Avatar
Trader Rating: 252 (100%+)
I like the look of the vehicle so far, I wonder how much better this will be than say the Ofna OB4 Mid motor design other than the better weight balance of the batteries being down the center of the car ( the ofna had saddle packs ). Anyone had driving experiences with the ofna? may give insights on how this will perform.
Cain is offline
Old 10-01-2004, 12:16 PM
  #469
seaball's Avatar
shaniqua
seaball is offline
Old 10-01-2004, 04:45 PM
  #470
Wow. That must be a real early XXX-S prototype. The motors in the back, offset more towards the outside of the car, spur gear on opposite side of belt.....anyways. I'll miss my XXXSG+ too.
Anymore JRXS sightings out there in Cali., MD, U.K.?? LOL
dasupacat is offline
Old 10-01-2004, 05:18 PM
  #471
I hope the new car retains the same motor mounting system, the XXX-S allows you to easily get your gear mesh spot on
v0rtex is offline
Old 10-01-2004, 05:57 PM
  #472
mwcet8k's Avatar
Iím in the opposing camp. I definitely prefer the standard mounting method to that of the xxx-s. The xxx-s uses the rotating cam because of the fully enclosed drive train. Otherwise, Iím sure it would use standard motor mounting/adjustment.
mwcet8k is offline
Old 10-01-2004, 06:13 PM
  #473
I'm not a big fan of the adjustment cam on the XXX-S. It makes it difficult to fit a larger pinion when racing stock class. The bigger the pinion the more the motor would raise itself because of the rotating cam. Bringing the center of gravity up. It also was not very effective at pulling heat away from the motor. The new JRXS looks like it will keep the motor very low and cool. The motor adjustment is horizontal and attached to the aluminum mid. chassis brace. Which will keep it much cooler and lower no matter what pinion you use. I'd rather take the extra minute to adjust the pinion/spur mesh and keep the weight of the motor xtra low.
Old 10-01-2004, 08:56 PM
  #474
tc3stocker's Avatar
I think this car is cool, but won't be getting one for a while
tc3stocker is offline
Old 10-01-2004, 10:21 PM
  #475
POOKYT's Avatar
MAN! How late is that library open? Go to bed and get up tomorrow and rake leaves or something and get some money to buy a car. SHEESH!
Brant
POOKYT is offline
Old 10-01-2004, 10:26 PM
  #476
tc3stocker's Avatar
I am at my dad;s house, and I am staying up a while
I am saving money, got 100 saved and only 1350 to go
Old 10-01-2004, 10:39 PM
  #477
POOKYT's Avatar
You Go Boy!
POOKYT is offline
Old 10-02-2004, 12:47 AM
  #478
robk's Avatar
Trader Rating: 22 (100%+)
"I like the look of the vehicle so far, I wonder how much better this will be than say the Ofna OB4 Mid motor design other than the better weight balance of the batteries being down the center of the car ( the ofna had saddle packs )."
The fact that it will be a stick pack vs. a saddle will be a lot better. The OB4/Streetweapon/RCLab/Schum. Axis type layout concentrates too much wieght at the rear of the car.
robk is offline
Old 10-02-2004, 06:51 AM
  #479
Hmmmm......I think I see the possiblity of a 1/10th gas car layout. Steering servo, .12 engine, fuel tank behind motor, & reciever pack at the end of tank near rear diff. Throttle servo on gear side and reciever pack on opposite side. will have to have a custom pipe similar to the NTC3.
Can you see a .12 engine head sticking out the hood/windsheid? Ultimate cooling.....
Old 10-02-2004, 07:40 AM
  #480
mashimaro's Avatar
With the exception of two belt not one belt and the motor up the back as oppose to the middle/front, this car reminds me of the kyosho kx-one. similar idea but executed differently, in fact jrxs is almost like merging kx-one and pro3 together. haha, just me thoughts
mashimaro is offline
