Old 04-29-2005, 04:11 PM   #4666
TL_XXX-S_racer's Avatar
Send a message via AIM to TL_XXX-S_racer
Todd,
Quick question about sealing the edges. On the Losi sight is says use Super thin CA glue. Could I use epoxy instead. Cause if you use super glue or CA glue wont it chip off once something hits it? By sealing the edges can you please remind me what this will prevent.
ProMatchRacing
"Nobody does it better"
Team Corally
Superior Hobbies
"Supplying all your r/c racing needs"
TL_XXX-S_racer is offline   Reply With Quote
Old 04-29-2005, 04:33 PM   #4667
losixxxs's Avatar
i a building my kit and on side of my steering rack is binding on me and the other side is moving freely how can i fix this ??
travis
losixxxs is offline   Reply With Quote
Old 04-29-2005, 04:43 PM   #4668
J.Filipow's Avatar
Trader Rating: 15 (100%+)
TL_XXX_s_Racer- First of all, get with it! Change your username to TL_JRXS_Racer!!! LOL...use CA glue as recommended on the Losi site, after, of course, you sand the edges with some 400 or 600 grit paper. Sealing the edges can prevent the carbon fiber from delaminating. If the CA seal DOES chip or flake away on a spot, it is really easy and quick to touch it up with another drop of CA. Good luck!
losixxxs- refer to above regarding usernames!!! Kidding, of course! Check your ball cups, to be sure they are not binding on your ball studs. Also check the molded linkage on the servo horn/arm to be sure that is free as well.
P1 Brand - "Victory is Black and White" ◢◤◢◤◢◤◢◤◢◤◢◤◢◤◢◤◢◤◢◤
RC America / XRayUSA / Hudy / Motiv / Avid / Vannen Watches
J.Filipow is offline   Reply With Quote
Old 04-29-2005, 04:57 PM   #4669
Ya thats what im gonna change it to. So no one change it to that. lol. Ok thanks. Another thing thats on my mind. It says also on the losi sight that you need to grind away some of the chassis for the diffs if you run them in the low posistion. I thought if we were going to spend 345 some odd bucks on the car dont u think we shouldnt make those adjustments to get a setup change to work. If they spent all that delay time and they didnt see that problem. They should of fixed that so all of us who dont have a dremel dont have to fix anything. Just my two cents.
Thanks anyways.
ProMatchRacing
Team Corally
Superior Hobbies
Old 04-29-2005, 05:00 PM   #4670
wannabee's Avatar
travis
Travis,
Check and make sure you don't have P/N A1543 (bellcrank side) on upside down. This will cause the binding your talking about...
Also make sure not to use too much thread lock, this will seep out and stick the works up!!
KE
wannabee is offline   Reply With Quote
Old 04-29-2005, 06:05 PM   #4671
Core Creations's Avatar
Trader Rating: 95 (100%+)
Send a message via AIM to Core Creations
So, how exactly is everyone addressing the NO servo saver issue?? I'm not real hot on the idea of breaking steering pieces or the servo itself!
Core Creations paint thread
Mini Mafia Kansas Chapter - where the monster minis grow!
Core Creations is offline   Reply With Quote
Old 04-29-2005, 07:01 PM   #4672
tony montana's Avatar
Trader Rating: 66 (100%+)
Fella's I need some advise, Im running gp3300 and Im having problems getting them in the car. When ever the battery bars hit the carbon fiber the bars start sparking acting like Im hitting metal. And also the battery bar for my positve terminal for my hard wiring is hitting the rear diff. Im also wondering about the servo saver thing, I dont wont to screw up my airtronics 947358
K.C. Guy- TLR- Horrizon Hobby- Team Trinity- 92 zero designs- AKA
tony montana is offline   Reply With Quote
Old 04-29-2005, 07:15 PM   #4673
RBLove's Avatar
Trader Rating: 72 (100%+)
Try a Kimbrough saver. Quite a few of the guys are using them. The medium and large sized savers fit.... I am not sure of the spring tension between the medium and large. If the large saver's spring is no stiffer go with the medium saver and vice versa....
RC America, Xray, Hudy, R1 Wurks, EA Motorsports, ProLevel RC, Ulti Tires America, PROTOform
RBLove is offline   Reply With Quote
Old 04-29-2005, 07:16 PM   #4674
RBLove's Avatar
Can you post a pic? Try removing the soldering tabs and take a look at the clearance you have. This will help you better figure out how to wire the batteries in. You can also take a look at Todd Hodge's section on www.teamlosi.com. He has a nice sample wiring pic.....
Old 04-29-2005, 07:18 PM   #4675
I have not been able to a Kimbrough to fit...the nut for the ball end hits the motor.
Old 04-29-2005, 07:25 PM   #4676
RBLove's Avatar
That will definitely be an issue with large saver when running stock and 19 turn...............
Personally I have not tried any servo saver's thus far. I have not had any issues.
Old 04-29-2005, 07:28 PM   #4677
howard hudson's Avatar
R/C Tech Charter Subscriber
Default Re: Re: Re: Re: Re: Re: Todd
Originally posted by T. Hodge
He will not come out....he is too scared to race. He says he has yard work to do that day
What a girlie man !!!
what the heck is r/c car??? ( said in your best redneck voice)
'OL BUZZARD FARMING (lol)
howard hudson is offline   Reply With Quote
Old 04-29-2005, 08:54 PM   #4678
rayhuang's Avatar
Boy-dremeling the chassis for belt clearnace is a must. My rear belt after only 12 or so batteries has really shaven my rear belts outer carcass. There was belt material in the slot. So of course i yanked the diff and did the work. Of course the drivetrain spins a little freer now too.
Old 04-29-2005, 08:58 PM   #4679
Tim Johnson's Avatar
Yoiu need to use the kimbrough small servo saver. If yoiu have futaba it is #114. That saver will fit nicely in the jrXs
#113 Servo Gear Savers____ KO, Airt. 23 Spline Drive _$ 4.00 ea
#114 Servo Gear Savers____ Futaba 25 Spline Drive __$ 4.00 ea
#131 Servo Gear Savers____ Hitec 24 Spline Drive ____$ 4.00 ea
_______________________________________________________
Support your Local Hobby Shop, because you can't race on Ebay!
Airtronics|Kyosho|
Tim Johnson is offline   Reply With Quote
Old 04-29-2005, 09:08 PM   #4680
RBLove's Avatar
Originally posted by Nathan Parker
To Fit the 3700`s
All I have done is removed the lip from the front of the tray.
Then filed down from the back of the screw holes at a 45deg angle to let the front cell sit further forward.
BINGO. Nice post Nathan. I think the 45 deg angle is key to anyone having issues with their cells appearing to be too large.
Team Losi JRXS Fast XXXS Australia For Sale/Trade 6 11-19-2007 03:34 PM
F-S Team losi JRXS as new mcskoda Australia For Sale/Trade 6 10-31-2006 02:15 AM
FS:Team Losi JRXS BiggAlz R/C Items: For Sale/Trade 21 03-25-2006 05:47 PM
Team Losi JRXS FS JRXSBear R/C Items: For Sale/Trade 9 01-19-2006 03:57 PM
Team Losi JRXS Jon Carlson R/C Items: For Sale/Trade 3 01-18-2006 08:28 PM
