Old 04-28-2005, 01:43 PM   #4576
Regional Moderator
Darkseid's Avatar
Originally posted by Tony Szep
nevermind i fixed it but i do have another problem... im running a ps-2113fet from KO and when i try to put the linkage on it hits the case of the servo im not sure why this is doing this.
There was a problem with this and some models of servo. The fix that was given by the team guys a while back was that you'll just have to lightly file a little off that portion of your servo.
I run a KO 2173 and I had to take off a VERY little at only one point,to keep mine from rubbing. And that was just at one little point. Also, since KO uses servo ears that are kinda rounded, you might want to check by your front belt and make sure that it isn't rubbing the servo ear at the mounting point.
TLR 22...Tamiya F104...
Old 04-28-2005, 01:44 PM   #4577
Administrator
Matt M.'s Avatar
Trader Rating: 26 (100%+)
Originally posted by rayhuang
matt-the rear hubs your usiing I bet arent off set hubs so they go in the outer holes on the arm. Now-Dont scream at me if you do have the offset hubs.
ray, you win the prize, i called todd, and while we were talking it hit me.....what a fool......i guess building a car, everynight on 4 hours sleep is a bad idea.......
thanks
matt
Matt M. is offline   Reply With Quote
Old 04-28-2005, 01:59 PM   #4578
wannabee's Avatar
0* inboard will get you 0* of toe, add the 2* hubs with the 0* inboard and you'll have a total of 2* out on the arm...
I'm also being told that offset hubs will yield more steering...
wannabee is offline   Reply With Quote
Old 04-28-2005, 02:04 PM   #4579
i just recived my RNR bumper that was very fast thank you
Tony Szep is offline   Reply With Quote
Old 04-28-2005, 02:06 PM   #4580
wannabee's Avatar
Your very welcome, thank you! Good luck with the new car!
KE
Old 04-28-2005, 02:06 PM   #4581
I had to take off alot of matiral and its still rubbing alittle
Old 04-28-2005, 02:08 PM   #4582
Greg Sharpe's Avatar
Trader Rating: 15 (100%+)
Default Re: Re: I got a chance to look at the new Losi shocks....
These were probably my favorite part of the build. Heck, how often do you say that?
Truely amazing units Losi came up with.
CRASH! (Greg passes out from sheer amazment)
Originally posted by OSherman
Will there be a spool released soon for the JRXS?.. Is there any way to lock the front diff?
Speedworld informed me the front spool option will consist of diff ring pads. They're "like sandpaper" and replace the diff rings and balls. I tried a ghetto version of these the other day, definitely locked the front wheels together, but provided WAY too much on-power steering. I found the stock front differential has enough on power steering for me.
Why don't we endurance race more often?
Greg Sharpe is offline   Reply With Quote
Old 04-28-2005, 02:21 PM   #4583
now its fixed and im not even gona say how much plastic i took off
Old 04-28-2005, 03:11 PM   #4584
Regional Moderator
Darkseid's Avatar
I feel you. I didn't even want to take that little bit off mine. But look at it like this, some cars require the removal of part or all of a servo ear(s), so doing some 'grooming' on your servo is just something we have to deal with in some kits.
Unfortunate, but sometimes neccesary...
Old 04-28-2005, 03:18 PM   #4585
hey a little plastic wont hurt anything it will just make the car lighter
Old 04-28-2005, 03:19 PM   #4586
Regional Moderator
Darkseid's Avatar
Now thats the power of positive thinking!
Old 04-28-2005, 03:21 PM   #4587
I just cant wait to run this thing!!!!
Old 04-28-2005, 03:23 PM   #4588
OSherman's Avatar
Default Re: Re: Re: I got a chance to look at the new Losi shocks....
Originally posted by Greg Sharpe
......Speedworld informed me the front spool option will consist of diff ring pads. They're "like sandpaper" and replace the diff rings and balls. I tried a ghetto version of these the other day, definitely locked the front wheels together, but provided WAY too much on-power steering. I found the stock front differential has enough on power steering for me.
Yeah.. I know of the LOSI pads (actually my first trip to SpeedWorld is when/where i first heard of and bought some). Tried them in a YOK at the time.. They worked, but didn't last for too long (for me).. they started to slip after a while..
•KO Propo America
•EXOTEK
OSherman is offline   Reply With Quote
Old 04-28-2005, 04:25 PM   #4589
TLRacing
Todd Hodge's Avatar
Todd-does putting toe in via the pivot blocks have more side bite and less rotation than putting the same toe in at the hubs, but zero innner hingepin toe in?
Its the other way around. Toe-in in the pivot will give you less steering since it will not want to transfer as much weight over the front.
Todd Hodge
Category Development Manager for Losi and Team Losi Racing
Losi and Team Losi Racing, brands of Horizon Hobby
Team Losi Racing, Orion, Nitrotane, Spektrum, Imagine It Graphics, Bradley Fine Line Designs, and Lunsford.
Todd Hodge is offline   Reply With Quote
Old 04-28-2005, 04:26 PM   #4590
RBLove's Avatar
Trader Rating: 72 (100%+)
Definitely. Off set hubs will provide more steering. The pivot point is changed slightly with the off set...... I highly recommend running the off set, but those of you that like Cadillac's run the standard (Hodge). LOL..... Standard will make the car a little smoother and less aggressive.
RC America, Xray, Hudy, R1 Wurks, EA Motorsports, ProLevel RC, Ulti Tires America, PROTOform
RBLove is offline   Reply With Quote
Team Losi JRXS Fast XXXS Australia For Sale/Trade 6 11-19-2007 03:34 PM
F-S Team losi JRXS as new mcskoda Australia For Sale/Trade 6 10-31-2006 02:15 AM
FS:Team Losi JRXS BiggAlz R/C Items: For Sale/Trade 21 03-25-2006 05:47 PM
Team Losi JRXS FS JRXSBear R/C Items: For Sale/Trade 9 01-19-2006 03:57 PM
Team Losi JRXS Jon Carlson R/C Items: For Sale/Trade 3 01-18-2006 08:28 PM
