Team Losi JRXS
#4366
Originally posted by James Nguyen
My car has been apart twice already and I haven't even ran it yet.
#4367
#4368
Originally posted by JRX-S Bill
Well, practice DOES make perfect...
#4369
Originally posted by Gearhead3
....LOL yeah I have done somethings to the car to keep improving.....Right now i am tring to think of a way to get the bearing on the motor plate side to sit flush so that i can put the second c clip on the opposite side.
#4370
yeah that i did.........The problem is the bearing on the Motor plate side does not sit flush.....I even heated the plate to allow it to drop in, but no luck....I pulled the bearing to make sure there was not something down in the hole, but it is all clean.....I would hate to drill it, and go to far.......LOL.....But for now i will leave it, finish the rest of the car, and ether purchase a new motor plate, or call losi.....LOL.
#4371
Not that it really matters; but, I just figured out how to install the Front Spool Drive Hub as opposed to the One-Way unit.
Was wondering about the reason for those six holes in the spur gear...Duh!
#4372
#4373
Did anybody elses kit come with spool pads? Mine does not. I want to run a front spool so unless you guys tell me different I will build it with sandpaper I have used in my G+. Let a butha know whaz up!
Brant
Brant
#4374
wow you sand the c clip and e clip.......OMG, and i thought i was nuts for sanding the center shaft with 2000 grip paper.....LOL......Well thanks for your info pooky...hmmmm.....
#4375
Guess it will make it a terrific "gravity car" without it...
#4376
That was the "problem" part. Wonder if what's wrong with yours was the actually issue. I just heard "mismachined". James may know.
#4377
Anybody on the spool ? ???
Brant
#4378
Brant
Brant
Still don't see any spool parts listed in the JRX-S Parts List. Seems like the pads is the only way to go.
#4379
Understood that the car would come with diff rings that would be dimpled on one side to hold the balls (acting as a spool) and the smooth on the opposite side for standard diff action. Maybe that got axed.
Brant
#4380
Well funny part is without the C clip but with the shim, everything fits perfect, no slop or anything, (without the c clip) Im kinda thinkin it does not need it.................
