Old 04-24-2005, 09:16 PM   #4351
Darkseid- what happens when you want to run 3300's?
Tony Szep is offline   Reply With Quote
Old 04-24-2005, 09:18 PM   #4352
Has any one put the white natural ballcups on the car yet?
Old 04-24-2005, 09:21 PM   #4353
Regional Moderator
Darkseid's Avatar
Dude, check out my previous post, the 3300s still fit PERFECTLY in my car. You can also go back and take a look at the full pic of my car I posted a while back. That full pic is with 3300s installed.
Don't believe me, ask a couple of guys from the Kansas thread who saw me run today.
Like I said before, I am not just some idiot who took a hacksaw to his kit. You think you know a better way, pick up a pack of 3700 and get to measuring. I'll be waiting for your results...
Darkseid.
TLR 22...Tamiya F104...
Old 04-24-2005, 10:12 PM   #4354
Still Bill's Avatar
Default Re: Cool.
Originally posted by JRM
Looks great Bill. Nice job on the chassis prep. Any tips on techniques? I have 400 and 600 grit wet/dry paper and plan on using Zap pacer super thin CA + kicker.
Used strips of medium emery paper to round the edges. Used 1" wide strips on the straighter edges and 1/2" wide strips on the more curved sections (45 minutes). Per Todd H, I then set the chassis plate on its edge and started with a drop of Losi CA at an upper corner corner and let it follow the edge. When the CA would stop moving downward along the edge, I would apply another drop about 1/2" above the spot it had progressed to. Just kept doing that until I had made a complete rotation of the chassis plate (15 minutes). Then I hung it to dry for another 30 minutes. It looked so good, I didn't bother sanding it.
Did do a bit of touchup sanding some of the interior holes too. Didn't like how sharp they were.
How much material did you have to remove on the rear battery slot?
Initially, I removed enough material with a small flat file to make a single battery cell almost flush with the bottom of the chassis. After assembly, I had to go back and dremel away more material to make the last cell flush with the bottom of the chassis. That 's what it took to eliminate any issues for fittin my 3300/3600 battery packs.
Constantly evolving CRC WGT and WGT-R/T...Carpet & Asphalt...All thanks to Team CRC.
And a pair of Associated B6 buggies for turf and clay tracks.
Still Bill is offline   Reply With Quote
Old 04-24-2005, 10:21 PM   #4355
Tim Johnson's Avatar
SO how did we all place in this weekends racing with the JRXS?
_______________________________________________________
Support your Local Hobby Shop, because you can't race on Ebay!
Airtronics|Kyosho|
Tim Johnson is offline   Reply With Quote
Old 04-24-2005, 10:27 PM   #4356
Still Bill's Avatar
Originally posted by tony montana
And a question, what do those set screws with the little spot with no treads on the end of them do? And how far should they be screwed in. What happend with the jrxs instrutions. I dont think they are as good as the usual losi instructions
Go to Step C-04 and look at those "Locating Pins" going into the Pivot Blocks (inner and outer). Don't just screw them in...First you need to tap the related holes with the special 4-40 screw that you should have found early in the assembly process.
Hope this helps.
Old 04-24-2005, 10:37 PM   #4357
Still Bill's Avatar
I kept building and finished the sucker in the late morning. Too late to go to Modesto for the NorCal Touring Car Challenge.
During testing on the smooth asphalt in front of my house, it was excellent with a stock Monster motor on rubber using most of the setup (and one-way drive hub) provided by following the JRX-S instructions...Car transitions REALLY WELL. Can't wait for next weekend.
Old 04-24-2005, 10:41 PM   #4358
Still Bill's Avatar
Default Re: Re: Re: Heres a look for the doubters...
Originally posted by Darkseid
People are like "oh my god, how could you do that to a new car.....eeeeeeekkkkkkkkk<insert horror movie scream there>. But what they forget is that this is the beauty of these "kits". Every part can be replaced individually. So after a pair of rear bulkheads and this magic tray, I'll be right back at box stock JRX-S kit standard.
And you could then split up those two 3700 6-packs and make three 4-packs for 12th scale. That's where I have used a 3700 pack.
Old 04-24-2005, 10:43 PM   #4359
Hey bill didyou have a problem getting the second c clip on for the center shaft? the side without the spur.
Airtronics|Kyosho|
Old 04-24-2005, 11:00 PM   #4360
Still Bill's Avatar
Absolutely...You have to follow the numbered sequence (#1-9) of putting that puppy together. That took some time to figure out.
Old 04-24-2005, 11:12 PM   #4361
FWR
Qualified 3rd and finished 6th in stock. The 6th place was stupid mistakes because the handling of the car made me overconfident. Without the mistakes I would have been 2nd. I usually struggle to stay out of the B.
The only other JRX-S at the track finished 1st in stock and 2nd in open mod. Incredible, considering the car was still in the box Saturday 4:00 pm and missed the first qualifier because he was still bolting in the motor.
This logon is no longer being monitored.
FWR is offline   Reply With Quote
Old 04-24-2005, 11:17 PM   #4362
Still Bill's Avatar
Here are other things I did wrong:
#1) Step C-05 says "Caution! Ensure the dogbone is inserted into the narrow slot in the Outdrive...". TWO OF MINE WEREN'T.
The back and forth slop at the wheel is enormous when you put the dogbone pins into the wide slot in the outdrive. Pretty easy to fix though.
#2) I bought ceramic diff and thrust balls for the new car. Didn't know that Losi was supplying the new Caged Thrust Bearing as a standard part. I like the caged unit and find that didn't need to use the ceramic thrust balls.
What Losi didn't say:
#1) Because the servo is in backwards, you have to reverse the action of the servo with your radio. Thought the multi-link steeting linkage was going to accomplish that; but, it doesn't.
#2) See page 22 for the info to adjust the Up-travel Limiters.
RTM...RTM...RTM...RTM...
Score is 2 to 2; but, the car is a winner!!!
Old 04-24-2005, 11:22 PM   #4363
You had to use your manual?
James Nguyen is offline   Reply With Quote
Old 04-24-2005, 11:24 PM   #4364
Still Bill's Avatar
Yes, I admit it...Does this mean I am forever banned from this forum?
Old 04-24-2005, 11:26 PM   #4365
My car has been apart twice already and I haven't even ran it yet.
Team Losi JRXS Fast XXXS Australia For Sale/Trade 6 11-19-2007 03:34 PM
F-S Team losi JRXS as new mcskoda Australia For Sale/Trade 6 10-31-2006 02:15 AM
FS:Team Losi JRXS BiggAlz R/C Items: For Sale/Trade 21 03-25-2006 05:47 PM
Team Losi JRXS FS JRXSBear R/C Items: For Sale/Trade 9 01-19-2006 03:57 PM
Team Losi JRXS Jon Carlson R/C Items: For Sale/Trade 3 01-18-2006 08:28 PM
