Old 04-22-2005, 07:02 PM   #4216
2-Bad's Avatar
Trader Rating: 24 (100%+)
Originally posted by POOKYT
Oh and I forgot!
I GOT MINE--I GOT MINE--I GOT MINE--I GOT MINE--I GOT MINE--I GOT MINE--I GOT MINE--I GOT MINE--I GOT MINE--I GOT MINE--I GOT MINE--I GOT MINE--I GOT MINE--I GOT MINE--I GOT MINE--I GOT MINE--I GOT MINE--I GOT MINE--I GOT MINE--I GOT MINE--I GOT.....MINE......( thud!!)
pooky passes out from shear delight and too much caffene
Brant
Head Mechanic
B-Main Motorpsorts
Gee thanks.........Still waiting......hmmm
2-Bad is offline   Reply With Quote
Old 04-22-2005, 07:28 PM   #4217
Darkside. I am having the same battery fitting issues and I am only using 3300's not the larger 3700's. I was going to try taking the shrink wrap off and see how they fit. the pack just doesn't let the battery door close all the way also I noticed the pack doesn't sit in the slots well. If anyone that has runn the car has any info it would be greatly appreciated.
Andy C is offline   Reply With Quote
Old 04-22-2005, 07:32 PM   #4218
JayBee's Avatar
Trader Rating: 31 (100%+)
Post BATTERY SLOTS...
Maybe Losi should have thought about this like YOKOMO did -JB
R C 3 G R A F I X _ F U S I O N . G R A P H I X _ S E A T T L E - R/C - R A C E R S _ E M E R A L D C I T Y R C . C O M
A E - 12R5.2 _ S M - REV8 PRO
JayBee is offline   Reply With Quote
Old 04-22-2005, 08:00 PM   #4219
CRASH's Avatar
Trader Rating: 26 (100%+)
Default Battery Mod
I am off to work, I will post some pics in the morning of my mods when I get home.
Battery sits perfect with a little room to spare. Once you also put the battery foam on the top of the upper deck it is a very nice snug fit.
Later,
CRASH is offline   Reply With Quote
Old 04-22-2005, 08:07 PM   #4220
Regional Moderator
Darkseid's Avatar
Default And the Crowd goes wild!!!
After about 4 HOURS of trimmnig, filling, dremeling and fitting, I finally got the 3700 w/shrink wrap installed.
POOKYT: I'll snap some pics, but you may not like what you see!
It took mods to the rear bulkhead(most extensive), the center aluminum bulkhead(moderate) and to the battery tray(serious mods).
Here are some early highlights to what I did to both inspire and scare the hell out of anyone who has to do these mods.
-Dremel a LOT off the rear bulkhead, while trying not to damage the accentric holder
-Dremel a little off the upper and curved portion of the mid bulkhead.
-Remove the front vertical lip from the battery tray. I basically had to cut the thing off. (It simply wont fit where its supposed to with the larger cells)
-I also cut some slots in my battery foam to keep it from pushing down too hard on the cells...
You know...."slight modifications"...
I'll try to speak more specifically when I get a chance to post some pics.
A lot of work, but...MOST IMPORTANTLY.... this finally got the damn things in there properly....AND my older 3300 still fit just fine.
If theres an easier way to pull this off, congrats to anyone who finds it...
TLR 22...Tamiya F104...
Old 04-22-2005, 08:21 PM   #4221
Tim Johnson's Avatar
hmmmm....Be interesting to see if i have the same problem.....
_______________________________________________________
Support your Local Hobby Shop, because you can't race on Ebay!
Airtronics|Kyosho|
Tim Johnson is offline   Reply With Quote
Old 04-22-2005, 08:54 PM   #4222
TCR
anyone remember the size of the bearing, for the dog bones, you know for the bk bones style
TCR is offline   Reply With Quote
Old 04-22-2005, 09:19 PM   #4223
RBLove's Avatar
Trader Rating: 72 (100%+)
Default Re: BATTERY SLOTS...
Losi is working on a battery tray to better accomodate the 3700's. For now you will have to go with the mods you guys are doing......
RC America, Xray, Hudy, R1 Wurks, EA Motorsports, ProLevel RC, Ulti Tires America, PROTOform
RBLove is offline   Reply With Quote
Old 04-22-2005, 09:22 PM   #4224
RBLove's Avatar
Originally posted by Kevin K
Dark....you can still get these gears from PRS they made them for Trinity now they sell them under their own. I hear they are also working on a spur gear adapter for the car.
But Robinson Black 64p works great as well.
PRS is also working on a spur gear adapter. Very trick and "simple" piece........ 130 is the largest you can go without hanging below the chassis....... Looks like a table saw blade sitting there~
Old 04-22-2005, 09:31 PM   #4225
RodneyB's Avatar
Has anyone tried to lay the front shocks all the way in on the tower (3rd hole). My shock springs rub on the outdrive in this position.
RodneyB is offline   Reply With Quote
Old 04-22-2005, 09:33 PM   #4226
RBLove's Avatar
Rodney B,
YES. You must space the shock out about .060 on the tower and the arm. Use more spacing on the tower and use a spacer between the arm and shock on the bottom....... Might be a little more than .060. Just make sure you do the same on top an bottom.
This HAS to be done when running the front arms in the middle or back. Moved forward "should" clear...
Old 04-22-2005, 09:39 PM   #4227
RBLove's Avatar
3/32 x 3/16
Old 04-22-2005, 10:51 PM   #4228
lazyboy's Avatar
Send a message via AIM to lazyboy
i got to hold the box of one today...to bad im out of money other wise id have one also. i think my lhs had 4 left
Random Guy
FT B4
Sponsored by Axiom Motors
Trackside hobbies
lazyboy is offline   Reply With Quote
Old 04-22-2005, 10:52 PM   #4229
Default Small Issues Need Help
Well I'm getting into BAG "C", and I've encountered a couple of problems and want to see if anyone else is or has worked thru them.
1. The center shaft has a small click when the belts are put under tension. Un-load both belts, and no click. Load either belt and the click shows up. The small spacer is in place between the bearing and pulley.
2. The LCD's: They came pre-assembled.
a. one is completely bound up and does not move freely.
b. the other is missing the piece in which the pin goes thru
inside of the joint. It's just assembled with the pin.
As far as battery fitting,,,,I just did a trial fitting and talk about TIGHT. And they are the GP3300's both newer and older. I am also having a slight issue with the DEANS battery bars being to wide. So if anyone could offer me a bit of advise.
blownawayig is offline   Reply With Quote
Old 04-22-2005, 10:58 PM   #4230
Greg Sharpe's Avatar
Trader Rating: 15 (100%+)
I find it strange that some of us are having difficulty fitting newer 3300 in the car. Mine dropped right in without modifying any of the bulkheads. I think the fitment is largely dependant on how well the rear battery slot in the chassis gets shaped. Upon installing the first battery, I mistakenly thought they didn't fit. The foam strips were so firm the battery was bending the tray. I pushed the tray back up flush with the chassis and left it over night. Now that the foam strips are dimpled, all my packs drop in without any issues.
I gotta say, the overall quality is better than I expected and better than any other touring car I've owned. Now if only I could wheel this thing with some skillz!
Why don't we endurance race more often?
Greg Sharpe is offline   Reply With Quote
Team Losi JRXS Fast XXXS Australia For Sale/Trade 6 11-19-2007 03:34 PM
F-S Team losi JRXS as new mcskoda Australia For Sale/Trade 6 10-31-2006 02:15 AM
FS:Team Losi JRXS BiggAlz R/C Items: For Sale/Trade 21 03-25-2006 05:47 PM
Team Losi JRXS FS JRXSBear R/C Items: For Sale/Trade 9 01-19-2006 03:57 PM
Team Losi JRXS Jon Carlson R/C Items: For Sale/Trade 3 01-18-2006 08:28 PM
