Tc3 Composite Drive Shaft >
Old 09-25-2004, 06:18 PM
onebeatuptc3's Avatar
Default Tc3 Composite Drive Shaft
Do they still make a composite driveshaft for the tc3 anymore? All i ever see is the aluminum ones lately, so i was wondering if the composite is still made.
onebeatuptc3 is offline
Old 09-25-2004, 06:50 PM
Sal Amato's Avatar
Trader Rating: 27 (100%+)
I don't think so ,I've seen after market ones cant remember where though
Sal Amato is offline
Old 09-25-2004, 06:54 PM
Sal Amato's Avatar
Default drive shaft
Oh yeah noW I remember SPEEDTECH http://64.70.208.72/speedtechrc/373.html
Old 09-25-2004, 07:00 PM
Composite Driveshaft? Do you mean the one you get with the RTR, Racer and Team kits? if so then yes
Andy M is offline
Old 09-25-2004, 07:07 PM
Charlie O's Avatar
I was told they were only making the aluminum shaft, i like the comosite because it is 3 grams of rotating mass less than the aluminum shaft.
Charlie O is offline
Old 09-25-2004, 07:34 PM
Why does everybody run the aluminum shafts ???? The composites are way lighter and seem to be very durable.
PhatPat is offline
Old 09-25-2004, 07:45 PM
i looked at my shaft and its even got a carbonfiber look to it. I think we should convince AE to bring them back (im asking about this because i got another tc3, but its missing the driveshaft, so i have to buy a new one) My only guess for getting rid of it was its flexibility which i guess could be a problem if your car is flexible. O well, maybe ill have to put a WTB or somethign soon.
Old 09-26-2004, 01:51 AM
lee82gx's Avatar
the carbon fiber driveshafts are no longer made.
They are much lighter and can take bending.
But the downside is that they were very expensive.
lee82gx is offline
Old 09-26-2004, 08:40 AM
TPhalen's Avatar
If you remember, the carbon driveshafts were a three piece unit....the center, hollow shaft and the two, press-fit and epoxied ends. Yes, it was light. Yes, it was very strong. Durability was good, unless you had a big crash. This would sometimes stress the drivetrain enough to break the epoxy, causing your end piece to spin inside the shaft. Car handling would be off. Would you know, maybe, maybe not, but you'd be scrambling trying to find the 'stink' in your car, not knowing its as simple as replacing the shaft. Plus, once we found that there were no problems with an aluminum shaft, we just started using those.
No plans on releasing (re-releasing) the carbon shaft....sorry guys.
TPhalen is offline
Old 09-30-2004, 11:47 AM
If small stone got stuck and touched the carbon shaft it could cut the shaft in 2 pieces in one main.
andsetinn is offline
Old 09-30-2004, 12:08 PM
Charlie O's Avatar
If it touched enough two cut the shaft into you would probably notice the car being really sluggish & feel like the brakes were on, & by the way the aluminum shafts bend quit easily, never had a problem with the carbon shafts even when i did get a rock stuck in it.
Old 09-30-2004, 12:30 PM
koabich's Avatar
Associated no longer offers this profuct. You can buy C/F drive shafts from other manufactures that fit the TC3. When I found out that Associated no longer offered this product, I went out and bought all I could find.
I bought the Aluminum unit and tested it out the last half of the race year last year and I was actually suprised at what I found. For the new, higher RPM motors (Monster/BS2), the Aluminum units were FASTER, even though they are heavier.
When I used a P2K2 or MVP the slight edge went to the C/F drive shaft. Not 100% sure but it may have to do with the fact that at higher RPM, the C/F shaft seemed to distort (or no longer rotates straight). In the middle of the C/F shaft, it seemed to bend outward, away from the center line of the chassis where the Aluminum shaft, no matter how high the RPM seemed straight.
koabich is offline
Old 10-01-2004, 04:50 AM
johnnywhopper's Avatar
my servo wire was laying against the shaft one time, and i didn't notice it untill it had worn through the shaft. definately wasn't bound, and definately alot less friction than a rock, but it wore through anyway.
johnnywhopper is offline
Old 10-01-2004, 05:08 AM
My friend just bought a racer kit and his came with a cheap looking aluminum shaft it looked like it was hollow aluminum with 2 pins sticking through each end... looked like crap to me... but my LHS still has 3 compsite shafts in...lol
Later
Jake
JakeDaSnake is offline
Old 10-01-2004, 09:33 AM
Tech Legend
Cain's Avatar
Trader Rating: 268 (100%+)
If you guys need older parts like this and are having trouble finding them, try www.greatlakeshobbies.com
There website is kind of a pain to go through, but prices are fairly reasonable and you can find older stuff there in stock.
Funny, I just sold one of those composite drive shafts and about 4 sets of NIB composite CVD bones on ebay.
Cain is offline
