Shock setting for TC3/BMI Chassis >
Old 09-25-2004, 04:20 PM
wrxdan's Avatar
Default Shock setting for TC3/BMI Chassis
I need a good starting point with this chassis. I run rubber and foam indoor carpet. What oil/piston/spring should I try first. The track is smooth with tons of grip.
Thanks!
Dan
wrxdan is offline
Old 09-25-2004, 05:10 PM
howard hudson's Avatar
Default Re: Shock setting for TC3/BMI Chassis
Thanks!
Dan
read through this thread click
howard hudson is offline
Old 09-25-2004, 05:12 PM
A good place to start is 60wt front w/#2 pistons and 50wt rear w/#2 pistons. Yellow srings front, purple springs rear. DBL Purple/Orange foams on front, purple foams on rear.
hobbyman_7 is offline
Old 09-25-2004, 06:47 PM
Trader Rating: 52 (100%+)
you can try #2 pistons with 70 wt. in front with purple springs
50wt. in rear with copper springs.
purple/orange (never heard of DBL purple/orange) fronts
and purple rears
this will be a good startign point at probably 90 percent of the carpet tracks you race at.
Mo
Mo Denton is offline
Old 09-25-2004, 09:32 PM
Chill Will's Avatar
Look in the back of the manual. It has a carpet setup thats a good starting point.
Chill Will is offline
