Like Tree2Likes
Old 03-21-2012, 12:47 AM   #106
texastc's Avatar
Originally Posted by blade072 View Post
also off topic....has anyone tried the trg tires??????
no but I hear they are good.
Exotek F1Ultra Tamiya TRF101 Speed Passion SP1 and Exotek F1UltraX Prototype.
"TexasTC, the single Greatest RCF1 racer I have ever known" - My mom
"you are a disgrace to RC" - everyone else. TCdoesRC
texastc is offline   Reply With Quote
Old 03-21-2012, 02:52 PM   #107
warnos's Avatar
Blade 72 get the softest Shimi tires u can on the rear to lock it down.. 579 or 575..
Anyone tried the 104 tires on a 109 or 103??
Cheers
TCX Smokem / F104 wgp
Major Sponsor : Visa Card
TEAM SMA - www.smaracing.org
warnos is offline   Reply With Quote
Old 04-18-2012, 12:22 PM   #108
I have read the whole f104 pro and this tire topic and I still need some info:
Gluing the pits to foam wheels: -do we glue the whole "lip" of the tire (like we do on hpi vintage tires) or just the sharp edge of the wheels?
I imagine both will work but the tire sidewall is harder if the lip is firmly glued in the rim.
witch is correct?
Just assembled my first formula(104 pro) and ordered tires for it. I would like to make it right the first time.
-Pate
fastvee is offline   Reply With Quote
Old 04-18-2012, 08:05 PM   #109
spring71's Avatar
Smile
witch is correct?
-Pate
Glue inside rip first and outside, and the other side.
TQ RC RACING
Indoor RC Race Track & Hobby Shop in Chino, CA
Online Shop
http://www.tqrcracing.com
[email protected]
spring71 is offline   Reply With Quote
Old 04-18-2012, 09:30 PM   #110
Thanks, I did see that picture b4 and that is why I asked.
On pic#3 "glue wheels edge first" I thought it ment glue that part first and then glue the whole side of the tire to the wheel after that. Then do the other side(only the edge of that side of tire)
The problem for me was that no glue is visible on pic#3 at the side of the tire/wheel.So I was not sure are we suppose to glue that whole side of the tire also, not just the sharp edges.
thanks,
-Pate
Old 04-18-2012, 10:55 PM   #111
CristianTabush's Avatar
wrong thread sorry.
REFLEX RACING/ RSD/ GIZMO RACING USA/ HOBBYWING/ AXON/ QTEQ/ TEAM PRIME
CristianTabush is offline   Reply With Quote
Old 05-13-2012, 05:23 AM   #112
blade072's Avatar
Trader Rating: 98 (100%+)
ok ill post this here.....and have on the f104 thread also
do ride tires fit these tamiya wheels or do i need to use ride wheels???
and if i need to use tamiya tires which ones??
thanks in advance
http://www.tamiyausa.com/product/ite...oduct-id=54201
David Randall
AWESOMATIX A800X ★ MUCHMORE ★ R1 WURKS ★
ROCHE RAPIDE F1-16 ★ SANWA M12 ★ SILVERBACK ★
HOBBYWING ★ RCMAKER ★ VOLANTE RC ★
blade072 is offline   Reply With Quote
Old 05-13-2012, 12:08 PM   #113
spring71's Avatar
Smile
thanks in advance
Ride F104 rubber tires fit on Ride F104 Wheels.
http://www.tqrcracing.com/shop/produ...d=f104&pg_no=1
Ride F103 rubber tires fit on Ride F103 wheels and Tamiya F103 Foam Wheels.
http://www.tqrcracing.com/shop/produ...d=f103&pg_no=1
Thanks.
TQ RC RACING
Online Shop
[email protected]
Old 05-14-2012, 03:46 AM   #114
blade072's Avatar
thanks spring71
so if i want to run shimizu i need to get the tamiya foam wheels and do the mod...
i already use ride wheels/tires was hoping they could be used on the tamiya wheels thats all
might have to do an order soon!!!
David Randall
Old 05-14-2012, 10:08 AM   #115
spring71's Avatar
Smile
thanks spring71
Yes, Shimizu F104 tires fit on Tamiya Foam Wheels and Rubber wheels with modification.
Shimizu F103 tires and Ride F103 tires fit on Tamiya F103 foam wheels and Ride F103 rubber wheels.
Thanks.
TQ RC RACING
Online Shop
[email protected]
Old 05-15-2012, 03:30 AM   #116
blade072's Avatar
and off topic what wheels are needed for hpi tires???
David Randall
Old 05-15-2012, 07:16 AM   #117
I was of the understanding that the HPI tyres came out of the Ride factory......
Racing program on # pause #
RedBullRacing is offline   Reply With Quote
Old 05-15-2012, 07:19 AM   #118
blade072's Avatar
i knew they looked the same.....saw some on a fellow racers car...so i guess they are rides..
David Randall
Old 06-01-2012, 08:08 PM   #119
Dan
Dan's Avatar
Trader Rating: 48 (100%+)
Which Shimizu tire setup would you guys recommend for front and rear for F104?
This will be for summer (warm weather) racing on prepped asphalt track.
Dan is offline   Reply With Quote
Old 06-01-2012, 08:27 PM   #120
F N CUDA's Avatar
Trader Rating: 31 (100%+)
I only run 571/572 combo and couldn't ask for (or find) anything better.
Been a winning combo for us since their release.
Recently 577s have been seen up front on winning cars to calm steering reaction when rear grip isn't 100%.
See the tips in this thread for mounting, sand or grind off sharp edges of rims to help reduce the risk of sidewalls cutting from inside.
Craig Hammon
F N CUDA is offline   Reply With Quote
