Like Tree2Likes
Old 12-27-2011, 07:56 AM   #91
MAD916's Avatar
Also had a good test this weekend at our carpet trrack with the 0561 and 0565 combo of soft soft.... even when front tires come up to temp they really worked well with a good balanced car ... We tried medium front/soft rear and it took quite a few laps to build front tire temp but would be great on a track with super high grip like at a big event..
until you are running on an extreamly high grip carpet track I think soft soft is a good soulution.
in stock at:http://www.timezonehobbies.com/store...&cPath=3_93_94
Timezone Raceway Park " on-road outdoor european style road course.
Timezone II 60'x100' indoor carpet track. Host of the ROAR 2011 Carpet Nat's.
Timezonehobbies.com your new source for online RC products.
MAD916 is offline   Reply With Quote
Old 12-31-2011, 07:29 PM   #92
spring71's Avatar
Smile
Ride tires & wheels are back in stock.
Click Here
FYI, Thanks.
TQ RC RACING
Indoor RC Race Track & Hobby Shop in Chino, CA
Online Shop
http://www.tqrcracing.com
[email protected]
spring71 is offline   Reply With Quote
Old 01-05-2012, 11:38 PM   #93
spring71's Avatar
Smile How to glue shimizu F1 tire and Tamiya Foam wheels
TQ RC RACING
Online Shop
[email protected]
Old 02-15-2012, 09:42 PM   #94
spring71's Avatar
Smile
Ride tires are back in stock, Click Here
FYI, Thanks.
TQ RC RACING
Online Shop
[email protected]
Old 03-20-2012, 03:38 AM   #95
blade072's Avatar
Trader Rating: 98 (100%+)
help me i have a 3racing f109......the tires i have used are the
0548 and 0543 and 0548....
also have spare set or 0541
our track is an outdoor asphalt prepped track....
anyway all i seem to be able to do are donuts.....
seems like i have way too much steering and no grip at the rear.....
i noticed the rears are r3 and the front are r1
also what mods would be needed to run f104 wheels on a f103 based car
thanks
put it this way it was that bad im ready to change cars......but i dont think its that!!!!
David Randall
AWESOMATIX A800X ★ MUCHMORE ★ R1 WURKS ★
ROCHE RAPIDE F1-16 ★ SANWA M12 ★ SILVERBACK ★
HOBBYWING ★ RCMAKER ★ VOLANTE RC ★
blade072 is offline   Reply With Quote
Old 03-20-2012, 09:58 AM   #96
thanks
How tight is your differential? Have you loosened it up to the point of slipping a little to see how that affects your rear traction?
3Racing Sakura XI 17.5 TC
Formula Rabbit (FGX conversion) 21.5
STRC LCG 2WD Slash 17.5
Serpent S120 13.5
6376vette is offline   Reply With Quote
Old 03-20-2012, 07:37 PM   #97
spring71's Avatar
Smile
thanks
If it's spining out, loosen your diff until it starts slip and tighten a little bit.
Or try Soft rear tires, PS-0545 or PS-0549
Thanks.
TQ RC RACING
Online Shop
[email protected]
Old 03-20-2012, 09:23 PM   #98
Arahawak's Avatar
Trader Rating: 32 (100%+)
Question.. How big a hole should be made for the vents?
What does it do actually?
Support Bacteria - its the only culture some people have!
Arahawak is offline   Reply With Quote
Old 03-20-2012, 10:27 PM   #99
texastc's Avatar
I drill a very small, 2mm tops (im guessing) it let's air escape out of the tires.
Exotek F1Ultra Tamiya TRF101 Speed Passion SP1 and Exotek F1UltraX Prototype.
"TexasTC, the single Greatest RCF1 racer I have ever known" - My mom
"you are a disgrace to RC" - everyone else. TCdoesRC
texastc is offline   Reply With Quote
Old 03-20-2012, 10:40 PM   #100
MikeR's Avatar
Trader Rating: 15 (100%+)
thanks
PS-0542 for the rears. 'HARD' is not the correct description because they are pretty soft. I think Pit meant 'HOT' because they are excellent on asphalt and use the stock insert too. They are working just like the Shimizu 72 'hard' for the F104 which means A+.
Clean tires and sauce the rears.
www.exotekracing.com ☆ASSOCIATED☆DURANGO☆HPI☆HB RACING☆KYOSHO☆LOSI/TLR☆SERPENT☆TAMIYA☆TEKNO☆XRAY☆
A picture with your post, when trouble shooting, will probably get more rctech help than without...
MikeR is offline   Reply With Quote
Old 03-20-2012, 10:42 PM   #101
Arahawak's Avatar
Does it help cool the tires say I run a very soft tire on a hot day?
I am experiencing no grip on soft tires and yet the harder tires are performing well... I am thinking maybe due to the heat generated.
Old 03-20-2012, 10:43 PM   #102
Arahawak's Avatar
Pit sells F1 inserts seperately?? Have not seen them before...
Old 03-20-2012, 10:55 PM   #103
MikeR's Avatar
They do but not the one we need. So far they only sell the full f104 foam- not the thins.
Old 03-20-2012, 11:01 PM   #104
Arahawak's Avatar
So they only 1 type.. Not like touring cars where they have like soft, mediums etc...
What are the part numbers or where to get them?
Old 03-21-2012, 12:01 AM   #105
blade072's Avatar
thanks spring71 and mike r........unfortunately we can only clean our tires......next meet i will have a 21.5 in.....looks like i have some testing and setup to do.....
also off topic....has anyone tried the trg tires??????
David Randall
