Like Tree2Likes
Old 07-15-2011, 07:24 AM   #46
k_bojar's Avatar
Trader Rating: 30 (100%+)
Send a message via ICQ to k_bojar Send a message via AIM to k_bojar
anyone find any other options to mounting the Shimizu tires? I really don't want to f'up a set trying to mount them to foam rims
or is it not as difficult as it sounds?
any ideas?
Bodies By Bean | Team Belly
k_bojar is offline   Reply With Quote
Old 07-15-2011, 08:27 AM   #47
texastc's Avatar
how about mounting them to Ride wheels?
Exotek F1Ultra Tamiya TRF101 Speed Passion SP1 and Exotek F1UltraX Prototype.
"TexasTC, the single Greatest RCF1 racer I have ever known" - My mom
"you are a disgrace to RC" - everyone else. TCdoesRC
texastc is offline   Reply With Quote
Old 07-15-2011, 09:28 AM   #48
spring71's Avatar
Smile
any ideas?
Shimizu F104 rubber tires only fit on Tamiya Foam rims, doesn't fit on Ride or Tamiya rubber rims.
It's not that hard, here is the picture of Shimizu F104 rubber with Tamiya Foam rims.
I'll upload more pictures.
TQ RC RACING
Indoor RC Race Track & Hobby Shop in Chino, CA
Online Shop
http://www.tqrcracing.com
[email protected]
spring71 is offline   Reply With Quote
Old 07-15-2011, 11:29 AM   #49
texastc's Avatar
Oops. Sorry about that. I'm learning. Have some shimuzus coming for my F109. After reading this thread and asking around, I'm excited about trying them out.
Old 07-15-2011, 11:38 AM   #50
Trader Rating: 32 (97%+)
Which tires do I order to get them on my F201? Do I get the HPI F10 version of tires/wheels?
Hotshot Rc Raceway
kikcaffine is offline   Reply With Quote
Old 07-15-2011, 02:07 PM   #51
British Menace's Avatar
I have used these Shimiyzu tires. Bothcompounds and found them to be highly grippy and stable!! Although, not wanting to contradict you here but I found the tires fit better on the stock Tamiya wheels for rubber tires then the foam wheels.
don't get me wrong. They do fit fine on the wheels for foam tires and they really are not hard at all to mount and glue. But I found with a good insert and if you carefully remove the outer securing rim on the wheels for rubber tires. The inner rim supports the insert and the tire bead better.
BM
So enjoying building cars I sometimes forget to save some "man-time" to race them!?
British Menace is offline   Reply With Quote
Old 07-15-2011, 03:12 PM   #52
spring71's Avatar
Smile
Originally Posted by British Menace View Post
I have used these Shimiyzu tires. Bothcompounds and found them to be highly grippe and stable!! Although, not wanting to contradict you here but I found the tires fit better on the stock Tamika wheels for rubber tires then the foam wheels.
BM
Could you upload the pictures of shimizu with tamiya rubber rim ?
If it fits, it's great... we have more options to choose of rims.
Thanks for the information.
TQ RC RACING
Online Shop
[email protected]
Old 07-15-2011, 04:07 PM   #53
Sure. I have two sets glued up. I'll try getting some photos done and uploaded tommorow am.
I want to try the Hard R1 tires next. These sound like they work well
BM
Old 07-15-2011, 04:10 PM   #54
spring71's Avatar
Smile
BM
Thank you
R1 Hard will be in stock next week. I'll post here, when it's available.
Thanks.
TQ RC RACING
Online Shop
[email protected]
Old 07-15-2011, 04:24 PM   #55
Great... I'll give them a go next race meet then.
By the way. Thank you for hooking me up with the F104 kit and all the parts and tires I asked for. Great service and very fast. Thanks!!
BM
Old 07-15-2011, 05:02 PM   #56
spring71's Avatar
Smile
BM
Thank you.
Glad to hear you like it.
TQ RC RACING
Online Shop
[email protected]
Old 07-15-2011, 08:34 PM   #57
Trader Rating: 69 (100%+)
Default Lastest Update on Pit Shimizu Tires
Performance Scale Remark
Steering (1-5) Based on steering input. (Understeer - Oversteer)
Stability (1-5) Driving down the straight. (Unstable - Stable)
Braking (1-5) High speed braking applied before the a tight corner. (Unstable - Stable)
Feel (1-5) The impression and bounciness of the car. (Floaty - Sticky)
Endurance (1-5) The wear rate of the tire. (Quick - Lasting)
Fade (1-5) Overheat resistance through the race. (Less - More)
Past Test Asphalt
Front Tires Pit Shimizu F3 (PS-0574)
Rear Tires Pit Shimizu R3-S (PS-0579)
Steering 1
Stability 5
Braking 5
Feel 5
Endurance 3
Fade 3
Track Tamiya America Outdoor
Surface Prepared Asphalt
Grip Medium
Weather Sunny, Slightly Windy, 70-75F
Chassis Tamiya F104 PRO Black Special
Setup Soft T-Bar, Soft Front-Springs Right-Height 5mm All-Round, No Friction Plate, Muchmore 400 Oil, Tamiya Soft Black Srping
Powerplant Team Orion Vortex Pro 21.5 Max Motor Timing, KO PROP BLZ ESC
Transmission Spur 93 Pinion 36 (slightly overgeared to reduce acceleration)
Radio KO PROPO Eurus, Steering Curve -25%, Throttle Curve -50%, Brake EPA 60%
Note Each test was only ran around 3-5 laps to get a feel for the initial impression. No tire sauce was applied to keep the test consistent.
Test 1 Asphalt
Front Tires Pit Shimizu F1-S (PS-0571)
Rear Tires Pit Shimizu R1 (PS-0575)
Steering 5
Stability 3
Braking 1
Feel 3
Endurance 2
Fade 3
Test 2 Asphalt
Front Tires Pit Shimizu F1-M (PS-0573)
Steering 4
Stability 4
Braking 2
Feel 4
Endurance 2
Fade 3
Test 3 Asphalt
Rear Tires Pit Shimizu R1-H (PS-0572)
Steering 3
Stability 5
Braking 3
Feel 5
Endurance 4
Fade 4
Test 4 Asphalt
Steering 4
Stability 4
Braking 2
Feel 4
Endurance 4
Fade 4
Test 5 Asphalt
Front Tires Ride S1 (24008)
Rear Tires Ride S1 (24010)
Steering 3
Stability 4
Braking 3
Feel 2
Endurance 4
Fade 2
Test 6 Asphalt
Front Tires Tamiya Hard (54198)
Rear Tires Tamiya Soft (54199)
Steering 4
Stability 3
Braking 2
Feel 3
Endurance 3
Fade 4
Track TQ RC Racing
Surface New Carpet
Grip Medium
Weather Indoor, 75-80F
Setup Soft T-Bar, Medium Front-Springs Right-Height 5mm All-Round, No Friction Plate, Muchmore 400 Oil, Tamiya Soft Black Srping
Transmission Spur 93 Pinion 35 (correctly geared for my setup)
Radio KO PROPO Eurus, Steering Curve -25%, Throttle Curve -25%, Brake EPA 60%
Test 7 Carpet
Steering 3
Stability 2
Braking 3
Feel 3
Endurance 3
Fade 3
Test 8 Carpet
Steering 1
Stability 3
Braking 4
Feel 4
Endurance 3
Fade 3
Test 9 Carpet
Steering 2
Stability 5
Braking 4
Feel 5
Endurance 4
Fade 5
Test 10 Carpet
Steering 3
Stability 4
Braking 3
Feel 4
Endurance 4
Fade 4
Test 11 Carpet
Steering 2
Stability 4
Braking 4
Feel 3
Endurance 4
Fade 3
Conclusion
The new Pit Shimizu R1-H seemed to grip better than my used R1 (medium), but I am not sure if it's because that the my used R1 has already lost its grip. The fair comparison would be to use a new set of R1 and R1-H for the test. Note that the R1 and R1-H have thinner inserts than the R3 and R3-S. Next, I plan to test different combo out again using 3-series tires, and then finally, mix and match.
eComet is offline   Reply With Quote
Old 07-15-2011, 11:12 PM   #58
spring71's Avatar
Smile
Wow, it's great review.
Thanks Alan.
TQ RC RACING
Online Shop
[email protected]
Old 07-16-2011, 04:38 AM   #59
http://www.rcmart.com/catalog/rc-tir...h=595_744_1390
would these be classed as medium or soft?
freakyfreakyflo is offline   Reply With Quote
Old 07-16-2011, 03:21 PM   #60
spring71's Avatar
Smile
Those tires are medium.
Here is more information.
Front tires
PS-0571: F1-Soft
PS-0573: F1-Medium
PS-0574: F3-Soft
PS-0577: F3-Medium
Rear tires
PS-0575: R1-Soft
PS-0572: R1-Hard
PS-0578: R3-Medium
PS-0579: R3-Soft
TQ RC RACING
Online Shop
[email protected]
