Like Tree2Likes
Old 04-15-2014, 01:43 PM   #256
Originally Posted by rnelias View Post
I've just got a F113 (3Racing) and wanna know which rims could be used with Shimizu rubber tires.
any of the tamiya rims for foams. or the ride rims etc. any rims for foam tires will be fine.
dragonracing is offline   Reply With Quote
Old 04-15-2014, 02:01 PM   #257
JLock's Avatar
Yes melias, use the appropriate Tamiya rims with the appropriate tires. The F103 and F104 have different sized tires (F103 smaller diameter and slightly wider than the F104 which are taller diameter and slightly narrower). Also, try this when you are gluing the tires to the rims: use the black tire glue. This gives you a few more seconds to line the edge of the tire to the edge of the rim before the glue sets. Let the tires sit for 24hrs, then run a bead of instant CA to the tire/rim seam. You should not have any issues with the tire separating from the rim down the road.
Texas 5
It's not what you know; it's what you can prove.
The only thing that is for sure is that nothing is for sure!!!
The needs of the many outweigh the needs of the few, or the one.
There are 2 things in life that are infinite: the universe and stupidity.
JLock is offline   Reply With Quote
Old 04-15-2014, 02:10 PM   #258
yeah he is right. i forgot to mention that you want to use the f104 rims with the pit tires designated for 104. you cant install 104 tires on 103 rims. and vice versa.
Old 04-15-2014, 03:56 PM   #259
Ph3nyx's Avatar
you must use F103 Foam rims with Pit shimizu PS-0541 and PS-0545
the first F1 RC resource in french : www.rcf1.fr
Ph3nyx is offline   Reply With Quote
Old 04-15-2014, 08:43 PM   #260
Send a message via MSN to rnelias Send a message via Skype™ to rnelias
Thank you all guys for the valuable help!
I haven't noticed F103 and F104 were different before finding them listed in TQ
In fact, I've got confused about all the combinations of compounds, brands for tires and rims and those that could be used by F113 with small modifications.
Here are the rims/tires that I've selected:
Tamiya F104 rims for foam:
http://www.tqrcracing.com/shop/produ...w.asp?p_id=302
Shimizu R1-hard for F103:
http://www.tqrcracing.com/shop/produ....asp?p_id=1987
Shimizu F1-Medium for F103:
http://www.tqrcracing.com/shop/produ....asp?p_id=1652
I live in Rio de Janeiro (Brazil) and here is hot like a hell (20 Celsius in the Winter and up to 50 in the summer). Moreover, our track is abrasive asphalt.
the only F103 Tamiya rim I've found...
http://www.tqrcracing.com/shop/produ...w.asp?p_id=619
rnelias is offline   Reply With Quote
Old 04-16-2014, 01:43 AM   #261
Ph3nyx's Avatar
there's 2 more
http://www.tqrcracing.com/shop/produ...w.asp?p_id=620
http://www.tqrcracing.com/shop/produ....asp?p_id=2220
F104 rims won't fit with f103 tires.
Old 04-16-2014, 04:09 AM   #262
Thanks Ph3nyx. I've changed the wheels for the correct ones.
I haven't found the black tire glue JLock mentioned
Is it CA?
Old 04-16-2014, 04:43 AM   #263
Ph3nyx's Avatar
Yes it's CA for tires
http://www.tqrcracing.com/shop/produ...05&s_maker_id=
Old 04-16-2014, 08:54 AM   #264
JLock's Avatar
Is it CA?
My LHS carries the black tire glue. It is more flexible than regular CA, sort of like a rubberized CA. Since going with this type of glue, my tires stayed glued to the rims longer and I don't have to use an accelerator. I get my best results when I let it cure for 24 hours before using the tire. Below are a couple of links to the type of glue I am referring.
http://www.shop.superstitionhobbies....FdBcMgodCCkAGA
http://www.siriusrocketry.biz/ishop/...FcURMwodMkUA_g
Both are pretty much the same but are labeled slightly different. But, this is some of the best glue to use on rubber tires to plastic/nylon rims.
Texas 5
Old 04-16-2014, 10:20 AM   #265
Thanks JLock. Just found it on eBay
http://www.ebay.com/itm/251400926348
(easier checkout )
Old 04-16-2014, 05:21 PM   #266
spring71's Avatar
Smile
New Shimizu PS-0590 F104 Rear (36deg Hard for Hot Weather) is available.
http://www.tqrcracing.com/shop/produ....asp?p_id=7808
FYI, Thanks.
TQ RC RACING
Indoor RC Race Track & Hobby Shop in Chino, CA
Online Shop
[email protected]
spring71 is offline   Reply With Quote
Old 04-16-2014, 05:29 PM   #267
evochick's Avatar
FYI, Thanks.
I saw that added the other day, just as we are coming into winter over here in Aus, I wont need to try them out for another 8 months.....
Unretired
2017 ACT Rally champion :)
evochick is offline   Reply With Quote
Old 04-17-2014, 04:18 AM   #268
ta04evah's Avatar
I wonder how they would perform against the Ride R1 tires on a hot day?
Castle Hill RC On Road Facebook https://www.facebook.com/groups/121817254587521/
FatBear RC Videos https://www.youtube.com/channel/UCjiAhwa-rk5Vas2rv5IBD4A
ta04evah is offline   Reply With Quote
Old 04-17-2014, 08:06 AM   #269
JLock's Avatar
FYI, Thanks.
Something that I will need to check out. Living in Texas, it gets really hot most summers (avg been around 100F degrees last couple of years) with the asphalt reaching temps of 140F degrees plus easily.
Texas 5
Old 04-22-2014, 05:22 AM   #270
Acid_CZ's Avatar
Send a message via ICQ to Acid_CZ
FYI, Thanks.
Hi.
What tire insert is in the package? Also, are they harder than R3, which are good for hot summer days?
Acid_CZ is offline   Reply With Quote
