Like Tree2Likes
Old 08-19-2013, 05:56 AM   #241
Originally Posted by rxsevengt View Post
Hi All,
Is there a way to remove the Shimizu's from your foam rims when they are worn out? I have a couple of sets with worn out rubber an I would like to recycle the rims if possible
Acetone. Put the wheels in an airtight container with a small amount of acetone, I put it in a small bottle cap, and leave for a day or two. The tyre will then just peel off.
terry.sc is offline   Reply With Quote
Old 08-25-2013, 06:34 AM   #242
rxsevengt's Avatar
Location: Smashing the wall at the end of the straight @ Ryper Raceway
Thumbs up
Thanks mate
Needs moar rotor
rxsevengt is offline   Reply With Quote
Old 09-10-2013, 01:10 PM   #243
Acid_CZ's Avatar
Send a message via ICQ to Acid_CZ
Acid_CZ is offline   Reply With Quote
Old 09-19-2013, 01:24 AM   #244
metalnut's Avatar
Trader Rating: 36 (100%+)
Stupid question, but what do you guys use to glue the two ends together of the rubberish insert that comes with the rear 572 tires?
Team Nervous | Team Scruffy | Team Orange
"If you ain't first, you're last!"
- Ricky Bobby
metalnut is offline   Reply With Quote
Old 09-19-2013, 02:02 AM   #245
Ph3nyx's Avatar
i use yellow neoprene contact glue , works realy well
the first F1 RC resource in french : www.rcf1.fr
Ph3nyx is offline   Reply With Quote
Old 12-23-2013, 07:30 AM   #246
j.d.roost's Avatar
Trader Rating: 28 (100%+)
Is there a tire that's "one step harder" than the 0572. We are running high grip carpet...and my rear is too locked in.
F1
Roche usa
R.I.P. Jon Williams
j.d.roost is offline   Reply With Quote
Old 01-06-2014, 09:06 PM   #247
metalnut's Avatar
I asked this in the F1 thread, but didn't get any replies, so maybe this is more appropriate. Sorry about the copy/paste:
I have an SP-1 with Pit tires that I run on a CRC carpet track. I'm having some issues with front/overall traction that I'm hoping you all can help me figure out.
So, the front Pit tire is a bit tapered/coned on the outside half, which seems like a bit of built in camber. What I'm trying to figure out is the tire sauce strategy vs. camber settings vs. caster settings.
First, I fully sauce the back, no matter what.
Second, I was running a 10 degree caster plate, 1 degree camber, and then saucing the front tires 1/2 - 3/4, depending on the track grip throughout the night. I was still understeering so I flipped the caster plate to the 5 degree side, keeping camber at 1 degree and saucing similar. I suddenly had a lot of oversteer.
It seems to me that, with the outside coning/taper, saucing the front Pit tires is tricky. The window of proper grip is very narrow. I wanted to ask how you guys handle this? What's the typical camber settings for these tires, and how do you sauce the fronts throughout the night?
And should I stick with the 5 degree caster plate, or go back to 10 degrees?
- Ricky Bobby
Old 01-06-2014, 11:49 PM   #248
j.d.roost's Avatar
One thing I learned in the past two weekends of running the 072 front is...You got to be on your sauce game. Be prepared to switch it up with grip...and most importantly take notes of where grip was...amount/time and results.
I have never had a tire that was so sensitive to sauce application. When I get it right my 104 v2 is money. When I don't it's traction rolling the 1st half or I loose all steering around the 3 min mark.
My standard procedure has been 1/4 front at 5 min ( no longer) or half with a wipe on wipe off right before the heat. I have actually sat in line to race my heat with a bottle of Sxt sitting next to me.
I can't help much with setup advice as I am still learning myself.
F1
Roche usa
R.I.P. Jon Williams
Old 01-07-2014, 02:04 AM   #249
Ph3nyx's Avatar
For my use , high grip carpet with 0572 too , i dont use the 10 caster plate , it understeer the car way too much. i keep the 5 setting
i sauce the rear full for 20 min and the front interior 1/3 for 20min too with CS speed grip or corally jack the gripper.
Old 01-07-2014, 08:50 AM   #250
metalnut's Avatar
Interesting... hrm. So, on our track we can only use SXT 3.0 or Jack, but I think both are more than up to the task. I feel like saucing the inner 1/2 (up to where the "taper" starts) doesn't give me much grip, but as soon as I go past that (so onto the "taper") things get very sensitive very quickly.
Ok, so, I'll keep my 5* caster plate and my 1* camber, unless someone suggests otherwise, and I'll try just playing with the sauce application.
I admit, I have been letting the front soak as long as the rear, so, 30+ minutes if not more. My VTA car can take full sauce front and for hours and loves it, so this is a totally different ball game.
- Ricky Bobby
Old 01-23-2014, 09:51 PM   #251
SavageCanadian's Avatar
Trader Rating: 58 (100%+)
Send a message via MSN to SavageCanadian
Just read a bunch of this thread and still cant find the answer im looking for. Going to be building a Exotek F1R2 and wondering which Pits will work best for medium to high grip carpet tracks?
CR Performance Custom RC Parts (PM for details)
Colin Roussel
2013/2014 WCICS CTA Champ
Awesomatix | CRP F1 | Trinity/Revtech | SANWA | ORCA
SavageCanadian is offline   Reply With Quote
Old 01-24-2014, 02:09 AM   #252
Ph3nyx's Avatar
For the front PS0571 or Ps0574 if you want more grip
PS0572 rear or PS0575 for more grip too , but if you are on a high grip carpet you can go for the 571-572 combo , 574-575 might be a little bit more "touchy"
Old 01-24-2014, 07:03 AM   #253
liljohn1064's Avatar
Trader Rating: 17 (100%+)
Run the 572s with the optional insert. It will stiffen the tire up a bit.
John Higgins former student of The Ian Ruggles Negative Reinforcement Driving School. The "Team Principal".
liljohn1064 is offline   Reply With Quote
Old 03-02-2014, 12:58 PM   #254
KBRacing's Avatar
Hi All,
Is there anyone who can tell my, what Compound the of the Ride ETS Formula 1 tire RI-26022 and R-26023 is........?????
KBRacing is offline   Reply With Quote
Old 04-15-2014, 01:14 PM   #255
Send a message via MSN to rnelias Send a message via Skype™ to rnelias
I've just got a F113 (3Racing) and wanna know which rims could be used with Shimizu rubber tires.
rnelias is offline   Reply With Quote
