Like Tree2Likes
Old 01-01-2013, 08:55 AM   #196
Andysan's Avatar
Originally Posted by texastc View Post
R1 Hard 0542 rear and F3 Soft 0544 front for carpet work well
Still struggling with this setup - only ever experienced the foams before, would be grateful if anyone could point me in the right direction with regards to a basic setup for carpet using the above tyres please? Currently the car understeers very wide on corner entry and spins on-power out of the corner. The exception being really fast long corners where it just seems to spin out on corner entry.
Any general setup tips appreciated - cheers.
Andysan is offline   Reply With Quote
Old 01-06-2013, 09:50 PM   #197
liljohn1064's Avatar
Trader Rating: 17 (100%+)
The Ride R1/R1 combo just has not come in for me. I put about 3 runs on them and they are still not completely scuffed in. Fronts are still super shiny and that is after full cleaning, compound and run as hard as possible.
John Higgins former student of The Ian Ruggles Negative Reinforcement Driving School. The "Team Principal".
liljohn1064 is offline   Reply With Quote
Old 01-11-2013, 07:33 PM   #198
Jerz616's Avatar
Trader Rating: 49 (100%+)
Can anyone tell me the difference between Pit tires? I can figure out the soft, medium, hard as thats pretty self explanatory. What do the numbers represent? Are they a reference to the firmness of the side wall, and how much difference does the number make. We use the 573/572 combo at our carpet track, but would like to try different combos.
Ryan Gracey
XRAY T4'14/ORCA VXX/ORCA TX 5.0
XRAY XB8'14
Jerz616 is offline   Reply With Quote
Old 01-14-2013, 05:23 AM   #199
TryHard's Avatar
They will never steer as hard as a set of Pits, but by going softer on the front, adding more toe-out, and (i find) running less camber really helps to gain more steering. Also bare in mind all my running is outdoor asphalt
| THard.co.uk | Xray | MuchMore |
Old 01-14-2013, 11:26 AM   #200
Trader Rating: 23 (100%+)
The same problem was driving me nuts yesterday, turns out the foams in the rear are thicker than say.. 0574. so the contact of the tire is only on the very center of the tire. upon swiching to the tire with thiner incert the car was perfect.
pete8541 is offline   Reply With Quote
Old 01-14-2013, 12:00 PM   #201
Makes sense on decreasing negative camber, I'll give it a try. I'm running 1* toe out on each side and like the initial turn in. I'll set camber at 1* instead of 1.5*. It should in theory increase the contact patch mid corner. Right now I think even the little bit of camber gain due to caster is putting me on the inside edge (1/4 or less) of the tire. And it is hell getting any tire scuffed in on carpet!
Old 01-15-2013, 06:55 AM   #202
TryHard's Avatar
That's what I found in my testing, is that less camber actually helped to keep the tyre more in contact during cornering. Didn't really help the initial, but middle was much better, and could get on the gas earlier/hold tighter line One time I tried going to 2.5, and it was horrible, completely washing away in the centre of the turn..
Old 01-16-2013, 09:11 AM   #203
scr8pn4205's Avatar
Running tamiya f104 v2 on carpet. What is a good starting setup for the pit shimizu rubber tire. I have heard 0573 front and 0572 rear. Thanks
Airtronics M12
Team Xray XB2 2017 CE
TSR power
scr8pn4205 is offline   Reply With Quote
Old 01-16-2013, 09:34 AM   #204
240Z's Avatar
This page from the UF1 wesite may help some, but it needs to be updated.
I don't always race RC, but when I do, I prefer "UF1 format".
240Z is offline   Reply With Quote
Old 01-16-2013, 10:28 AM   #205
TCS_FUN's Avatar
Last night was the first time I had the V2 out on the track. We are indoors on carpet.
I used the the tamiya option tires, hard front soft rear. Car was easy to drive even with the kit setup. Had tons of steering but what I noticed was you really had to baby the throttle coming out of the corner apex. With foams you could mash the throttle and be okay but rubber is a whole different ball game!!!!
TCS_FUN is offline   Reply With Quote
Old 05-09-2013, 03:44 AM   #206
Monsta's Avatar
Has anyone had issues with the Ride R1's being out of balance and causing vibrations?
BD7 '14 / Trinity / LRP / SANWA
F1R2 / Reedy / Hobbywing / SANWA
1:1 racer
HR31 Skyline - 350Kw RB30DET, 1130kg and 255 wide R comp tyres... needs more traction!
Monsta is offline   Reply With Quote
Old 05-10-2013, 11:51 AM   #207
Mr. MR4's Avatar
the ride premounted tyres do cause some vibration. I have found that the ones you mount yourself have nearly no vibrations at all.
Xray T4'16 HobbyWing Xerun 120A V3.1
Xray X1'16 HobbyWing Justock
Yokomo R12C3 HobbyWing Xerun V3.1
Mr. MR4 is offline   Reply With Quote
Old 05-10-2013, 06:46 PM   #208
Nuno Gancho's Avatar
Comparing R1 and Pit wish ones will you choose, thanks.
Nuno Gancho is offline   Reply With Quote
Old 05-11-2013, 08:53 AM   #209
Monsta's Avatar
Thats interesting. I mounted them myself, each corner needed some weight added. Was bad enough for the wing to vibrate up to 5mm on throttle.
Other thanks that, fantastic tyre! So much grip
1:1 racer
Old 05-12-2013, 11:07 AM   #210
Mr. MR4's Avatar
Default Difference in Pit Shimizu Tyre Compounds
Hi,
What is the difference between the F1 soft and F3 soft? and R1 and R3 soft?
571 - F104 Front F1-Soft (1 pair) with inserts
573 - F104 Front F1-Medium (1 pair) with inserts
574 - F104 Front F3-Soft (1 pair) with inserts
577 - F104 Front F3-Medium (1 pair) with inserts
572 - F104 Rear R1-Hard (1 pair) with inserts
575 - F104 Rear R1-Soft (1 pair) with inserts
578 - F104 Rear R3-Medium (1 pair) with inserts
579 - F104 Rear R3-Soft (1 pair) with inserts
