Like Tree2Likes
Old 09-01-2012, 07:23 PM   #181
spring71's Avatar
Smile
Originally Posted by Telinoz1975 View Post
Thanks.
So to confirm, for the F104 using Pit Shimizu Grooved tires PS-0561 Fronts and PS-0565 rears the following rims are options;
FRONT
1) Tamiya 51398 - Grey
2) Tamiya 54201 - Silver
3) Ride 25004 - Black Metallic
4) Ride 25009 - Black
REAR
3) Ride 25005 - Black Metallic
4) Ride 25010 - Black
Yes...
TQ RC RACING
Indoor RC Race Track & Hobby Shop in Chino, CA
Online Shop
http://www.tqrcracing.com
[email protected]
spring71 is offline   Reply With Quote
Old 09-01-2012, 09:06 PM   #182
f1larry's Avatar
R/C Tech Charter Subscriber
Trader Rating: 17 (100%+)
Send a message via AIM to f1larry
Which pit tires work on the f103 that are still able to be found?
Windy City RC Raceway & Hobbies, Arlington Heights, IL
Exotek F1R3|X-Ray T4 16|CRC Xti Altered Ego|Associated B5M|TT02|TA05|TL01RA|TL01|
f1larry is offline   Reply With Quote
Old 09-01-2012, 10:02 PM   #183
texastc's Avatar
R1 Hard 0542 rear
and F3 Soft 0544 front for carpet work well
The F1 Soft 0541 and Med 0543 work well on asphalt
R1 Hard is THE rear for either surface so far
Exotek F1Ultra Tamiya TRF101 Speed Passion SP1 and Exotek F1UltraX Prototype.
"TexasTC, the single Greatest RCF1 racer I have ever known" - My mom
"you are a disgrace to RC" - everyone else. TCdoesRC
texastc is offline   Reply With Quote
Old 09-02-2012, 03:42 AM   #184
I've tested the re-branded pit shimizu tires from tamiya on an indoor carpet track and now i can understand why lot's of you guys are saying that those tires are the best combo.
With the original rubber tamiya tires i was unable to compete with the other guys who are running on foam tires, but with the TCS tamiya tires i was able to compete.
The TCS tires makes the car more smooth in cornering and a lot easier to drive.
All i need to find is some more on power steering and i will be even faster
Definately worth the money, will be buying some more
addicted2blue is offline   Reply With Quote
Old 09-02-2012, 04:58 AM   #185
Originally Posted by spring71 View Post
Yes...
Thanks, sent the order today + some re-stock for me and a spare damper.
Your site has good support for F1
Telinoz1975 is offline   Reply With Quote
Old 10-31-2012, 06:54 PM   #186
spring71's Avatar
Smile
New Ride R-1 High Grip Compound F1 tires are available. Click here for more info.
Thanks.
TQ RC RACING
Online Shop
[email protected]
Old 11-01-2012, 12:08 AM   #187
Trader Rating: 21 (100%+)
Thanks.
Exciting news sean. It'll be interesting to see how the new compounds run compared to the 571/572 combo.
silencery is offline   Reply With Quote
Old 11-25-2012, 08:53 AM   #188
Andysan's Avatar
Hi All,
Thanks for the tips, went with the R1 Hard 0542 rear and F3 Soft 0544 front for carpet running for my F103. I'm struggling with power-on oversteer out of the slow corners, and understeer through the fast bends. Any tips anyone can offer for setup please, as I've only run foams before.
I've found that generally stiffening the car up seems to work - stiffer center shock spring, tightened the T-bar right up. I've also noticed that the rears are only wearing on the extreme edges and along the center, with a bit of a rise in the tyre along the centre that no amount of sanding on the tyre truer seems to improve - how long should it take the tyres to come into a good operating phase - I'd also be interested as to roughly how long they should last?
Andysan is offline   Reply With Quote
Old 12-31-2012, 12:57 PM   #189
liljohn1064's Avatar
Thanks.
Any word on these?
John Higgins former student of The Ian Ruggles Negative Reinforcement Driving School. The "Team Principal".
liljohn1064 is offline   Reply With Quote
Old 12-31-2012, 01:29 PM   #190
Thanks.
I ordered some for the F104 and FGX to test anyway. Always fun to test!
Old 12-31-2012, 07:30 PM   #191
Make sure to let us know how these work for you. Been thinking about ordering some for myself but waiting till they get a good review from somebody first.
racer robert is offline   Reply With Quote
Old 12-31-2012, 08:38 PM   #192
Will do. I hate gluing tires!
Old 12-31-2012, 10:33 PM   #193
fleetmaster's Avatar
Trader Rating: 16 (100%+)
I found rear R1 give more grip than SuperSoft (fitted to FGX)
Front seem to yield less grip than SuperSoft ( same)
This is indoors, bumpy , tight , grippy concrete (anti-slip painted)
fleetmaster is offline   Reply With Quote
Old 12-31-2012, 10:52 PM   #194
TryHard's Avatar
Ive run both the 571/572 and Ride R1 combos on my 104WGP here on outdoor asphalt. What I can say, is that they handle very very differently.
Whilst with the 571/572 combo, I generally had to go harder on the front to take away steering, with the R1's, you need to go soft soft soft to gain some back. (this is 17.5 blinky btw). The R1 front compound is pretty hard, so doesn't really generate a lot of steering. Having said that, they do last a long time (at least 20+ 8min runs), but there is a performace peak. Take about 5runs to break in, then they are good for fast times for about 7-8 runs, then start to tail off again, at least thats my findings (based on practise for the nationals demo class out here, which we all used R1's as spec tyre).
Having said all that... I've still set my fastest times with the R1's over the 571/572... so worth trying out if you can get the car setup for them.
HiH
Ed
| THard.co.uk | Xray | MuchMore |
Old 12-31-2012, 11:48 PM   #195
Thanks Ed, I always appreciate your advice.
