Like Tree2Likes
Old 08-08-2012, 01:47 AM   #151
sir miles's Avatar
Trader Rating: 23 (100%+)
How about a ride rubber tires combination for F104 on an indoor prepped track?
gaining momentum!
sir miles is offline   Reply With Quote
Old 08-08-2012, 03:17 PM   #152
F N CUDA's Avatar
Trader Rating: 31 (100%+)
Nothing from Ride that will rival the Pit 571/572 combo, that's why we all run them.
Craig Hammon
F N CUDA is offline   Reply With Quote
Old 08-08-2012, 04:05 PM   #153
sir miles's Avatar
Thanks Sir!
gaining momentum!
Old 08-10-2012, 09:51 PM   #154
What is the OD of mounted F1 rubber tires
ChrisHarrington is offline   Reply With Quote
Old 08-14-2012, 07:47 AM   #155
Alfonso_R's Avatar
Send a message via Yahoo to Alfonso_R
Thanks, spring71 ! But with the HPI It get's really twitchy when I use that or the soft-soft. Then I understeer when i use medium-medium. I'll go test the shimizu's next !
Alfonso_R is offline   Reply With Quote
Old 08-16-2012, 07:38 AM   #156
cadillac's Avatar
Trader Rating: 85 (100%+)
do they make a rear insert for the pit tires and tamiya rims that comes as a doughnut? i have a f104x1...
also what inserts are recommended for asphalt with the 0572 and 0573 combo?
thanks
Thanks to those who support me in my RC adventures....
COW RC / DE RACING / TEKNO RC / PHATDAD RC
cadillac is offline   Reply With Quote
Old 08-16-2012, 07:56 AM   #157
Shimizus 571/572 come with the inserts, you only need to make some holes in the foam rims and use some good rubber tire glue. Perfect match for your F104X1
T.O.P Photon EX-RCDevil PC10H3X-Xray X1
rokosam is offline   Reply With Quote
Old 08-16-2012, 08:01 AM   #158
cadillac's Avatar
do i have to glue the foam strip together?
Old 08-16-2012, 10:36 AM   #159
spring71's Avatar
Smile
You don't have to glue the inserts.
If you want to, scotch tape works fine.
Here is the shimizu inserts.
http://www.tqrcracing.com/shop/produ...yword=&pg_no=1
Ps-0550 is softer than stock inserts, gives you more traction.
Ps-0550-1 is the same inserts comes with ps-0572 & 0575.
Thanks.
TQ RC RACING
Indoor RC Race Track & Hobby Shop in Chino, CA
Online Shop
[email protected]
spring71 is offline   Reply With Quote
Old 08-16-2012, 11:11 AM   #160
NewWestF1's Avatar
do grooved or slick tyres work best for FGX on somewhat bumpy asphalt?
i have Ride/Bridgestone tyres soft back and front currently and get a lot of back end slide, would grooved be better?
.. Sakura FGX; Novak power plant, Exotek, Lotus/Renault #9 ..
.. TB-03 Calsonic GT-R . reventon s/ultra v.3 power plant . yeah racing ..
.. M-05 Mini Cooper, Silver Can 104BK speedo, fakkin' cute!
...one of these days, life will get easier...
NewWestF1 is offline   Reply With Quote
Old 08-16-2012, 12:11 PM   #161
I bought the new tamiya tires, it says that they are pit shimizu tires.
I've noticed that the inner foams for the rear tires are thin, do i need other foams or are they the correct ones?
addicted2blue is offline   Reply With Quote
Old 08-16-2012, 12:15 PM   #162
spring71's Avatar
Shimizu grooved tire has a lot more traction, so it will help.
Http://www.tqrcracing.com/shop/produ...rd=fgx&pg_no=1
TQ RC RACING
Online Shop
[email protected]
Old 08-16-2012, 12:18 PM   #163
spring71's Avatar
Smile
That's correct one same as shimizu 0572.
Thanks.
TQ RC RACING
Online Shop
[email protected]
Old 08-16-2012, 12:26 PM   #164
Originally Posted by spring71 View Post
That's correct one same as shimizu 0573.
Thanks.
So i don't need other or extra foams to put in the tire?
Old 08-16-2012, 02:29 PM   #165
240Z's Avatar
No other insert needed other than the thin one that came with the pit tire. Air gap is OK.
240Z is offline   Reply With Quote
