Like Tree2Likes
Old 06-29-2012, 09:00 PM   #136
1. Clean the tires and wheels with motor spray/soap water/degreaser to remove the mold release agents on the tires and wheels. Otherwises the CA glue won't stick.
2. Assuming the inserts are donuts and not strips*, seat the inserts into each tire. Work them with your fingers so there aren't any wrinkles. Do Not glue the foam inserts to the tires or wheels.
3. Assemble tires to wheels. Use fat rubber bands around the tires to help the tire seat tight against the wheel. Pull tire away slightly from wheel and apply CA sparingly on the bead of the tire. Reseat back onto wheel. (do this in small sections at a time)
4. When the glue is dry, use your thumb and try to peel back the tire from the wheel all the way around. Reglue any spots that peel back.
*if foam inserts come as strips you need to glue the ends together with rubber cement first then go to step 2.
Sydewynder is offline   Reply With Quote
Old 06-30-2012, 12:21 PM   #137
Tracy B's Avatar
Tires are glued to the rims & ready to run.
Very simple task to do, don't know why I was so nervous about doing it.
I got Front F1-S(PS-0541), Front F1-M(PS-0543), Front F3-S(PS-0544), Front F3-M(PS-0547), and Rear R3-M(PS-0548).
Thanks for the tips Sydewinder.
Tracy B is offline   Reply With Quote
Old 07-28-2012, 04:47 PM   #138
sir miles's Avatar
Trader Rating: 23 (100%+)
Hello! What is the best rubber combination for an indoor asphalt to be used on my F103?
gaining momentum!
sir miles is offline   Reply With Quote
Old 07-29-2012, 10:49 AM   #139
spring71's Avatar
Smile
Shimizu (PS-0541 or PS-0544) & PS-0542 has good steering setup. If you need stable setup, try PS-0545 & PS-0543 or PS-0549 & PS-0547.
http://www.tqrcracing.com/shop/produ...d=f103&pg_no=1
Also, Ride 24000 & 24001 works good.
TQ RC RACING
Indoor RC Race Track & Hobby Shop in Chino, CA
Online Shop
[email protected]
spring71 is offline   Reply With Quote
Old 07-30-2012, 05:52 AM   #140
PS-0541 (F1-S F103) /PS 0542 (R1-H F103) is as good combo as 0571/0572 is with F104?
T.O.P Photon EX-RCDevil PC10H3X-Xray X1
rokosam is offline   Reply With Quote
Old 07-30-2012, 10:49 AM   #141
I'm a noob with F1 RC cars. I just ordered the Shimizu 0571 and 0572's for my F104 and am super excited. Is there an optimum car weight and or front/rear weight distribution when using these tires? I have a full size 2S hard pack 4000mah pack and a 2200mah which is about half the size and weight.
Evandiego is offline   Reply With Quote
Old 08-01-2012, 07:06 AM   #142
sir miles's Avatar
Thanks for the answer. One last question, Will the Ride Type A tires fit the TRG F103 rims?
gaining momentum!
Old 08-01-2012, 06:04 PM   #143
spring71's Avatar
Smile
I haven't tried, but it's same rubber compounds, so will work pretty close.
TQ RC RACING
Online Shop
[email protected]
Old 08-01-2012, 06:10 PM   #144
spring71's Avatar
Smile
It's all about your setup.
If you need more weight on the front, people put lead weight under the front arms.
TQ RC RACING
Online Shop
[email protected]
Old 08-01-2012, 06:12 PM   #145
spring71's Avatar
Smile
Ride Type A tires are standard size of F103 rubber tires.
I'm not sure about of TRG rim size. If you can, measure with Tamiya F103 foam rims, if it's same it will fit.
Thanks.
TQ RC RACING
Online Shop
[email protected]
Old 08-01-2012, 07:10 PM   #146
texastc's Avatar
I really like the PS0542's and 0544's
Exotek F1Ultra Tamiya TRF101 Speed Passion SP1 and Exotek F1UltraX Prototype.
"TexasTC, the single Greatest RCF1 racer I have ever known" - My mom
"you are a disgrace to RC" - everyone else. TCdoesRC
texastc is offline   Reply With Quote
Old 08-05-2012, 03:48 AM   #147
sir miles's Avatar
saw this at RCmart website. I wonder if they will fit the Pit shimz i ordered for my F103
gaining momentum!
Old 08-05-2012, 11:14 AM   #148
spring71's Avatar
Smile
If it's desinged for Tamiya F103 Foam tires, it will fit.
Thanks.
TQ RC RACING
Online Shop
[email protected]
Old 08-06-2012, 08:07 PM   #149
Alfonso_R's Avatar
Send a message via Yahoo to Alfonso_R
Hi guys,
For those using an F10 on a medium-high grip asphalt track. What would be the best tire choice? Thanks !
Alfonso_R is offline   Reply With Quote
Old 08-07-2012, 11:53 AM   #150
spring71's Avatar
Smile
Originally Posted by Alfonso_R View Post
Hi guys,
Shimizu PS-0561 & PS-0565 works great.
http://www.tqrcracing.com/shop/produ...rd=hpi&pg_no=1
HPI Midium rear and Soft front is another good combo.
http://www.tqrcracing.com/shop/produ...yword=&pg_no=1
TQ RC RACING
Online Shop
[email protected]
