Old 06-10-2012, 01:40 PM   #91
dameetz's Avatar
Originally Posted by MonkeyNuts View Post
How much thicker are the Jet Racing motor mounts compared to the standard kit ones?
Its 3mm compare to the stock 2mm, I think ABC option mounts are 2.5mm. Anyway I Tq'ed and won my first race with the Gambado on its first race, even beating one of the guy who used a 4wd mini. I m loving it and its damn good.
Dudududududuuuuuu.....
dameetz is offline   Reply With Quote
Old 06-10-2012, 05:26 PM   #92
Trader Rating: 29 (100%+)
Not really sure as no one has them as yet, a friend of mine ordered some and when he gets them I will post the thickness, from the pics I would want to say they look like 3 to 4 mm thick and thin in the places where it needs to mount back to the org spots.
Plus abc hobby said they should have there upgrade motor mounts by the latest mid July
Hope this help
Andre
SFJR Series
ABC Hobby Grid, ARC R10, Airtronics, Tekin, TQ Monkey, Zombie Batteries
www.jamrocracing.com
awjs is offline   Reply With Quote
Old 06-11-2012, 10:42 AM   #93
MonkeyNuts's Avatar
Cheers, that's what I thought from looking at them. I will probably go for the Jet one's, as they'll go nice with the carbon chassis that I run on mine.
I will probably leave the steel counter gears TBH, I remember the problems I had when running the HPI Switch, with that having plastic-metal gears..
Liam
Tamiya FF03 Pro ~ Tamiya M06 Pro ~ Tamiya M05L JCW Coupe
MonkeyNuts is offline   Reply With Quote
Old 06-12-2012, 12:24 AM   #94
Liam
I run the the steel counter and haven't had any issues, before I would strip the gear inside the gear box (20t) and would have to do a lot of work to replace it so the steel one at least in the gear box I would recommend.
SFJR Series
Old 06-13-2012, 01:01 PM   #95
MonkeyNuts's Avatar
I've never had a problem with the gears actually inside the gearbox itself! Seems as though each car is different lol. For the time being I'm just going to get the Jet motor mount and see if that cures it.
Old 06-16-2012, 08:52 AM   #96
ppabalan's Avatar
Trader Rating: 23 (100%+)
Post Performance Upgrade for Grid/Gambado
Motor Plate Alu upgrade
PPabalan
ABC Hobby USA
[email protected]
www.abchobbyusa.com
Follow us in Twitter and Facebook : Abc Hobby USA
ppabalan is offline   Reply With Quote
Old 06-16-2012, 08:52 AM   #97
ppabalan's Avatar
awjs you got PM
PPabalan
ABC Hobby USA
[email protected]
www.abchobbyusa.com
Old 06-17-2012, 02:04 AM   #98
Originally Posted by ppabalan View Post
awjs you got PM
ok got it thanks sent one back
SFJR Series
Old 07-01-2012, 11:16 AM   #99
dameetz's Avatar
After running this car for 2 months I think I know the culprit for the counter gear strip problem. My car has already been upgraded to the thick motor mount (Jet Racing) and I bashed this car almost everyday eversince, 2 days ago I stripped the counter gear (outside gear) for the 1st time. I pulled it a part and found the counter gear shaft (part no 25666) has worn out at where the shaft's bearings sit. The shaft wobble and not running true making the counter gear's mesh with the spur gear inconsistent and eventually stripping itself out. I confirmed it with my friend's car which has regular stripping problem and his also has the wobble worn out counter gear shaft. We replaced his with a new shaft and the stripping problem went away. I think the aluminum material for that counter gear shaft is too soft and can easily wears out.
I hope ABC HOBBY can address this problem and maybe can come up with an option counter gear shaft made out of Hard Steel or Spring Steel, for sure it will last longer. Anyway i m still loving this car, its the car to beat at my local club.
Old 07-01-2012, 06:07 PM   #100
Raman's Avatar
Trader Rating: 56 (100%+)
Selling an ABC Goose rear wheel drive if anyone is interested
http://www.rctech.net/forum/r-c-item...l#post10925859
TRF419X USGT, Roche F1 '16, M06 Pro M Chassis
Raman is online now   Reply With Quote
Old 07-03-2012, 02:07 PM   #101
Default Good job
Hi all
Installed the new motor mounts and fan unit in my car very nice job ABC it looks good and works really well. Ran all weekend I really like the fan unit too kept my motor at 123 motor temp all weekend. Looking forward to future upgrades.
I have some motor mounts for sale if anyone is instrested
Jamrocracing.com
SFJR Series
Old 07-03-2012, 02:08 PM   #102
Thanks for your input I will keep a look out for that beaning an issue and report back
SFJR Series
Old 07-14-2012, 11:31 PM   #103
Default Race Night
Just got back from a race night at my local track and I was the top qualifier, A main got rained out, this mini is really nice, having so much fun with this car.
SFJR Series
Old 07-27-2012, 05:16 AM   #104
has
somebody made ​​experience with a different weight arrangement?
With ABC GRID?
Sascha Feldt is offline   Reply With Quote
Old 08-30-2012, 09:07 AM   #105
dameetz's Avatar
Default Toyota MR2 body
Has anyone tried ABC Hobby Toyota MR2 (AW11) in a Grid/Gambado? Will it fit?
Electric 1/8th Scale conversion kits. DJ1978 Electric Off-Road 19923 06-12-2017 06:16 AM
