Ask Steve "The Evicerator" Weiss >
Old 02-23-2005, 01:56 PM
  #1051
R/C Tech Founder
Steve,
I know you want it:
http://cgi.ebay.com/ws/eBayISAPI.dll...sPageName=WDVW
futureal is offline
Old 02-23-2005, 02:15 PM
  #1052
DavidAlford's Avatar
Trader Rating: 31 (100%+)
23 bids? wow....
DavidAlford is offline
Old 02-23-2005, 02:19 PM
  #1053
SCML's Avatar
$34, WOW! That is too funny.
SCML is offline
Old 02-23-2005, 02:27 PM
  #1054
The Evicerator
Ray, Most guys are running 1.5 or 2.5 now for drive freq... I don't know how the cyclone will run at that low of a drive frequncy though...
Steve Weiss is offline
Old 02-23-2005, 03:46 PM
  #1055
J.Filipow's Avatar
Trader Rating: 15 (100%+)
"...burninating the country side..."
J.Filipow is offline
Old 02-23-2005, 07:39 PM
  #1056
rayhuang's Avatar
I opened every bag of frozen vegetable and frozen food in my freezer and i didnt find anyting that looked like a super hero, actor, cartoon character. Certainley nothing to sell on e-bay. I am going to the grocery store tomorrow to buy them out of frozen breaded popcorn shrimp!! Wish me luck!!!
rayhuang is offline
Old 03-01-2005, 12:59 AM
  #1057
SCML's Avatar
Default Page 4 will not do
Hey Steve,
Got any good tips for the soon to be released JRX-S? Car looks very interesting, but it seems spring rates, sway bars and and the like will be far different than the current cars out.
SCML is offline
Old 03-01-2005, 09:34 AM
  #1058
The Evicerator
I agree, page 4 stinks!
As far as setup tips go, all I can recommend is to get an assortment of springs/sway bars when the car comes out...
Over the last week I have been running 25lb springs in the front w/ a .055" sway bar and 17.5 springs in the back...before that I was running 35 lb in the front with an 0.037 sway bar and 20lbs in the back with a 0.037 sway bar....
I *think* the losi sway bars that are going to come out will be 0.030", 0.040", 0.050", and 0.060"... but I'm not positive
I also recommend buying yourself a set of piston drill bits... being as that we have done alot of experiementation with different dampening and in my opinion it is very important to how the car works.
I think once you get a few of the essential/odd things out of the way the car will not be that difficult to work with... the numbers will just be different... instead of using 15lb - 17lb springs like everyone else you might run stififer... no big deal
Old 03-01-2005, 11:21 AM
  #1059
SCML's Avatar
Thanks, you guys have it working great so far, so I'm sure it will be quick out of the box. I really like the departure from every other basic design.
Do you find you are using smaller hole pistons, and/or heavier oil with the short arms and stiffer springs? I've seen setups for other cars that range from 30wt to 70wt (same car). I usually run lower weight oil, and it seems to work ok for me in stock.
The sway bar setup had me confused at first when I saw the pictures of the JRX-S. Interesting way of doing it, pretty unique.
I just got a 415 to use for the Tamiya races, so I won't be getting a JRX-S in the first run, but hopefully it won't be long after release.
SCML is offline
Old 03-01-2005, 12:37 PM
  #1060
The Evicerator
I have been running relatively lighter (30-40 wt) oil with smaller pistons...with the aforementioned stiffer springs
Old 03-03-2005, 01:16 PM
  #1061
dstyles's Avatar
what exactly does adding washers under the camber link ball stud do?
thanks
dstyles is offline
Old 03-03-2005, 01:26 PM
  #1062
Registered User
why is steve sooo coooooool
ITS A TAMIYA!!!
v2_drag is offline
Old 03-03-2005, 01:56 PM
  #1063
The Evicerator
dstyles: depends on if it is at the wheel or on the chassis...
at the wheel will give you more cambergain which will make the care feel softer in roll generally... generally more consistant side bite
at the chassis it will have the opposite effect: less camber gain...stiffer in roll....more abrupt loss of traction
Old 03-03-2005, 04:27 PM
  #1064
The Evicerator
Btw, I thought I'd let everyone know that chicks really confuse me sometimes!
Old 03-03-2005, 05:34 PM
  #1065
Jon Kerr's Avatar
Trader Rating: 17 (100%+)
They confuse all of us.
Jon Kerr is offline
