Old 07-25-2009, 08:28 AM   #6946
The Evicerator
Originally Posted by ittjv View Post
Hi Steve,
Could you share with us what the timing range is on the new spec ballistic motors? Is it 20 - 40 like on the SS series?
Thanks!
The Ballistic Spec motors have infinately adjustable timing... we do not recommend using the full range of adjustability though. There is a label on the motor with an adjustment range that is recommended.
It's approximately 10-45/50 degrees if I remember correctly... I can double check it next week.
Originally Posted by bigkoitat View Post
Wassup Steve,
Was cool meeting you at Pound It Paints Race. A group of us are heading up to WCRC tomorrow, I was going to try the Jaco Blues and MM Sweep 36's too. Since I got my Xray's quite a few drivers switched to the 009, awsome piece of machinery. I have'nt ran there and was wondering how the traction is at WCRC? I'm sure it's HIGH bite and was wondering what set-up would work in comparison to other set-ups on Xrayonline.com? I'm sure once I drive on the track I can make the proper adjustments, but would be nice to have a basic set-up to start from.
Thank You - Jaws
Hey Jaws,
I haven't run at WCRC as much as I would like, but I am honing in on a good setup... it's not too far off so far from my standard setup that I run with the exception of a stiffer front spring.
I will be there all day today so feel free to hit me up with any questions you may have!
Steve Weiss
TEAM ASSOCIATED -- REEDY -- SANWA -- PROTOFORM -- 1UP Racing -- ActivRC -- P1 BRAND -- TEAM KINWALD -- TEAM STEVE INTERNATIONAL
Steve Weiss is offline   Reply With Quote
Old 07-25-2009, 09:26 AM   #6947
bigkoitat's Avatar
Trader Rating: 6 (88%+)
Cool Thanks you Steve, see you this afternoon
JAWS
TRF-416WE & 416-X / DHW / TEAMRCR.NET
bigkoitat is offline   Reply With Quote
Old 08-09-2009, 10:44 PM   #6948
Danny-b23's Avatar
What problem with a motor would cause the fets to blow up on a GTB right when you turned it on?
Thanks,
Danny
RC America|XRAY|ORCA|Motiv|EA Motorsports
Danny Buck
WCICS Rep - Round 1, Saskatoon, SK
Danny-b23 is offline   Reply With Quote
Old 08-10-2009, 11:20 AM   #6949
JamesArluck's Avatar
Trader Rating: 52 (100%+)
Send a message via AIM to JamesArluck
Hey Steve,
Have the Ballistic Spec motors been sent to ROAR for approval yet?
I saw your car running at West Coast R/C on Sat. night and it was very impressive. What gearing and timing were you running on your 13.5?
-James
JamesArluck is offline   Reply With Quote
Old 08-10-2009, 11:31 AM   #6950
The Evicerator
Thanks,
Danny
Danny,
If the motor was completely shorted out and you tried to apply throttle over and over again I could see it possibly causing a problem with the ESC fets like that, but that's what the Locked Rotor protection is for.
There is a chance that the system was simply just run too hot in a previous run and that caused some sort of damage... or reverse voltage input to the ESC can cause damage like that as well.
Originally Posted by JamesArluck View Post
Hey Steve,
-James
Hey James,
We sent them to ROAR quite a bit ago... still waiting to hear from them??
Thanks for the compliments!
We were fooling around with gearing and timing most of the night, but I ran between 5.56 and 5.76 with the timing set to the maximum on the label.
The gearing and timing are of course always subjective and it really depends on what ESC you are using.
I assume you're using an SPX or Tekin... something with a ton of timing advance... in which case I'd start out much more conservatively with the motor's static timing. I would start out with 5.5 or so and try advancing the timing a half a tick mark at a time until you get to the right balance between speed and temperature.
My motor was coming off around 150-155 most of the night and we recommend keeping motor temps under 160 for the best performance and motor life.
Steve Weiss
Old 08-10-2009, 12:13 PM   #6951
trdsupra88's Avatar
Trader Rating: 25 (100%+)
Send a message via Yahoo to trdsupra88
Hey steve, I have a non-electronics question, Ive seen you answer some similar questions, Ive been struggling with my car with Sorex tires and recently tried a set of Jacos and turned the handling around. Should I avoid Sorex's even though everyone else at my track is running them? I am running a TC5, rubber on asphault, stock motor on a small track. Thanks for any advice, Joe.
I cut my own hair ☆
trdsupra88 is offline   Reply With Quote
Old 08-10-2009, 01:05 PM   #6952
Danny-b23's Avatar
The thing is, throttle was never applied.
I took my car out of my case, turned it on, had steering but no drive.
Then I rebound it with my radio, same thing, steering but no drive. I then wondered if the ESC was even getting power so I turned it on it's side to check for the lights, turned the power on, and there was no lights, a high pitched whine, the positive lead on the capacitor burnt out, and a bit of smoke came from the speed control.
I decided to try it again later to see if it was just a freak accident. More smoke, more high pitched whine. Also tried the same motor that I had on when I blew this one up on another, just to see if it was the motor that caused it. The same thing happened.
I never ran a mod motor on these ESC's and they never got above 115F. I also run deans plugs so no chance of mixing up plugs.
Danny Buck
Old 08-10-2009, 01:29 PM   #6953
HB Moose's Avatar
Steve. Are you going to be the Novak rep at IIC this year? Anyone else from team Orange going?
Bruce "Moose" Riedinger
HB Moose is offline   Reply With Quote
Old 08-10-2009, 06:38 PM   #6954
chrisfrom619's Avatar
Send a message via Yahoo to chrisfrom619
Hi Steve,
I know I've been asking a lot of question for my friends. This question is about the lipo cut off for the XL-5 blue case, Is this problem have been resolved yet? Can I install the lipo cut off power wires directly to the XL-5 power wires and would this work?
#1 Sponsor: Wifey
Hpi baja, traxxas e-maxx,slash, AE TC5R, RC18R,SC10, Thunder Tiger EB4 S2, and Futaba 4pk
DHW Raceway San Diego CA.
Novice Class
chrisfrom619 is offline   Reply With Quote
Old 08-11-2009, 09:46 AM   #6955
The Evicerator
Well at the end of the day you need to do what you feel most comfortable with. There are some tracks were Jacos will be the better tire, and some tracks where sorex will be the better tires.
If you have exhausted your setup knowledge with trying to get the sorex tires to work then just run the Jacos if they seem to work for you.
I'm sorry to hear about that...was the battery ever plugged into the ESC with the power off for a significant period of time...? Sometimes damage can occur when the battery is left plugged in and the steering servo gets moved around inadvertantly (for instance if someone turns the wheels by hand or if it gets knocked around in the back of a car during transport)
I would definately get that sent in to us to look at!
Hey Moose,
I'm really not sure what we're doing about IIC this year... still waiting to hear that myself!
Originally Posted by chrisfrom619 View Post
Hi Steve,
Hi Chris,
We have not found a solution for this problem yet. It seems that the XL-5 is not compatible with our unit (which we have not experienced any problems with other brand's ESCs)
Steve Weiss
Old 08-11-2009, 10:29 AM   #6956
Hebiki's Avatar
Trader Rating: 26 (100%+)
Default Race for a Cause...
Steve,
will you be able to attend the Race for a Cause charity race at West Coast R/C on Saturday, Oct. 10th?
Link for more info is in my signature.
We'll have a mod class
- Chris
Hebiki Design Works
Custom R/C Vinyl Graphics & Apparel: Your gear, your way!
Web Design - Web Development - Logo Design - Graphic Design
www.facebook.com/HebikiDesignWorks
Hebiki is offline   Reply With Quote
Old 08-27-2009, 11:45 AM   #6957
HB Moose's Avatar
Steve, what is this thread doing on page 7. You're being ignored.
Old 08-27-2009, 12:07 PM   #6958
bkspeedo's Avatar
Steve,
I search this thread and could not find an answer to this question.
What is the static timing on the SS BL motors?
Brent Klingforth
Sponsors: Awesomatix USA ~ Roche USA ~ ORCA ~ AVID Bearings ~ R1 Wurks
TQ Wire ~ Montech ~ WTF ~ BSR Racing Tires ~ 2mm Design ~ Helix Designs
5280 Raceway
MILE HIGH INDOOR CHAMPS April 19-22nd 2018 @ www.milehighindoorchamps.com
bkspeedo is offline   Reply With Quote
Old 08-27-2009, 12:13 PM   #6959
The Evicerator
The timing we set the motors to is approximately 30 degrees.
Steve Weiss
Old 08-27-2009, 01:07 PM   #6960
tfrahm's Avatar
Send a message via AIM to tfrahm
He was busy for a while over on the 'Ballistic Spec' thread... LOVE the new motors!
"If you cannot win, make the one ahead of you break the record."
Biff Racing Team #420 (Ah... The "good old days"...)
The local indoor Offroad Track: The RC Race Barn
TLR22-3.0, TLR22T-2.0, TLR22SCT-1.0
tfrahm is offline   Reply With Quote
STUFF FOR SALE """"LQQK """" EZRC R/C Items: For Sale/Trade 1 03-13-2007 07:20 PM
"""NEW""" Collari .21 3 port buggy motor lc21-b3 goneRVing R/C Items: For Sale/Trade 7 12-20-2006 06:25 PM
STUFF FOR SALE """"LQQK """" EZRC R/C Items: For Sale/Trade 11 10-22-2006 09:49 PM
""" XRAY FK05 """ excellent cond/super clean/stock evostyle R/C Items: For Sale/Trade 9 06-29-2006 10:04 PM
Let's send Steve Weiss (Evicerator) to Cleveland!!! TeamButter Electric On-Road 8 11-02-2004 11:32 PM
