Old 01-23-2009, 01:34 PM   #6691
The Evicerator
Go to our shopatron site and you should be able to get it there!
http://www.shopatron.com/product/par...21.26354.0.0.0
Originally Posted by Syber Serulean View Post
steveeeeee. I have a fifty dollar visa gift card and i want to use towards a purchase of an RMF XBR (or a non SS GTB if they become available again soon). How would i go about doing this if its even possible?
Steve Weiss
TEAM ASSOCIATED -- REEDY -- SANWA -- PROTOFORM -- 1UP Racing -- ActivRC -- P1 BRAND -- TEAM KINWALD -- TEAM STEVE INTERNATIONAL
Steve Weiss is offline   Reply With Quote
Old 01-23-2009, 03:41 PM   #6692
Syber Serulean's Avatar
Trader Rating: 28 (100%+)
Send a message via AIM to Syber Serulean
well i've bought from there before but what im trying to say is i dont think i can use it online, it doesnt even have my name on it. It says "gift recipient."
I wouldnt know how to enter that to pay online with it if its even possible o_O
Ive bought stuff online with it before but it was ordered on will call and i went down to the hobby site's warehouse office and they have a POS terminal there they can charge it to (they had to type the card number in, they dont slide it. Some kind of virtual terminal i think). But i dont think will-call is available for novak?
Syber Serulean is offline   Reply With Quote
Old 01-30-2009, 06:56 PM   #6693
my god......page 6 we can1`t be having this....TTT
srp67 is offline   Reply With Quote
Old 01-30-2009, 07:02 PM   #6694
The Evicerator
Thanks SRP!
I have been out of town at the Snowbirds all this week and only been able to check in sporadically...I was afraid there were a bunch of questions that have gone un-attended to!
Steve Weiss
Old 01-30-2009, 07:13 PM   #6695
I seen on the race results that you where at the birds and seem to be doing pretty good...I do have a question if you have the time. In either your thread or the Novak thread i remember seeing 3 pictures of the back of a Novak motor showing the different settings for the timing adjustments, I can not seem to locate them again. I have recently switched to brushless and trying to get the most out of them...I am running 17.5 and any help would be great. Good luck at the Snowbirds.
Steve P.
Old 01-30-2009, 07:17 PM   #6696
The Evicerator
Thanks for the well-wishes!
I don't have those pictures saved anywhere on this laptop or else I would re-post them here for you.
But the crux of it is that the slotted timing ring on the back of the motor can be turned one way or the other a fixed amount... When the ring is rotated counter-clockwise, the timing is advanced; when the ring is rotated clockwise the timing is reduced.
Most of the time we recommend people to leave the stock timing but it seems more often than not people advance the timing fully. When this is done heating and rpm are increased... please note that when the timing is advanced the gearing needs to be reduced!
Steve Weiss
Old 01-30-2009, 07:23 PM   #6697
Thanks for the quick reply I will play with it this weekend. I will post middle of next week when you make it back home and maybe you can post the pictures again.
Steve P.
Old 01-31-2009, 12:53 AM   #6698
cyclone speed's Avatar
Hi Steve ,
I curently own a GM 6t delta motor ( brushless wich is aparently = to a 3t ) and i would like to know if i can use it with my GTB , i have had it for 2 days ( the 6t GM motor ) and i would like to know if i can use it with my GTB .
Another question , if i reduce the Min.drive on my GTB , ( from 4 to 2 ) will it increase my runtime or not ?
Thanks Steve
cyclone speed is offline   Reply With Quote
Old 01-31-2009, 06:45 AM   #6699
The Evicerator
Hi Cyclone,
I have never run a GM 6T delta but we have made our own 6T delta wind motors here to test and we have found that they pull quite a bit more current than their "equivalent" wye wind counterparts.
I wouldn't recommend trying it unless you are running 5 cells and have plenty of gearing experience.
i just think the current draw will be quite high.
If you reduce the min drive you will probably feel a pretty big difference in bottom end response... but as far as significantl increasing your run time I honestly couldn't tell you. Theoretically it should but I can't give you some quantifiable number.
Originally Posted by cyclone speed View Post
Hi Steve ,
Thanks Steve
Steve Weiss
Old 01-31-2009, 07:20 AM   #6700
Originally Posted by Steve Weiss View Post
Hi Cyclone,
Ok , i do run 5 cell and some GM people told me the proper gearing and i will be carfull , on the instruction manual of the gm motor , they say that the amp draw was of 90A @ 7.2 v and at max power , so i dont know if it will be enough runtime .
Old 01-31-2009, 10:03 AM   #6701
GM Pro's, these new motors ought to have extremely high performance and high efficiency - we NEED YOU to test your GM 6T delta out and report your experience on the forum.
I posted my car's motor, pinion, spur, and battery setup at
rcgearing.com
gini@BentKneeRC is offline   Reply With Quote
Old 01-31-2009, 10:08 AM   #6702
Well , i will run the motor next sunday but hinestly i am not so experienced with motors , i will tel you what i think of it next week .
Old 02-02-2009, 09:42 AM   #6703
I'll rescue this thread from page 3.
Steve - does the novak speed control program cover completely fried GTB ESCs? In other words, can I send in the one I fried this weekend, pay the $69 and get a replacement? Why it blew up, I have no idea but I am not dwelling on that. The replacement I pulled out of my sedan worked perfectly.
Tony Vega is offline   Reply With Quote
Old 02-02-2009, 12:17 PM   #6704
Trader Rating: 26 (100%+)
Default Gearing
Finally got a set of Pinions for a TC5R with GTB/13.5/Orion 3800 2s. Currently installed 78/33 which would be 4.73. I have the GTB set on the factory settings. It seems sluggish. If it is the gearing, which direction should I head with the pinions? Higher or lower? Currently I have 28 thru 34.
svines1972 is offline   Reply With Quote
Old 02-03-2009, 06:59 AM   #6705
Trader Rating: 1 (67%+)
Happy B-day
Just for the record.......yes that is old
Josh Hohnstein is offline   Reply With Quote
STUFF FOR SALE """"LQQK """" EZRC R/C Items: For Sale/Trade 1 03-13-2007 07:20 PM
"""NEW""" Collari .21 3 port buggy motor lc21-b3 goneRVing R/C Items: For Sale/Trade 7 12-20-2006 06:25 PM
STUFF FOR SALE """"LQQK """" EZRC R/C Items: For Sale/Trade 11 10-22-2006 09:49 PM
""" XRAY FK05 """ excellent cond/super clean/stock evostyle R/C Items: For Sale/Trade 9 06-29-2006 10:04 PM
Let's send Steve Weiss (Evicerator) to Cleveland!!! TeamButter Electric On-Road 8 11-02-2004 11:32 PM
