Old 01-12-2009, 10:14 AM   #6661
The Evicerator
Not really... there are those that will do anything for a little bit of attention or exposure... I'm not really one of them
Should be a good interview though!
Originally Posted by Unregistered View Post
Steve
Are you dissapointed that they chose to interview Tommy VuTong in the first issue of Radio Control Babes instead of you?
I mean really, Tommy freaking VuTong?
Mike,
Sounds good! I might be able to make it!
Originally Posted by King of B Main View Post
Steve,
Race day is Jan 24,and 25th should be fun.....They have more info about the race on nitro onroad thread....Hope to see you there.
Steve Weiss
TEAM ASSOCIATED -- REEDY -- SANWA -- PROTOFORM -- 1UP Racing -- ActivRC -- P1 BRAND -- TEAM KINWALD -- TEAM STEVE INTERNATIONAL
Steve Weiss is offline   Reply With Quote
Old 01-12-2009, 10:38 AM   #6662
trdsupra88's Avatar
Trader Rating: 25 (100%+)
Send a message via Yahoo to trdsupra88
Originally Posted by Steve Weiss View Post
Yeah, pretty much. Due to the fact I work at Novak Electronics most of the questions anymore are related to our products ... but feel free to ask anything you'd like... I usually do my best to give you an entertaining if not informative answer at least!
Sounds good, With a new touring car, should I set the camber and toe at 0 for a starting point or rummage through the factory drivers set-up sheets and average those out? Ill be running a TC5 with a GTX, 27t, rubber on asphault on a very small Hobbytown track(7-9 second laps).
I cut my own hair ☆
trdsupra88 is offline   Reply With Quote
Old 01-14-2009, 05:09 AM   #6663
Professor's Avatar
Default lipo cut off
hi steve
this may have been asked before but i will ask anyway,can u tell me if the gtb b/l speedy has an inbuilt lipo voltage cut off & if so what it is & can it be adjusted up or down ?
thanx graham
VBC RACING AUS--HOBBYWING--RC MAKER--
MAD GRAPHICS--BITTY DESIGN
Professor is offline   Reply With Quote
Old 01-14-2009, 01:41 PM   #6664
The Evicerator
I usually run 1.5 or 2 degrees of camber front and rear... depending on how the car is handling.
0 toe out in the front is a good starting point... I usually run just a tick of toe out ... 0.5 degrees.
Hope this helps!
Graham,
The newer GTBs/SS GTBs all have internal lipo cut off. The cut off is fixed however at 6.25 V.
The easiest way to tell if your GTB has the cut off or not is to check the programming. With everything on, press and hold the button down until you see red and amber light up together, this is the color code for the lipo cut off. One blink denotes the cut feature is off, two blinks denotes the feature is on.
Hope this helps!
Originally Posted by Professor View Post
hi steve
thanx graham
Steve Weiss
Old 01-14-2009, 02:08 PM   #6665
Professor's Avatar
Default gtb
hi steve
thanxs for the info on the gtb cut off helps me out a lot
graham
Old 01-14-2009, 02:14 PM   #6666
trdsupra88's Avatar
Thanks, we start racing in March so I will figure it out before then...
I cut my own hair ☆
Old 01-14-2009, 02:46 PM   #6667
STLNLST's Avatar
Trader Rating: 21 (100%+)
What up Steve.......how ya been bro?
STLNLST is offline   Reply With Quote
Old 01-17-2009, 06:35 PM   #6668
Hi Steve, i've just crossed to the orange side and got myself a GTB 1710-L after reading countless threads about the dreaded magic smoke i found this one. The esc i've bought is a factory remanufacured product and i'm wondering if i should have a diode on the rx cable as i don't or has the fix been done internally now?
Regards Paul.
BILKO1 is offline   Reply With Quote
Old 01-17-2009, 11:08 PM   #6669
racer x 1's Avatar
Trader Rating: 27 (100%+)
Dumb question is it safe to run any brand brushless motor with my GTB?
Matt Bell
Mugen MRX5 Ae R5.2 X6^3 M11x All powered by Speedtech Rc
racer x 1 is offline   Reply With Quote
Old 01-18-2009, 11:12 AM   #6670
The Evicerator
Regards Paul.
I am fairly certain that all the latest remanufactured ESCs have the internal fix now, but I will have to recheck once back at work this week.
You should be able to run any sensored brushless motor with your GTB... I would pay attention to what wind you use with how many cells... for instance, I would not recommend running someone else's 2.5 turn with a 2S lipo
I'd say anything from 3.5 and up should be fine.
Steve Weiss
Old 01-18-2009, 03:32 PM   #6671
Thanks for the response Steve, if it is internal as i suspect could you find out if there is a way to be 100% sure please? Maybe the number on the barcode or the way the componants are laid out that you can see through the bottom cover.
Regards Paul.
Old 01-18-2009, 04:04 PM   #6672
Adam?'s Avatar
It's good to know that even with all these fancy new motors coming out, I can still throw in my trusty old Novak 13.5 and it'll run right with them, or even be .1 faster. And, imagine that, you can even buy replacement rotors for them!
The only thing you guys are missing is a "bling" series with more easily adjustable timing and some sexy new looks. :-)
Adam? is offline   Reply With Quote
Old 01-19-2009, 09:42 AM   #6673
The Evicerator
Bilko,
Just PM me the serial number on your ESC and I should be able to figure out if it has it or not.
Regards Paul.
Thanks for the compliments Adam! We're very proud of our motors! And don't worry...we never stop working around here
Steve Weiss
Old 01-20-2009, 11:23 AM   #6674
rcterp's Avatar
Trader Rating: 35 (100%+)
Power Cap question - I believe the XBR used a smaller power cap. Would it be effective to use the smaller power cap on the GTB only running a 1s (3.7v) lipo with a 13.5 motor?
Φ
Glitter Lidz - "My driving doesn't shine but my lid does!!"
rcterp is offline   Reply With Quote
Old 01-20-2009, 11:43 AM   #6675
stitchy's Avatar
Default yellow ring
Hi Steve,
The new TCS rules for GT2 stipulate that we need a yellow ringed 17.5. I have the old 17.5 with a black ring.
Without buying a new motor just to get the yellow ring, is there an easier way?
Thanks!
Speedtechhobbies.com
stitchy is offline   Reply With Quote
STUFF FOR SALE """"LQQK """" EZRC R/C Items: For Sale/Trade 1 03-13-2007 07:20 PM
"""NEW""" Collari .21 3 port buggy motor lc21-b3 goneRVing R/C Items: For Sale/Trade 7 12-20-2006 06:25 PM
STUFF FOR SALE """"LQQK """" EZRC R/C Items: For Sale/Trade 11 10-22-2006 09:49 PM
""" XRAY FK05 """ excellent cond/super clean/stock evostyle R/C Items: For Sale/Trade 9 06-29-2006 10:04 PM
Let's send Steve Weiss (Evicerator) to Cleveland!!! TeamButter Electric On-Road 8 11-02-2004 11:32 PM
