Old 09-25-2008, 11:09 AM   #6511
Hi Steve, Your not done yet sir LOL! I am a long time fan of Novak products and have had good luck with them. Recently Traxxas has come out with the waterproof ESC's & such and I was wondering if Novak was going to offer any waterproof versions of your ESC's. I want to set up a truck to run this winter on ice/snow and want to have a "factory" setup rather than a cobbled up deal with ballons/sealer around everything. I don't want to have to buy someone else's stuff if Novak has a brushless waterproof lipo capable ESC. Thanks.
monsterbft is offline   Reply With Quote
Old 09-25-2008, 11:33 AM   #6512
The Evicerator
I will pass your comments along down the chain of command! We have discussed it quite a bit and we have been always moving towards this sort of goal.
Most of our ESCs now are what we call "water resistant" ... with some gasketing to help keep them "splash proof"
Steve Weiss
TEAM ASSOCIATED -- REEDY -- SANWA -- PROTOFORM -- 1UP Racing -- ActivRC -- P1 BRAND -- TEAM KINWALD -- TEAM STEVE INTERNATIONAL
Steve Weiss is offline   Reply With Quote
Old 09-28-2008, 01:11 AM   #6513
s13evo's Avatar
Default Loose orange wire
Help, can anyone show me how to get the orange wire back onto the white tab.
<a href="http://s216.photobucket.com/albums/cc100/S13evo/?action=view&current=Image005.jpg" target="_blank"><img src="http://i216.photobucket.com/albums/cc100/S13evo/Image005.jpg" border="0" alt="Photobucket"></a>
s13evo is offline   Reply With Quote
Old 09-28-2008, 05:29 PM   #6514
The Evicerator
Your best course of action is to send it in to us to repair/replace.
It would be possible for you to pry up the white tab and remove the connector socket and try to reinsert the wire into the socket, and using a tiny little bit of solder you might be able to fix it yourself.... but this might prove difficult considering the soldering aspect.
Steve Weiss
Old 09-29-2008, 03:05 PM   #6515
Dan the Man's Avatar
Trader Rating: 40 (100%+)
I want to change the wiring on my GTX, just wondering what temperature to set my soldering station to in order to NOT damage it
|-ē-|Hot Bodies Pro 5|-●-|The "F109X"|-ē-|
If you don't have clean bearings, good transmission and a perfect car, trust me when I say this...someone else does.
Dan the Man is offline   Reply With Quote
Old 09-29-2008, 03:42 PM   #6516
The Evicerator
Dan,
I usually set my iron for 800 F. Bare in mind that you need to use a good medium sized tip to have effetive heat transfer!
The trick is to pre-tin things...make sure that you add a little solder to the tip to help aid in heat transfer as well!
Don't leave the iron on anything in particular for too long either!
Steve Weiss
Old 10-02-2008, 01:28 AM   #6517
edwintklee's Avatar
Trader Rating: 23 (96%+)
Originally Posted by Steve Weiss View Post
Dan,
good advise.....i always do like that too....
but i am only using hakko trigger type soldering gun, pre heat it, just tab not more than 10 sec, after solder, please cool down the esc.
I am a Red Star, Blue Star, Fans......
edwintklee is offline   Reply With Quote
Old 10-02-2008, 09:37 AM   #6518
minimusprime's Avatar
Trader Rating: 19 (100%+)
Steve,
I've got a 13.5ss I run at bcr. I recently picked up a 13mm rotor for it to help with handling heat on the extreme heat days. Typically I run a 4.3-4.5 final ratio. How will my gearing have to change to accomodate for the new rotor?
"I personally do not believe in luck. I believe luck is just an excuse for people that have failed in their mission to accomplish something." Allen McNish
minimusprime is offline   Reply With Quote
Old 10-02-2008, 11:43 AM   #6519
The Evicerator
Usually when I go to a 13 mm rotor I gear up 2 teeth on the pinion.
I would start there and see how it goes.
Originally Posted by minimusprime View Post
Steve,
Steve Weiss
Old 10-04-2008, 03:19 AM   #6520
Hey Steve
Have had problems emailing you and tech at Novak so im trying my luck here, hope you can help me.
I have a "old" Novak SS5800 system and Im wondering if I could hook up a 17,5SS PRO motor to the old SS ESC?
Thanks in advance
/Fredrik
Heimdal is offline   Reply With Quote
Old 10-04-2008, 07:27 PM   #6521
nunga's Avatar
Default half dead motor
Hi Steve,
Can you help please.
I have the novak GTB brushless system with the 13.5 motor. I ran one race meet with no dramas, Now, itís the second meet, and today didnít even get started. The motor wonít start unless pushed. It seems to have a dead spot. Rotate the motor 60 deg it will start no worries and 120 deg same. Back to original position and no go. When it will go, it stutters, like a car with one cylinder out, rough. This is my first novak product and its not off to a good start.
Thanks.
nunga is offline   Reply With Quote
Old 10-04-2008, 08:14 PM   #6522
The Evicerator
Heimdal,
Sorry about the email problems!
Your Super Sport ESC shouldn't have any problems running the 17.5 pro motor!
Originally Posted by Heimdal View Post
Hey Steve
Thanks in advance
/Fredrik
Nunga,
Have you tried another motor with your ESC? The reason I ask is because It would help narrow down whether the problem is with the ESC or the motor itself!
Double check the sensor harness and make sure it's fully plugged into the ESC.
Also make sure that the motor phase wires are wired in correctly and not shorted out by mistake.
Originally Posted by nunga View Post
Hi Steve,
Thanks.
Steve Weiss
Old 10-05-2008, 01:20 AM   #6523
Sweet, many thanks Steve!
Old 10-05-2008, 02:36 PM   #6524
nunga's Avatar
Thanks steve,
The sensor plug is ok, but i don't have a spare motor,now. There is one on its way but I won't see it for a week or so.
will get back to you when it arrives.
Cheers.
Old 10-05-2008, 02:38 PM   #6525
nunga's Avatar
Heimdal,
Nunga,
oops.
Thanks steve,
Cheers.
STUFF FOR SALE """"LQQK """" EZRC R/C Items: For Sale/Trade 1 03-13-2007 07:20 PM
"""NEW""" Collari .21 3 port buggy motor lc21-b3 goneRVing R/C Items: For Sale/Trade 7 12-20-2006 06:25 PM
STUFF FOR SALE """"LQQK """" EZRC R/C Items: For Sale/Trade 11 10-22-2006 09:49 PM
""" XRAY FK05 """ excellent cond/super clean/stock evostyle R/C Items: For Sale/Trade 9 06-29-2006 10:04 PM
Let's send Steve Weiss (Evicerator) to Cleveland!!! TeamButter Electric On-Road 8 11-02-2004 11:32 PM
