Old 08-05-2008, 10:47 PM   #6406
chris moore's Avatar
Trader Rating: 88 (99%+)
Hi Steve, question for you, like you could'nt have guessed that. Tonight I was setting up my touring car with the GTB from one of my trucks, it is the spread spektrum, lipo cuttoff one. I had everything set and powered up the system, for some reason there were no lights on the side of the unit and the esc got hot real quick. So I unhooked the motor, both the sensor harnes and the three wires and powered up the esc again to do the one-touch program just in case for some reason it had switched to brushed mode (no reason for that to happen I have'nt run a brushed motor in two yrs). I had just finished the one-touch progam when poof out came the magic smoke. I'll package it up and send it in tomorrow but I don't have the receipt, checked already, any idea on what might have happened? And any thoughts on how much it'll cost? I'm also thinking of sending in the motor to be checked just in case that was the problem.
Chris
Sponsered by:
CMDezigns Paint Works
https://www.facebook.com/pages/CM-Dezigns/259989190822177?ref=hl
chris moore is offline   Reply With Quote
Old 08-05-2008, 10:55 PM   #6407
mdttb's Avatar
Originally Posted by Swamp Rat View Post
Where should the Temp be taken ????
The Rat
From one of Steve's other post in this thread:
In regards to temping the motor I usually do one of a number of things:
Temp the black end cap/end screw... while this might not be the absolute hottest part of the motor it is often times very consistant.
The purple/black/blue band on the motor is generally another decent spot to temp as well. Like some mentioned if the ring is loose then the readings you will get will not be consistant.
Someone mentioned putting sharpie on your motor endbell to give it some color for the IR temp guages to work properly... this or a small sticker will work to get a better readings as well.
mdttb is offline   Reply With Quote
Old 08-05-2008, 11:13 PM   #6408
The Evicerator
Hey Chris,
It's hard to say what happened to your GTB... there's always a chance that if you did some soldering or wiring something might have been misconnected or inadvertantly shorted.
Also, if you had a battery connected while the ESC is off and you turned the wheels of your car you might have caused some damage as well...we have a new input harness and the new ESCs have a revision to protect against this type of damage.
If the ESC is out of warrantee the replacement cost is $69 for the lipo GTB.
Sending the motor in for a checkup is always good too!
Chris
Steve Weiss
TEAM ASSOCIATED -- REEDY -- SANWA -- PROTOFORM -- 1UP Racing -- ActivRC -- P1 BRAND -- TEAM KINWALD -- TEAM STEVE INTERNATIONAL
Steve Weiss is offline   Reply With Quote
Old 08-05-2008, 11:17 PM   #6409
Originally Posted by Steve Weiss View Post
Hey Chris,
Nope I allways connect the battery last right before I turn on the system so thats not it. I went back through my steps to see if I could find anyting, but I'm sure I did everything right.
Sponsered by:
Old 08-08-2008, 09:20 AM   #6410
J@UNE's Avatar
Hi Steve,
I have a ex13.5 motor updated with sintered rotor. I know the EX isn't listed on the roar aprouved motor but internally, is that motor the same as an 13.5ss?
Thanks in advance!
Jon
J@UNE is offline   Reply With Quote
Old 08-08-2008, 09:40 AM   #6411
The Evicerator
Jon,
Internally everything is identical!
The only differences are the gold sleeve, bonded rotor, small-bearing, and ribbed endbells. Change out the endbell and the rotor and you've basically got yourself a Pro!
Originally Posted by [email protected] View Post
Hi Steve,
Thanks in advance!
Jon
Steve Weiss
Old 08-10-2008, 12:38 AM   #6412
Drewdc90's Avatar
Hey Steve just a question regards rollout for a 17.5. I usually run a monster stock around 33mm rollout for a large track. Whats a good starting point for my 17.5 with heatsink? Some of the other 17.5's LRP are around 58mm rollout, but I want to be conservative to start with and work my way up without doing damage. I know to gear by temp but want to check a good start point.
Thanks Drew
-Xray--Nosram--Orion--Trak Power--Duratrax--Spektrum--Futaba-
Sunshine Coast QLD AUSTRALIA
"If you stand still long enough you'll go backwards"
Drewdc90 is offline   Reply With Quote
Old 08-11-2008, 12:40 PM   #6413
The Evicerator
Hey Drew,
Sorry about the delay in answering you!
I really don't have any experience or feedback from people running 17.5 on asphalt with foam tires ( I assume this is what you are running ... I know foam tires on asphalt is pretty popular down under)
But when I was crunching some numbers I thought I'd start out around 51 mm rollout... but it's hard to say how that stacks up compared to what the LRPs are running... I know some of those guys are running 14 mm sintered rotors in their motors...and that is going to dramatically change the gearing that the motor needs.
I would recommend running a shorter ratio and seeing how it fares for a few laps...bring it in, check the temp, and gear up a couple teeth a time.
Steve Weiss
Old 08-11-2008, 07:53 PM   #6414
tpczx6's Avatar
Steve
are we going to see you in Vegas????
RcAmerica--Xray---Hudy----KO PROPO USA---ORCA---GRAVITY RC
Motiv------Apexrc----- AVID
SWEEP Racing USA
Mike's Hobbyshop in Dallas (RIP)
Nor-Cal Hobbies [The Race Place]
tpczx6 is offline   Reply With Quote
Old 08-12-2008, 07:21 AM   #6415
Skitee's Avatar
Hi Steve,
We're starting to test 13.5 brushless as an option to run together with 19turn brushed as per the current ROAR rules. Have you done this kind of head to head testing with the 13.5SS motors and 19turn brushed motors ? How close did you get the times ? What ended up quicker and by how much ?
Xray T4 2018 ~ HobbyWing Xerun XR10 Pro ~ Motiv RC 4.5
Xray X12 2018 ~ ORCA Vritra VX3 1S ~ Speedzone 4.5
POWERED BY SPEEDZONE USA
Skitee is offline   Reply With Quote
Old 08-12-2008, 08:57 AM   #6416
The Evicerator
Skitee,
Most people will say that the 13.5 brushless will have more torque/acceleration than the brushed 19T... but the brushed 19T might have more "free flowing rpm" ... they both get around the track a little differently from one another...but usually they are pretty close on times
Originally Posted by Skitee View Post
Hi Steve,
Steve Weiss
Old 08-12-2008, 05:36 PM   #6417
Super Moderator
Grizzbob's Avatar
Skitee,
Agreed, in some of the informal testing we've done in my neck of the woods, betwem the 13.5 & 10.5 brushless & 27, 23 & 19 turn brushed motors, it seems the closest match is the 13.5 brushless & the 23 turn brushed(at least Tamiya's 23 turn motors, they seem to have a pretty similar power curve to the 13.5, based on how the 23 turn makes power & the way they both run ontrack), while a good 19 turn can have more top end power(as well as more rpm in general), so geared properly I'd give a slight edge to the 19 turn....
Bob Seay
Tamiya TRF417, TA05v.2, TRF211XM, M-05ver.2R, XRAY X12, Associated B5m Factory Lite
Go Pokes!!!
Grizzbob is offline   Reply With Quote
Old 08-18-2008, 11:15 AM   #6418
The Evicerator
TTT
Steve Weiss
Old 08-19-2008, 05:32 AM   #6419
Mr. Shookie's Avatar
R/C Tech Charter Subscriber
Send a message via AIM to Mr. Shookie Send a message via MSN to Mr. Shookie
STEVE YOU SO FAST @ SUMMA SLAM>>>>>>WHATS YOUR SUPER TEAM STEVE SECRET FOR TOTAL DOMINANCE?!!!!!!!!!!!!!!!!!!
-Shookie <><
All who love the LORD JESUS I praise with you.1 Cor 10:31
Team HOLY Rollers (Team Manager)
The Church is a Hospital for Sinners not a Museum for Saints.
RcTech Feedback <>< RC Tech Subcriber #92
Mr. Shookie is offline   Reply With Quote
Old 08-19-2008, 05:14 PM   #6420
The Evicerator
I just don't give up!
Steve Weiss
STUFF FOR SALE """"LQQK """" EZRC R/C Items: For Sale/Trade 1 03-13-2007 07:20 PM
"""NEW""" Collari .21 3 port buggy motor lc21-b3 goneRVing R/C Items: For Sale/Trade 7 12-20-2006 06:25 PM
STUFF FOR SALE """"LQQK """" EZRC R/C Items: For Sale/Trade 11 10-22-2006 09:49 PM
""" XRAY FK05 """ excellent cond/super clean/stock evostyle R/C Items: For Sale/Trade 9 06-29-2006 10:04 PM
Let's send Steve Weiss (Evicerator) to Cleveland!!! TeamButter Electric On-Road 8 11-02-2004 11:32 PM
