Old 06-20-2008, 11:23 AM   #6301
The Evicerator
Sometimes when under heavy accelleration the voltage gets pulled down so far that it "fools" the smart stop into thinking that the battery voltage is too low... some smart stops tend to be more sensitive to this than others... if it keeps giving you problems send it on in to us.
Originally Posted by stitchy View Post
Hi Steve. I installed the 2 cell lipo cutoff in my Slash and it seemed to cause the throttle to stutter when accelerating from zero. I know it's supposed to do that when the battery is low and the LED would come on. The battery was fully charged so the LED never came on.
I was only bench testing and didn't run the car outside to see if the condition would last beyond the first few moments the car is run, but is the stuttering upon start up normal? Thanks!
Steve Weiss
TEAM ASSOCIATED -- REEDY -- SANWA -- PROTOFORM -- 1UP Racing -- ActivRC -- P1 BRAND -- TEAM KINWALD -- TEAM STEVE INTERNATIONAL
Steve Weiss is offline   Reply With Quote
Old 06-20-2008, 11:59 AM   #6302
stitchy's Avatar
In this instance, however, would the light come on?
Speedtechhobbies.com
stitchy is offline   Reply With Quote
Old 06-20-2008, 01:37 PM   #6303
The Evicerator
I believe the blue LED should only come on when the cut off has occured... the "blips" are warnings.
Steve Weiss
Old 06-20-2008, 08:41 PM   #6304
tbeardmore's Avatar
Hey All - FYI!
The 4th Annual Midwest Carpet On-Road Championships has been announced!
Hope you can make it to "The Plex"...!
http://www.rctech.net/forum/attachme...9&d=1213690177
-Todd
BMI DB10R, Corally RDX PHi, BMI 12R..!!
Need a "real" car... contact me at:
www.beardmorechevy.com -or- www.beardmoresubaru.com
tbeardmore is offline   Reply With Quote
Old 06-22-2008, 09:04 AM   #6305
Scottrik's Avatar
Trader Rating: 245 (100%+)
Oh Weiss One...
I come before you (yet again) seeking wisdom.
I am being told that a 3-cell smart stop can work for 2-cell. I pulled the Smart Stop "manual" from the Novak site and don't see any referrence to making changes, only that the 3-cell begins it's "stop" routine at 9.375v...substantially higher than my 2-cell pack will ever produce.
Help me Mr. Wizzard...
Congressmen should wear uniforms like NASCAR drivers so we can identify their corporate sponsors.
THE REVOLUTION WILL NOT BE TELEVISED -Gil Scott-Heron (1949-2011)
Scottrik is offline   Reply With Quote
Old 06-22-2008, 10:31 AM   #6306
The Evicerator
Hi Scottrik,
You can only use the 3 cell smart stop for 3S packs... for 2S packs you need the 2 cell smart stop.
Hope this clears things up for you!
Originally Posted by Scottrik View Post
Oh Weiss One...
Steve Weiss
Old 06-22-2008, 10:43 AM   #6307
Scottrik's Avatar
Excellent. That was what I was thinking after reading the instructions, but thanks much for the confirmation.
Scottrik
Old 06-23-2008, 12:46 PM   #6308
stitchy's Avatar
I tried using the cutoff in a race this past weekend with some bad results. The stutter mode would kick in right away even with smooth acceleration. During the race it kinda made my ESC an on/off switch with either 100% throttle or nothing. The light never came on.
I took it home and ran some tests. It seems when the motor would sense any kind of resistance (from transmission etc.), the lipo cutoff would go into stutter mode. (This is with a fully charged 2 cell lipo with 2 cell cutoff). When I took the motor out of the transmission letting it spin freely, it would still do this occaissionally, but much, much less. After removing the lipo cutoff, everything was back to normal, throttle was smooth.
Do I have a defective unit?
Also, does it matter which way the light plug is connected? I noticed that the servo wire would have the pins facing out, but on the light connector, if I match red to red and black to black on the opposite side of the chip, the pins on the two wire connector would face the other way. Just wondering...
Old 06-23-2008, 01:11 PM   #6309
Scottrik's Avatar
This may seem obvious, and sorry if it is, but have you programmed your Smart Stop to your tranmitter? I can see how it would be easy to miss that step in the instructions and have problems.
Old 06-23-2008, 03:11 PM   #6310
Francis M.'s Avatar
Hey Steve, I was planning on purchasing a brushless motor for a slash but noticed the Traxxas Slash comes with a 550 can. Will the standard motors work O.K. with this truck or do I need to install an HV motor?
TQ-racing Yokomo BD7 Airtronics
Francis M. is offline   Reply With Quote
Old 06-23-2008, 03:45 PM   #6311
The Evicerator
Hi Francis,
We have not received a slash yet for testing... so I can't really say for sure what would work best in it yet.
I will see what we can do about getting one and then let you know!
Steve Weiss
Old 06-23-2008, 04:02 PM   #6312
Francis M.'s Avatar
Hi Francis,
Thanks Steve, I'll see you at the summer slam....
Old 06-23-2008, 04:22 PM   #6313
stitchy's Avatar
Yeah, I programmed the Smart Stop to the transmitter, and esc to the transmitter, multiple times. Same result.
Old 06-23-2008, 04:34 PM   #6314
The Evicerator
Stitchy,
It's hard to say what's going on with your smart stop...but you can send it in to us and we can check it out for you.
Steve Weiss
Old 06-23-2008, 07:59 PM   #6315
lbckevin's Avatar
Trader Rating: 91 (99%+)
Francis,
Yes the 13.5 or 10.5 will fit in the Traxxas slash. I saw Orlando Sherman has already setup his with a 10.5.
The 550 motor will fit the same as the 540 , just a little longer.
Kevin Smith
Hobbywing * Pro-Line * MIP * Paint Monster
lbckevin is offline   Reply With Quote
STUFF FOR SALE """"LQQK """" EZRC R/C Items: For Sale/Trade 1 03-13-2007 07:20 PM
"""NEW""" Collari .21 3 port buggy motor lc21-b3 goneRVing R/C Items: For Sale/Trade 7 12-20-2006 06:25 PM
STUFF FOR SALE """"LQQK """" EZRC R/C Items: For Sale/Trade 11 10-22-2006 09:49 PM
""" XRAY FK05 """ excellent cond/super clean/stock evostyle R/C Items: For Sale/Trade 9 06-29-2006 10:04 PM
Let's send Steve Weiss (Evicerator) to Cleveland!!! TeamButter Electric On-Road 8 11-02-2004 11:32 PM
