Old 06-11-2008, 12:02 AM   #6271
The Evicerator
Chris,
It honestly depends on a number of factors, but generally I start people out much lower than that, around 5.4 and go up from there.
I would say that most will probably end up around 4.8-5.0
Steve Weiss
TEAM ASSOCIATED -- REEDY -- SANWA -- PROTOFORM -- 1UP Racing -- ActivRC -- P1 BRAND -- TEAM KINWALD -- TEAM STEVE INTERNATIONAL
Steve Weiss is offline   Reply With Quote
Old 06-11-2008, 04:22 AM   #6272
Chris08527's Avatar
Trader Rating: 16 (100%+)
thanks steve that is what i was looking for, i understand it depends on many things but i was just looking for a ballpark # to start from.
"Hello How 'bout that ride in? I guess thats why they call it Sin City." Alan Garner~"I play the drums, I'm good as hell" Richie Rich
Chris08527 is offline   Reply With Quote
Old 06-11-2008, 06:42 AM   #6273
SSS Racing's Avatar
Default GTB Lipo Cutoff
Hi Steve,
Just want to check something re my GTB SS speedy.
I've just started running lipo packs with the speedy, and have noticed that if the low voltage cutoff point is reached, its the RED and GREEN leds that flash to indicate the cutoff has cut in. Not RED and AMBER leds as per the instructions..?
Thanks,
Ryan
SSS Racing is offline   Reply With Quote
Old 06-11-2008, 08:51 AM   #6274
The Evicerator
Ryan,
I just looked over the addendum that is included with the GTB and you are correct in taht there is a mistake there.
When the cut off has activated the red and green LEDs will blink alternately.
Originally Posted by SSS Racing View Post
Hi Steve,
Thanks,
Ryan
Steve Weiss
Old 06-11-2008, 09:32 AM   #6275
J.Filipow's Avatar
Trader Rating: 15 (100%+)
HEY STEVE TYPE!!! How's your foot?
P1 Brand - "Victory is Black and White" ◢◤◢◤◢◤◢◤◢◤◢◤◢◤◢◤◢◤◢◤
RC America / XRayUSA / Hudy / Motiv / Avid / Vannen Watches
J.Filipow is offline   Reply With Quote
Old 06-11-2008, 10:22 AM   #6276
The Evicerator
Still uncomfortable... hurting less though... thanks for asking!
Steve Weiss
Old 06-11-2008, 10:43 AM   #6277
Default Novak 8.5 brushless
I have a Novak 8.5 brushless motor in my B4 Chassis with a late model body. I am using a GTB esc and using a 3600 lipo battery. I was running an 81 tooth spur with a 24 tooth pinion.
About 3-4 minutes into the race, it stopped running. It seemed very hot and started up again after sitting for a couple minutes. I assumed that I was using too big a pinion and starting using smaller pionions.
I went down the list and am now down to using a 19 tooth pinion with the same spur gear. Last night I did a practice run using the 19 tooth pinion. It still quit running after about 4 minutes. I checked the temp and it read 170-185 degrees. I am assuming that earlier it may have been even hotter. The ESC was at about 90 degrees.
According to the Novak website, I should be using a fdr of 9 with a 2 wheel drive buggy. As near as I can figure, I should have been right there with the 23 tooth pionion and a lot higher with the 19 tooth. Have I ruined the motor, or is there something else I can check. I cleaned all the dirt off of it before my latest run.
Thanks in advance for your help.
jarmuth is offline   Reply With Quote
Old 06-11-2008, 11:11 AM   #6278
The Evicerator
Jarmuth,
The gearing recomendations are good places to start, but as we note the motor temperature should always be the first peice of information used to figure out if the gearing is correct.
Does your 8.5 have a sintered or a bonded rotor in it...?
If it has a bonded rotor in it, the gearing will need to be lower...and as such the higher gearing that you started out with might have over-stressed it and caused it to demagnetize.
Once a rotor begins to demagnetize it causes everything to run hotter.
I would check your rotor and possibly try replacing it with a new sintered rotor.
Let me know if you have any other questions!
Steve Weiss
Old 06-11-2008, 11:20 AM   #6279
stitchy's Avatar
Sorry if this has been asked before, but can lipo cutoff be activated in profile 5 on the GTB? [edited for clarity]
Per the instructions, profile 5 is the only one that is not programable. Why is that? Thanks for your time!
Speedtechhobbies.com
stitchy is offline   Reply With Quote
Old 06-11-2008, 01:25 PM   #6280
The Evicerator
The lipo cut off should be available in any of the profiles on the GTB.
The 5th profile was made "unprogrammable" to make it an easy profile for boat useage.
Steve Weiss
Old 06-11-2008, 02:02 PM   #6281
stitchy's Avatar
Oh I see. So for cars, if we want reverse, we should use profile 2? Thanks for the answers Steve!
Old 06-11-2008, 03:33 PM   #6282
The Evicerator
Yep, profile 2 will have reverse and all the adjustment you will need!
Steve Weiss
Old 06-12-2008, 02:47 AM   #6283
kavadni's Avatar
Steve,
I love this thread.
Can you point me at, or produce of the top of your head, a guide to brushes and compounds, to help me decide which ones to try. I race 27t at the moment.
Kevin
kavadni is offline   Reply With Quote
Old 06-12-2008, 05:18 AM   #6284
Trader Rating: 16 (94%+)
Steve,
Regarding 1/12 scale 17.5 Rollout on NON-Oval Carpet Racing, the Novak website recommends a rollout of 65mm with a 17.5 motor, but everyone at my track is running around a 79-82mm rollout, which is closer to the rollout suggested for Oval 1/12 racing using a 17.5. Our track is about 60'x90' with only one straight, the rest is all twisty's.
Any reason for the huge difference is what is suggested compared to what we are running? It does not seem that we are over geared, temps are in the 150-160F range after 8-minutes.
kn7671 is offline   Reply With Quote
Old 06-12-2008, 10:08 AM   #6285
The Evicerator
Originally Posted by kavadni View Post
Steve,
I love this thread.
Kevin
Thanks Kevin!
IT's been a while since I did the stock motor thing, but I will let ya know about what I know and remember
In most instances I always tried to run Trinity 4499s... they always seemed to give me the best power, but they were finicky... if they got too hot they'd burn up FAST.... so if it's really hot out these might not be the best brush for you. Also, these brushes seemed to varry from batch to batch...so sometimes brushes were good, sometimes they weren't... it's sort of a roll of the dice with them...but if you find a batch that are good, you're in luck!
Next in line was the Reedy 767...which is a good brush that I used when temperatures were a problem... I never felt like they produced the same overall power as the 4499... but they were easier on the motor and less sensitive to high temperatures...they seemed pretty consistant from batch to batch as well.
The "F" brush came around after I really got out of stock racing, so I don't really have too much experience with it... but even when I tried them back to back against good 4499's I prefered the 4499's... but in my estimation they sort of fall "in between" the 4499 and the 767 when it comes to performance.
You pretty much always want a serrated brush... you just want to break the brush in for a little bit at low current... maybe 300 seconds at 2 volts or something like that...
As far as cuts on the brush go... a vertical slot in the center helps keep the brush aligned properly and generally keeps the comm cleaner and cooler ... it reduces power a little bit but not too much.
A hole in the center of the brush reduces power and keeps the brush a bit cooler too.
Cutting the edges of the brushes can effectively change the timing the in motor slightly... some motors respond well to this, others don't... but generally more timing increases motor heat in most instances.
Hope all this helps!
Originally Posted by kn7671 View Post
Steve,
The reason there is probably a big difference is that we are conservative in our gearing recommendations due to the fact that most people will continue to run their vehicle on the track until the battery dies out... and with a 17.5 this can be a very long time.
Race gearing for 5 or 8 minute applications will vary with driver, traction, track size, and ambient temperatures.
Hope this helps!
Steve Weiss
STUFF FOR SALE """"LQQK """" EZRC R/C Items: For Sale/Trade 1 03-13-2007 07:20 PM
"""NEW""" Collari .21 3 port buggy motor lc21-b3 goneRVing R/C Items: For Sale/Trade 7 12-20-2006 06:25 PM
STUFF FOR SALE """"LQQK """" EZRC R/C Items: For Sale/Trade 11 10-22-2006 09:49 PM
""" XRAY FK05 """ excellent cond/super clean/stock evostyle R/C Items: For Sale/Trade 9 06-29-2006 10:04 PM
Let's send Steve Weiss (Evicerator) to Cleveland!!! TeamButter Electric On-Road 8 11-02-2004 11:32 PM
