Old 04-03-2008, 08:51 AM   #6031
The Evicerator
Dan,
There are instances when being significantly undergeared can cause damage to a motor.
Most of the time I would say this would occur with the 3.5 and 4.5 turn motors where if geared too low, can put tremendous strain on the rotor causing eventual rotor failure.
Also, too low of a gearing with this low wind motors can also cause high heat just as overgearing can ... a sign that you might be undergeared is if your esc is cool and the motor is hot... generally in most applications if gearing is correct ESC and motor temps are relatively close.
Originally Posted by Dan the Man View Post
Hi Steve,
Can you damage a brushless motor by undergearing it?
Steve Weiss
TEAM ASSOCIATED -- REEDY -- SANWA -- PROTOFORM -- 1UP Racing -- ActivRC -- P1 BRAND -- TEAM KINWALD -- TEAM STEVE INTERNATIONAL
Steve Weiss is offline   Reply With Quote
Old 04-03-2008, 09:38 AM   #6032
POUNDITRACING's Avatar
what would the best geearing for a 13.5 be? Would you make any timing adjustments?
Pound It Paints - http://www.rctech.net/forum/painting-designs-graphics-photography/270707-pound-paints-raymond-ramirez.html
RC Reveled - http://www.teamrcr.net
POUNDITRACING is offline   Reply With Quote
Old 04-03-2008, 09:41 AM   #6033
The Evicerator
Hey Ray,
I would say mid 4's to start out with and go from there.
Steve Weiss
Old 04-03-2008, 09:47 AM   #6034
Thanks a ton. You are the man.
Old 04-03-2008, 10:09 AM   #6035
J.Filipow's Avatar
Trader Rating: 15 (100%+)
TEAM STEVE!
P1 Brand - "Victory is Black and White" ◢◤◢◤◢◤◢◤◢◤◢◤◢◤◢◤◢◤◢◤
RC America / XRayUSA / Hudy / Motiv / Avid / Vannen Watches
J.Filipow is offline   Reply With Quote
Old 04-03-2008, 10:18 AM   #6036
Originally Posted by J.Filipow View Post
TEAM STEVE!
One could only be so special.
Old 04-03-2008, 11:38 AM   #6037
The Evicerator
Ray, I think you've earned the right to be a member of TEAM STEVE
Steve Weiss
Old 04-03-2008, 11:45 AM   #6038
syndr0me's Avatar
Trader Rating: 32 (100%+)
Eagle Racing makes a rotor fan and endbell kit for the Novak motors. I had an order coming in from RCMarket, so I decided to pick one up. I'm not using the fan, but the new endbell felt much lighter, and has some cool looking machining on the front, as well as some vents cut into the side (not shown). I don't know if/how it will help with cooling, but it looks pretty great on the motor.
Comparing this endbell to the other "ribbed" one from Novak, it appears to be entirely machined by them, and not a modifed Novak version. It comes with a bearing as well. Impressive work for sure. Not sure if you guys knew about it or not. I guess you've officially been "hopped up."
http://rcmarket.com.hk/product_info....oducts_id=2709 (there's a version for the 13mm rotor too)
syndr0me is offline   Reply With Quote
Old 04-03-2008, 01:59 PM   #6039
Wow!!!! For real? That's the best news that I've had since Patrick told me that I would be faster than him some day.
Old 04-03-2008, 06:12 PM   #6040
Branden Moody's Avatar
Ok this sounds dumb but just out of couriosity will a gtb still work if a few of the fets are melted but not too bad?
Branden Moody is offline   Reply With Quote
Old 04-03-2008, 06:31 PM   #6041
The Evicerator
Well, it might function but it will probably run poorly. It might run rough, slow top end, or have trouble starting from a stop.
Steve Weiss
Old 04-03-2008, 11:34 PM   #6042
maxepower's Avatar
Exclamation WHAT HAPPENDED?
Steve,
I have a question, I'm not sure if it is a brushless issue of a Lipo issue but I thought I'd ask just in case you have heard this happen.
While me and my son were running the GTB with the 10.5 motor with the Orion Lipo the negative wire soldered to the bullet connector to the battery literally melted the solder and the wire disconnected.
My son running the same combo with a different car had the same thing happen but on the positive wire, again the solder melted and came completely out of the bullet connector. Both times nothing on the chassis was close to touching the wire connector. No damage or short or overheating anywhere on the electronics. The motor was 110 F. as was the ESC. I resoldered the wire back to the bullet connector and everything was fine. I don't know if this is a battery or a brushless issue, but if you have any ideas what would cause this. The wires are the ones that came with the Novak system and the solder is Radio Shack brand which I have been using for years with no problems in the past.
Not really related but I remember when low turn brushed motors were having wires coming unsolder because of heat or too many amps flowing through a a small gage wire. This is not the case with my cars but I don't know if there is some commonality there or not?
Thanks in advance for any suggestions!
maxepower is offline   Reply With Quote
Old 04-04-2008, 08:59 AM   #6043
The Evicerator
Maxepower,
Brushless systems are capable of pulling lots of current and it just sounds like to me for whatever reason that joint that you have -- lipo bullet connector, wire bullet connector, and solder joint -- is having a hard time handling the current and is heating up.
Do you have access to different solder? How is the solder joint itself...? A picture is worth a thousand words... If you want maybe you can bring it by the shop or to me at the track one day and I can check it out and maybe re-solder it for you...?
Originally Posted by maxepower View Post
Steve,
Steve Weiss
Old 04-04-2008, 11:36 AM   #6044
overflow's Avatar
Originally Posted by Steve Weiss View Post
Maxepower,
I had the same thing happen to me with a trinity 4500 lipo... the negitive lead came off and melted the plastic. It was with a LRP TC and a 10.5, i know this is Steve's novak thread, but i just thought i would throw that out there. i think Steve is right and not a novak ESC problem, but maybe something with lipos and current draw.
Dennis Vice
[HOTBODIES] [SPEED PASSION]
overflow is offline   Reply With Quote
Old 04-04-2008, 12:07 PM   #6045
The Evicerator
Thanks for the input Overflow!
The more connections you have the more resistance you will accumulate and this leads to voltage drop/less efficiency/more heating... which can be contributing to the leads unsoldering at this point.
Steve Weiss
STUFF FOR SALE """"LQQK """" EZRC R/C Items: For Sale/Trade 1 03-13-2007 07:20 PM
"""NEW""" Collari .21 3 port buggy motor lc21-b3 goneRVing R/C Items: For Sale/Trade 7 12-20-2006 06:25 PM
STUFF FOR SALE """"LQQK """" EZRC R/C Items: For Sale/Trade 11 10-22-2006 09:49 PM
""" XRAY FK05 """ excellent cond/super clean/stock evostyle R/C Items: For Sale/Trade 9 06-29-2006 10:04 PM
Let's send Steve Weiss (Evicerator) to Cleveland!!! TeamButter Electric On-Road 8 11-02-2004 11:32 PM
