Old 02-08-2008, 11:15 AM   #5866
Regional Moderator
CarbonJoe's Avatar
Originally Posted by Steve Weiss View Post
Carbon ... I believe they have updated the website!
Yes, they seem to have updated it on 2/06. I created a thread about it already.
http://www.rctech.net/forum/showthread.php?t=204669
Thanks!
*** The Gate - Celebrating 8 years at the same location ***
The difference between genius and stupidity is that genius has its limits. - Albert Einstein
Understeer is when you hit the wall with the front of the car and oversteer is when you hit the wall with the rear of the car
CarbonJoe is offline   Reply With Quote
Old 02-11-2008, 01:00 AM   #5867
fatbear's Avatar
Send a message via Yahoo to fatbear
Hey Fatbear... any more updates on your problem?
Yep, no problems at the track. Car switched on and as before sometimes went to full power for a second or two and sometimes nothing. But after that it was as normal. No glitching, no other problems. So I just got used to it and ran it.
fatbear is offline   Reply With Quote
Old 02-11-2008, 08:59 AM   #5868
The Evicerator
Still seems strange to me but as long as it's not affecting your on track performance I suppose that's ok.
Steve Weiss
TEAM ASSOCIATED -- REEDY -- SANWA -- PROTOFORM -- 1UP Racing -- ActivRC -- P1 BRAND -- TEAM KINWALD -- TEAM STEVE INTERNATIONAL
Steve Weiss is offline   Reply With Quote
Old 02-11-2008, 09:05 AM   #5869
RPage's Avatar
Hi Steve
fatbear - Re-bind your receiver and add a little brake into the fail safe mode. This should eliminate the uncontrolled throttle application while the module and receiver find each other.
RPage is offline   Reply With Quote
Old 02-11-2008, 10:28 AM   #5870
Steve,
Wilma Flintstone or Betty Rubble?
Unregistered is offline   Reply With Quote
Old 02-11-2008, 11:06 AM   #5871
The Evicerator
Steve Weiss
Old 02-11-2008, 11:06 AM   #5872
The Evicerator
Tough question!
I like both red heads and brunettes!
But.... I'd have to go with ............Betty!
Steve Weiss
Old 02-11-2008, 11:05 PM   #5873
EricF's Avatar
Steve,
Is it a really bad idea to use a lipo pack w/ the 4 cell gtb, or can it be done?
thanks,
E
EricF is offline   Reply With Quote
Old 02-11-2008, 11:32 PM   #5874
The Evicerator
It is not advisable... the 4 cell GTB is really only intended for use with 4 cells NiMH ... which is about 6 V total.
Originally Posted by EricF View Post
Steve,
thanks,
E
Steve Weiss
Old 02-12-2008, 12:55 AM   #5875
And "The 2008 Snowbird Nationals 10.5 Oval class sponsor is NOVAK!!!!!!!!!!!!"
Thanks Steve and Charlie for all your hard work.
Hope to see you at the Carpet Oval Nats in Fla.
scarecrow is offline   Reply With Quote
Old 02-12-2008, 06:17 AM   #5876
Aid1970's Avatar
Hi Steve
I am going to try my 10.5 setup n 5 cell .some have try'd it and found it faster how should i change my speedo settings i race tc rubber on carpet thanks in advance for your help
Aid1970 is offline   Reply With Quote
Old 02-12-2008, 09:21 AM   #5877
The Evicerator
NOVAK!
Steve Weiss
Old 02-12-2008, 09:22 AM   #5878
The Evicerator
Aid,
Honestly most of your settings will probably stay the same. Your gearing will have to go up though... usually I would gear up 2 teeth on the pinion when changing from 6 to 5 cells in mod... you may have to gear up even more for 10.5.
The only setting that you might want to play with would be your minimum drive... you can turn that up from 1% to suit your preference to give you a little more bottom end response.
Originally Posted by Aid1970 View Post
Hi Steve
Steve Weiss
Old 02-12-2008, 01:33 PM   #5879
Aid1970's Avatar
Thanks Steve
Old 02-12-2008, 05:15 PM   #5880
miccal's Avatar
Trader Rating: 23 (100%+)
Hey Miccal,
Sorry about the delay in answering you... been a busy last few days!
We always recommend running the fan on the ESC regardless of the application: A cooler ESC is a better running ESC...but in most cases with a 13.5 the system will not generate too much heat and you'd more than likely be safe running without it.
If you would like another fan sent to you you can PM me your address and I can try to have one sent to you.
Received the replacement fans, thanks Steve!
Could you give me some information regarding the 13mm rotor, like what it does different, gear ratios etc?
miccal is offline   Reply With Quote
STUFF FOR SALE """"LQQK """" EZRC R/C Items: For Sale/Trade 1 03-13-2007 07:20 PM
"""NEW""" Collari .21 3 port buggy motor lc21-b3 goneRVing R/C Items: For Sale/Trade 7 12-20-2006 06:25 PM
STUFF FOR SALE """"LQQK """" EZRC R/C Items: For Sale/Trade 11 10-22-2006 09:49 PM
""" XRAY FK05 """ excellent cond/super clean/stock evostyle R/C Items: For Sale/Trade 9 06-29-2006 10:04 PM
Let's send Steve Weiss (Evicerator) to Cleveland!!! TeamButter Electric On-Road 8 11-02-2004 11:32 PM
