Old 01-09-2008, 05:46 PM   #5776
The Evicerator
March,
You are correct for the most part.
The timing helps move the power band around...generally if you turn the timing up significantly you have to gear down to take advantage of the higher RPM because the torque will be reduced to a point that it will not efficiently carry the load of a larger gear.
Originally Posted by march to my own View Post
Hello Steve,
When I advance the timing on my 13.5 am I essentially just moving the torque curve around.
For instance If the timing is advanced the motor will run faster but will have to be geared down correct?
Is advancing the timing give me and advantage?
Steve Weiss
TEAM ASSOCIATED -- REEDY -- SANWA -- PROTOFORM -- 1UP Racing -- ActivRC -- P1 BRAND -- TEAM KINWALD -- TEAM STEVE INTERNATIONAL
Steve Weiss is offline   Reply With Quote
Old 01-09-2008, 06:06 PM   #5777
Steve-
When do you think the new software for GTB will be released with regards to the auto timing advance. It sure seems like Josh and Mike like the feature. Has it changed since Cleveland?
cookie1 is offline   Reply With Quote
Old 01-10-2008, 03:03 AM   #5778
rough512's Avatar
Hi Steve
Would you guys possibly have information (re: wire guages and number of strands for each BL motor) posted somewhere? if not, kindly post them here? I rewound my 3.5r since I can't drive a car with it. My rewound motor is doing fine using #18awg wire but the winding is sloppy. I'm planning to re-do it sometime. I would like to pattern it after your "official" specs if possible.
thanks
rough512 is offline   Reply With Quote
Old 01-10-2008, 04:20 AM   #5779
LOSI123's Avatar
Trader Rating: 63 (100%+)
Steve:
Is it safe to drive a car with a novak 4.5r and a gtb that doesnt have built in li-po cuttoff, and just drive it till when you pull the trigger on all the way you notice got not much power and then pull it in for a charge.
I am running li-po's and it seems to be all fine then just dump real fast all of a sudden, (like its hard to tell that its slowing, until bam !!!!)
so when it dumps can i just nurse the car in at slow speed.
or can letting it go until you notice it dump on a li-po can be bad for the pack?
LOSI123 is offline   Reply With Quote
Old 01-10-2008, 05:36 AM   #5780
Trader Rating: 44 (100%+)
thanks Steve. you are spot on. the RX wiring was the wrong way around.
with prompt responses like this .. it's 1 of the primary reasons i got a 3rd novak speedo.
Originally Posted by Steve Weiss View Post
wyl,
Well it sounds like you might have two problems... let me address the first one:
When doing the one touch setup, you have the start right:
Hold down the button, turn the ESC on and when the red LED comes on let go of the button and pull full throttle.
But where you have it wrong is when the green LED comes on... at this poing you go to full brake, not to neutral!
Once the trigger is at full brake the green LED should blink, THEN you return the trigger to neutral!
Now, in regards to the issue where when you turn the ESC on and you see a green and red LED on solid, this means that the ESC is not getting signal... check to make sure your transmitter is on and working properly, and double check your input harness to make sure that it is oriented correctly on both the ESC and in the receiver!
YOKObori MOkei
wyl03 is offline   Reply With Quote
Old 01-10-2008, 08:43 AM   #5781
Frank McKinney's Avatar
Steve, what is your opinion of the Hollywood writer's strike, and further what do you think about the actors and actresses not attending the Golden Globes? Do you think the strike will affect the Oscars at all?
Minimal signature to save screen space! Big sigs suX0r
Frank McKinney is offline   Reply With Quote
Old 01-10-2008, 08:50 AM   #5782
The Evicerator
Cookie,
Unfortunately that sort of stuff is still under development and we don't have any sort of ETA for when it will be put into production.
Originally Posted by cookie1 View Post
Steve-
Steve Weiss
Old 01-10-2008, 08:51 AM   #5783
The Evicerator
Hey Rough,
I will check to see if it is "OK" for me to post that information online later !
Originally Posted by rough512 View Post
Hi Steve
thanks
Steve Weiss
Old 01-10-2008, 08:53 AM   #5784
The Evicerator
Losi,
Well I can't really say that it's safe because if you damage the battery pack by discharging it too low you run the risk of having problems charging that lipo pack back up....
From an ESC stand point it won't be hurt by the battery being discharged too low though.
Running a smart stop cut off module is your safest option available to you so you don't damage your packs.
Sometimes you can tell when a lipo pack is dumping just by the lack of punch you get but this is a very dangerous way to determine if your pack is getting close to being dumped out.
Originally Posted by LOSI123 View Post
Steve:
Steve Weiss
Old 01-10-2008, 08:54 AM   #5785
The Evicerator
wyl,
I'm glad to have been a help!!
Steve Weiss
Old 01-10-2008, 09:00 AM   #5786
The Evicerator
I agree with them in that if you're doing work, you should be getting paid for it.
I wouldn't like going to the track weekend after weekend testing stuff and not getting paid for it...
As far as the award show stuff goes... I have a hard time caring about any of it... Alot of people patting themselves on the back for bad rehashes of 20 year old movies and concepts just doesn't strike me as noteworthy
I guess the actors and acrtresses not attending can be seen like a "sacrifice" from their point of view...they're cutting out valuble public appearance time in an effort to garner a close to the strike... so I guess that's nice of them.
Steve Weiss
Old 01-10-2008, 10:14 AM   #5787
ta_man's Avatar
Trader Rating: 151 (100%+)
True, but you don't really expect to get paid continuously for years and years for that one weekend at the track testing something just because Novak is selling the thing you tested.
ta_man is offline   Reply With Quote
Old 01-10-2008, 10:05 PM   #5788
The Evicerator
Good point... I guess my analogy wasn't exactly perfect
Steve Weiss
Old 01-10-2008, 10:48 PM   #5789
flameoutgarrett's Avatar
Send a message via MSN to flameoutgarrett
steve....2 ????'s
1st: what would you gear a 5.5 (foam) on a vegas sized track, TC?
2nd: why you gotta wuss out on COD4?
jk
Team fun-Www.rc-trim.com-Team Speedmerchant-Team Orca-Team Br00d
flameoutgarrett is offline   Reply With Quote
Old 01-10-2008, 10:51 PM   #5790
The Evicerator
Our 5.5?
12.3 mm rotor about 8.5
13.0 mm rotor about 7.6 or so
as for COD4... no idea... just not into it lately
Originally Posted by flameoutgarrett View Post
steve....2 ????'s
jk
Steve Weiss
STUFF FOR SALE """"LQQK """" EZRC R/C Items: For Sale/Trade 1 03-13-2007 07:20 PM
"""NEW""" Collari .21 3 port buggy motor lc21-b3 goneRVing R/C Items: For Sale/Trade 7 12-20-2006 06:25 PM
STUFF FOR SALE """"LQQK """" EZRC R/C Items: For Sale/Trade 11 10-22-2006 09:49 PM
""" XRAY FK05 """ excellent cond/super clean/stock evostyle R/C Items: For Sale/Trade 9 06-29-2006 10:04 PM
Let's send Steve Weiss (Evicerator) to Cleveland!!! TeamButter Electric On-Road 8 11-02-2004 11:32 PM
