Old 12-27-2007, 02:37 PM   #5746
Hebiki's Avatar
Trader Rating: 26 (100%+)
Default Red Ring of Death
Steve
when you returned your xbox.... how long did it take to get it back? also.. any special procedures i need to know to return it? my (original) xbox finally got nailed with the red ring of death. i need to send it in for repair
good thing i got the ring though.. i bought myself a new elite. game on tonight?
- Chris
Hebiki Design Works
Custom R/C Vinyl Graphics & Apparel: Your gear, your way!
Web Design - Web Development - Logo Design - Graphic Design
www.facebook.com/HebikiDesignWorks
Hebiki is offline   Reply With Quote
Old 12-27-2007, 03:08 PM   #5747
The Evicerator
It depends on how it all goes through... you should call them...get a return number and all that jazz...the first time I sent it in I sent it in my own box...the second time they sent their own box.... after they get it it should only take a week or so for them to get another one shipped back out to you
All in all it takes around 2 weeks
Originally Posted by Hebiki View Post
Steve
- Chris
Steve Weiss
TEAM ASSOCIATED -- REEDY -- SANWA -- PROTOFORM -- 1UP Racing -- ActivRC -- P1 BRAND -- TEAM KINWALD -- TEAM STEVE INTERNATIONAL
Steve Weiss is offline   Reply With Quote
Old 12-27-2007, 07:18 PM   #5748
Steve
- Chris
Hi there,
GO on youtube and type in xbox 360 ring of deth fix.
You put 4 towels around your 360 and turn it on for about 20 mins, take the towels off then restart your xbox, then it should be fine. Basically all it does is overheat your xbox till an extent that it will reset its internal memory.
jamie814340 is offline   Reply With Quote
Old 12-28-2007, 07:10 PM   #5749
Trader Rating: 49 (95%+)
Send a message via Yahoo to loopedout
Steve, on a 13mm rotor vs. a std sintered rotor should I go up a tooth or two on the pinion?
loopedout is offline   Reply With Quote
Old 12-28-2007, 11:29 PM   #5750
LOSI123's Avatar
Trader Rating: 63 (100%+)
Steve,
(non novak ?)
Is running 30wt shock oil in 2 hole pistons with 1.2mm holes,
similar to running 45wt oil with 3 hole 1.1mm holes.
thanks...
LOSI123 is offline   Reply With Quote
Old 12-29-2007, 10:32 AM   #5751
The Evicerator
Looped,
I usually gear up two teeth on the pinion in 64 pitch when I used the 13 mm rotor
Steve Weiss
Old 12-29-2007, 10:37 AM   #5752
The Evicerator
hey Losi,
Non novak questions are fine by me... that's how this thread started out anyways
While 30wt w/ 2x1.2 may feel like 4.5 w/3x1.1's when moving the pistion in and out slowly, they will have different dampening characteristics if you move them faster and in the car.
The smaller the total pistion hole area, the 2x1.2 pistion, will have more pack, or more high speed dampening than the 3x1.1
This usually translates to less weight transfer when running in the car...less body roll from side to side and front to back.
It really depends on what track conditions are like...but generally more pack is better for high traction situations and less pack is better for lower traction surfaces.
Originally Posted by LOSI123 View Post
Steve,
(non novak ?)
thanks...
Steve Weiss
Old 12-29-2007, 03:40 PM   #5753
LOSI123's Avatar
Thanks steve....
Old 12-31-2007, 02:58 AM   #5754
miccal's Avatar
Trader Rating: 23 (100%+)
I have a GTB/SS13.5 setup. If I get a Novak motor heat sink, it says that you can mount a 25mm fan on the fins. Where do you plug the fan in? There is only one set of fan pins on the ESC, which the ESC fan is plugged into, so how do you use another fan?
miccal is offline   Reply With Quote
Old 12-31-2007, 11:11 PM   #5755
miccal's Avatar
I am new to brushless, so another question. I have installed my GTB/SS13.5 into my new Tamiya TRF416, and the car weighs 1550g without transponder. Are brushless setups heavier than a brushed setup?
Old 01-01-2008, 11:23 AM   #5756
The Evicerator
Hey Miccal,
You can just splice the fan wires into the ESC fan wires... or you can plug the motor fan wires into an extra space in the receiver to run off the BEC.
Also,
A brushless setup is generally heavier than a brushed setup by a good amount.
Steve Weiss
Old 01-01-2008, 11:56 AM   #5757
miccal's Avatar
Thanks Steve. I have a Futaba R303FHS receiver, and there is a slot labeled "B/C", is that what you mean by BEC? Is that where I plug it in?
Old 01-01-2008, 12:00 PM   #5758
The Evicerator
You can generally plug the fan into ANY open slot in your receiver.
Steve Weiss
Old 01-01-2008, 12:01 PM   #5759
J.Filipow's Avatar
Trader Rating: 15 (100%+)
Steve Type-
I hope you have an intergalactic-prophylactic-atlatlactic New Year's Day!
P1 Brand - "Victory is Black and White" ◢◤◢◤◢◤◢◤◢◤◢◤◢◤◢◤◢◤◢◤
RC America / XRayUSA / Hudy / Motiv / Avid / Vannen Watches
J.Filipow is offline   Reply With Quote
Old 01-01-2008, 12:05 PM   #5760
miccal's Avatar
So Channel 3 is also OK?
STUFF FOR SALE """"LQQK """" EZRC R/C Items: For Sale/Trade 1 03-13-2007 07:20 PM
"""NEW""" Collari .21 3 port buggy motor lc21-b3 goneRVing R/C Items: For Sale/Trade 7 12-20-2006 06:25 PM
STUFF FOR SALE """"LQQK """" EZRC R/C Items: For Sale/Trade 11 10-22-2006 09:49 PM
""" XRAY FK05 """ excellent cond/super clean/stock evostyle R/C Items: For Sale/Trade 9 06-29-2006 10:04 PM
Let's send Steve Weiss (Evicerator) to Cleveland!!! TeamButter Electric On-Road 8 11-02-2004 11:32 PM
