Old 12-14-2007, 02:58 PM   #5686
maxepower's Avatar
Questions?? ESC spectrum question!
Steve,
Will the new GTB Spreadspektrum ESC work with 75mhz controllers.
I just bought one and the hobby store said it would work but the label
on the box says "only" spectrum systems?
Thanks in advance!
Max
maxepower is offline   Reply With Quote
Old 12-14-2007, 03:40 PM   #5687
The Evicerator
Max,
Your hobby shop was wrong when they said that the Spread Spectrum GTB would work fine with your 75 or 27 MHz radio systems.
I would expect you to encounter glitching problems if you try to run the SS GTB without some sort of 2.4 GHz radio system.
Originally Posted by maxepower View Post
Steve,
Thanks in advance!
Max
Steve Weiss
TEAM ASSOCIATED -- REEDY -- SANWA -- PROTOFORM -- 1UP Racing -- ActivRC -- P1 BRAND -- TEAM KINWALD -- TEAM STEVE INTERNATIONAL
Steve Weiss is offline   Reply With Quote
Old 12-14-2007, 04:17 PM   #5688
Trader Rating: 22 (100%+)
Default Timing
Originally Posted by Steve Weiss View Post
The timing is already adjustable in our motors, it's just not veary obvious.
The three flat head screws in the back must be loosened up a bit then the outside ring that has slots in it must be rotated.
If you're looking at the endcap side of the motor clockwise is less timing, counter-clockwise is more timing.
This changes the sensors in relation to the coils in the motor.
Sorry about this repeat question but need it cleared up. Does the above answer include all 13.5 motors including the pro motors with "The color-coded, non-removable, non-replaceable timing ring" ?
Terry
Is your car slow..Xray it!.......FK05, M18, M18t
RexX
Assoc...T3,T4, B4
Team Ash is offline   Reply With Quote
Old 12-14-2007, 04:34 PM   #5689
The Evicerator
Terry,
Yes, the timing is adjustable on all of our motors that we have made thus far.
This includes the original Super Sport Series:
5800 and 4300
The Newer EX Series
8.5 EX, 10.5 EX, and 13.5 EX
The Super Sport Pro Series
8.5 Pro, 10.5 Pro, 13.5 Pro and 17.5 Pro
The Velociti Series
3.5R, 3.5L, 4.5R, 4.5L, 5.5R, 5.5L, 6.5R, 6.5L, 7.5R and 7.5L
The HV Series
6.5 HV (formerly HV 4400) and 4.5 HV
...whew, that's alot of motors!
Originally Posted by Team Ash View Post
Sorry about this repeat question but need it cleared up. (some people are a little hard to convince) Does the above answer include all 13.5 motors including the pro motors with "The color-coded, non-removable, non-replaceable timing ring" ?
Terry
Steve Weiss
Old 12-14-2007, 04:51 PM   #5690
Default Timing
Thank you Steve.
RexX
Assoc...T3,T4, B4
Old 12-14-2007, 05:22 PM   #5691
maxepower's Avatar
Max,
Old 12-14-2007, 08:20 PM   #5692
Trader Rating: 16 (94%+)
Wow, and just looking back, I bet Novak never thought they would be in the motor business 6-years ago.
Terry,
5800 and 4300
The Newer EX Series
The Velociti Series
The HV Series
kn7671 is offline   Reply With Quote
Old 12-15-2007, 11:06 PM   #5693
LOSI123's Avatar
Trader Rating: 63 (100%+)
Steve:
Is there a correct way to pull out the sensor plug from a gtb esc?
as i cant grab the actual plug as it is too small, the only way i can think of to pull it out is to pull on the wires?
LOSI123 is offline   Reply With Quote
Old 12-16-2007, 11:32 AM   #5694
The Evicerator
Losi,
Well ideally we like to be able to grab the plug... but if you grab the wires and sort of wiggle the connector back and forth while gently pulling it out.
Originally Posted by LOSI123 View Post
Steve:
Steve Weiss
Old 12-17-2007, 01:01 PM   #5695
LOSI123's Avatar
Thanks steve,
Also, is it posible to damage the gtb by having a brushed motor wired up (no sensor wire in) & turning the car on and transmitting a throtle signal (while still in brushless mode i think)?
As i thought the gtb just changed to brushed mode once the sensor wire was unpluged, but then i relized i have to do a seqeunce with the button to change it into brushed mode, oops...
Old 12-17-2007, 01:38 PM   #5696
The Evicerator
They say that it's possible to damage the ESC by having it wired up incorrectly, but I haven't actually seen one be damaged from that as long as you don't leave it running like that for a long period of time.
Thanks steve,
Steve Weiss
Old 12-17-2007, 03:47 PM   #5697
LOSI123's Avatar
yeah with the gtb, i had it all wired up correctly and didnt have the sensor wire pluged in,
but i just turned it all on and tryed to use it and wondered why it didnt work, lol
I think i got confused with my novak XBR esc instructions and assumed that it would go automaticly into brushed profile, like i think the xbr does. is this correct?
Old 12-18-2007, 11:21 AM   #5698
Turbo Joe's Avatar
Trader Rating: 41 (100%+)
Hey Steve,
Thanks for the stickers!
http://edseb.smugmug.com/gallery/4012501#233520413
http://edseb.smugmug.com/gallery/4012501#233520080
It won the concourse, too. 5 year-old judge with an eye for bright colors.
Joe
Turbo Joe is offline   Reply With Quote
Old 12-18-2007, 12:17 PM   #5699
fatbear's Avatar
Send a message via Yahoo to fatbear
Steve,
In your opinion for touring car which motor setup would be better and/ or quicker on a medium to long length ashfelt track.
6.5 with a bonded rotor or a 7.5 with a sintered/ 13mm rotor?
Team Associated www.teamassociated.com
Team Tekin www.teamtekin.com
B-Fast R/C Performance www.bfastrc.com
JConcepts www.jconcepts.net
Ace Hobby Distributors www.acehobbyaustralia.com
fatbear is offline   Reply With Quote
Old 12-19-2007, 10:00 AM   #5700
The Evicerator
Hey Fatbear,
I always recommend using sintered rotors in favor of bonded rotors for most applications... that being said I think the 7.5 turn with the sintered rotor is your best bet.
Originally Posted by fatbear View Post
Steve,
Steve Weiss
STUFF FOR SALE """"LQQK """" EZRC R/C Items: For Sale/Trade 1 03-13-2007 07:20 PM
"""NEW""" Collari .21 3 port buggy motor lc21-b3 goneRVing R/C Items: For Sale/Trade 7 12-20-2006 06:25 PM
STUFF FOR SALE """"LQQK """" EZRC R/C Items: For Sale/Trade 11 10-22-2006 09:49 PM
""" XRAY FK05 """ excellent cond/super clean/stock evostyle R/C Items: For Sale/Trade 9 06-29-2006 10:04 PM
Let's send Steve Weiss (Evicerator) to Cleveland!!! TeamButter Electric On-Road 8 11-02-2004 11:32 PM
