Ask Steve "The Evicerator" Weiss
#5566
steve will the 13.5 motor work with ko vsf-1 c2 esc?
#5568
1. Can the GTB Spread Spektrum be used with non-Spektrum receivers? How about Futaba's PCM receiver?
Will there be any degradation in response rate?
2. Is there a way to disable the lipo cut-off?
Cheers.
Cheers.
#5569
The Evicerator
The GTB Spread Spectrum should be used ONLY with DSM 2.4 GHz radio systems. No FM, no AM, no PCM.
The lipo cut off can be toggled between on and off
#5570
The Evicerator
Tire Chunker,
You're correct, we only shim the pinion side. We never shim the opposite end.
#5571
10.5 Shims
Steve,
For the BL motors do you only shim the pinion side to take up play? Do you need any shims at the other end?
#5573
@Steve: I bought a Novak Crawler 55t motor and can not keep up with the guys with the 3.5t LRP motors, I think your product is no good...
How's everything chap? Does Bob keep you busy?
#5574
#5576
The Evicerator
Hey Reto!
I dunno what to say... I guess we will have to do some major tuning work on our 55 crawler motor to get it up to speed!
Everything is going pretty well...been very busy with work, school, racing, and life in general!
How are things over there...? Staying busy for sure I bet!
#5577
An unfair question, but I'll ask anyway...
We may be getting a carpet track locally, and they are talking about starting some 4-cell 13.5 oval classes... That sounds good, but I would want to get the 4-cell ESC for it's light weight, etc... HOWEVER -- I mostly run 6-cell (sedan, offroad truck/buggy, etc.)...
If I buy the 4-cell GTB could I get away with using it for 13.5 or 10.5 with 6-cells or is it strictly 4-cells only? (I figure as cool as a GTB stays for 13.5 and 10.5, it just might work?)....
I had to ask...
I had to ask...
#5578
The Evicerator
Tfrahm,
We don't recommend running the 4 cell GTB with 6 cells in any application... Sorry!
I had to ask...
I had to ask...
#5579
I also assume that changing the heatsink voids the warranty...? Any special tips and/or an official "How-To"?
#5580
The Evicerator
Sorry about the delay in answering...was out of town for the holiday!
Switching to a flat aluminum heatsink for the standard GTB would be ok for lower load applications such as 1/12 because you don't need as much heat disipation.
No special tips except to be careful of the pad and the spacers underneath the heatsink...try not to damage them.
No problem -- I just had to ask... I also need to look at 12th scale onroad, where room under the body is a problem -- I assume the switch to a flat aluminum "heatsink" like the 4-cell GTB, etc. is OK for the standard GTB...? (is the flat plate available separately?)
