Old 11-01-2007, 09:04 AM   #5491
Trader Rating: 1 (67%+)
Dear sir,
Can you please tell me a good starting point for fdr on a 10.5 with a sintered rotor to be run on a 100'x50' carpet track. (rubber tires)
Thank you, I'll hang up and listen for your response
Josh Hohnstein is offline   Reply With Quote
Old 11-01-2007, 09:11 AM   #5492
The Evicerator
Hey Josh,
Usually I recommend to people to start out at a 5.5 FDR... but it seems that alot of people end up running higher than that... usually in the 5.3-4.9 range.
Steve Weiss
TEAM ASSOCIATED -- REEDY -- SANWA -- PROTOFORM -- 1UP Racing -- ActivRC -- P1 BRAND -- TEAM KINWALD -- TEAM STEVE INTERNATIONAL
Steve Weiss is offline   Reply With Quote
Old 11-01-2007, 09:29 AM   #5493
Thank you
Old 11-01-2007, 03:01 PM   #5494
STLNLST's Avatar
Trader Rating: 21 (100%+)
RAN MINE AT 5.2 AND THE CAR WAS FAST. JUST NEED TO TWEAK THE SET UP A LITTLE. MY MOTOR IS FAST EVEN IF STEVE DIDN'T TOUCH MY MOTOR
STLNLST is offline   Reply With Quote
Old 11-01-2007, 03:58 PM   #5495
RobertV's Avatar
RobertV is offline   Reply With Quote
Old 11-01-2007, 04:12 PM   #5496
Jon Kerr's Avatar
Trader Rating: 17 (100%+)
Then why are you yelling at him?
Jon Kerr is offline   Reply With Quote
Old 11-01-2007, 04:37 PM   #5497
Trader Rating: 18 (100%+)
Come on guys....quit picking on the "Caps Lock" challenged.
LMAO!
SMC ( www.smc-racing.com the only place to order your batteries online.), Awesomatix, Gonzo Paints, BN Racing
"Imitation is the sincerest form of flattery."
Advil is offline   Reply With Quote
Old 11-01-2007, 09:52 PM   #5498
Thumbs down
Steve what do you think the chances are that I can plug my 17.5 /Crawler into the new Mongoose controller and mount it in my 1/12th ride???
cookie1 is offline   Reply With Quote
Old 11-01-2007, 10:37 PM   #5499
The Evicerator
Cookie,
It's hard to say... I'm sure we'll get around to testing something like that sooner or later... because I'm sure at some point someone will try it themselves.... but I can't give you any sort of idea as to how well it will work.
Steve Weiss
Old 11-02-2007, 04:48 AM   #5500
LOSI123's Avatar
Trader Rating: 63 (100%+)
Hello Steve,
Whats the recomended Gear Ratio range for a ex13.5 (bonded)
in a TC, outdoor, running 63mm sorex rubber, 6 cell, in 30 degrees Celsius Weather, Medium sized track.
thanks....
LOSI123 is offline   Reply With Quote
Old 11-02-2007, 07:47 AM   #5501
Thanks..time will tell....
ok on a separate note I want to get my gtx to be more of a switch for stock 1/12th racing...I have moved from profile 1 to profile 7. I am running the lowest drive freg. with highest minimum drive allowed. I have set my 3pk's throttle expo to 100%. Any other suggestions?
Old 11-02-2007, 08:58 AM   #5502
The Evicerator
I would probably start out around 5.5 and go from there. Carefully monitor your temperatures and make sure that the motor stays under 170 degrees F.
Originally Posted by LOSI123 View Post
Hello Steve,
thanks....
Steve Weiss
Old 11-02-2007, 03:03 PM   #5503
BJ
what is the difference between a 3.5R motor and a 3.5T motor?? is it to do with the winding pattern?
BJ is offline   Reply With Quote
Old 11-02-2007, 03:12 PM   #5504
The Evicerator
Technically there is no "3.5T" ... I think you might have seen it simply because it'd be a condensed version of "3.5 Turn".
There are two different styles now... the "standard" or "R" suffixed winds.. and the "Light" or "L" suffixed winds.
The "L's" use smaller gauge wire
Steve Weiss
Old 11-02-2007, 03:14 PM   #5505
STLNLST's Avatar
Originally Posted by RobertV View Post
Steve likes it when I speak up
Too many EEEEEWWWWOOOOOPPPPPPPSSSSSS back in the day so his hearing has suffered some
STUFF FOR SALE """"LQQK """" EZRC R/C Items: For Sale/Trade 1 03-13-2007 07:20 PM
"""NEW""" Collari .21 3 port buggy motor lc21-b3 goneRVing R/C Items: For Sale/Trade 7 12-20-2006 06:25 PM
STUFF FOR SALE """"LQQK """" EZRC R/C Items: For Sale/Trade 11 10-22-2006 09:49 PM
""" XRAY FK05 """ excellent cond/super clean/stock evostyle R/C Items: For Sale/Trade 9 06-29-2006 10:04 PM
Let's send Steve Weiss (Evicerator) to Cleveland!!! TeamButter Electric On-Road 8 11-02-2004 11:32 PM
