Old 07-19-2007, 09:17 AM   #4981
The Evicerator
Adrian,
I don't really recommend changing the timing on the motors because we optomize the timing for most applications, but it can be done.
If you are looking at the back side of the motor where the sensor wires come out the back you need to loosen the 3 1/16" screws slightly and rotate the colored timing ring via one of slots in the ring... I recommend a small screwdriver for this.
The ring itself will only move a small amount... if you look at the solder tabs on the motors in relation to the slots in the motor the slots on either side of the tabs will just tuck up behind the solder tabs at either extremity.
To advance the timing you turn the ring counter clockwise.
To retard the timing you turn the ring clockwise.
When you time up you're going to have to gear the car down a bit... and when you time down you will have to gear it up.
Good luck!
Originally Posted by AdrianM View Post
Steve,
Can you adjust the timing on the new 13.5 and 10.5 motors? I see no mention of this in the instructions. I would like to increse the timing of my new 13.5 for 1/12th 4 cell racing. Hopefully to get a little more rpm so I can run a less insane gear ratio
Steve Weiss
TEAM ASSOCIATED -- REEDY -- SANWA -- PROTOFORM -- 1UP Racing -- ActivRC -- P1 BRAND -- TEAM KINWALD -- TEAM STEVE INTERNATIONAL
Steve Weiss is offline   Reply With Quote
Old 07-19-2007, 04:23 PM   #4982
AdrianM's Avatar
Originally Posted by Steve Weiss View Post
Adrian,
Good luck!
Thanks Steve, thats what I needed to know. I figured I could time up and gear down a little. Heat and efficiency are not big issues in 4 cell 1/12th racing.
Old 07-20-2007, 08:58 AM   #4983
The Evicerator
No problem!
Steve Weiss
Old 07-20-2007, 09:56 AM   #4984
DRAG_ON's Avatar
Steve can you please post the save FDR ratio for rubber tire 5 cells for:
Novak 5.5R
Novak 4.5R
Novak 3.5R
thanks please give me the save ratio within, thanks in advance
Freq:29.945, car no:29, W.A.R.C.M.C.C, http://projectm-design.blogspot.com/
DRAG_ON is offline   Reply With Quote
Old 07-20-2007, 10:07 AM   #4985
Jack Smash's Avatar
Trader Rating: 29 (100%+)
How do you change profiles on the XBR sport Speedo? It wasnt in the instructions. Is it the same as the GTB?
Kyosho / Orion / Amain.com / Protek / MIP /
Jack Smash is offline   Reply With Quote
Old 07-20-2007, 10:18 AM   #4986
The Evicerator
Drag_on,
Usually for 5 cell I find myself gearing up 2 teeth on my pinion in 64 pitch from where I am geared with 6 cells.
So for medium sized tracks I would gear:
5.5= 7.6 FDR
4.5= 8.5 FDR
3.5= 9.4 FDR
Novak 5.5R
Novak 4.5R
Novak 3.5R
Steve Weiss
Old 07-20-2007, 10:20 AM   #4987
Hebiki's Avatar
Trader Rating: 26 (100%+)
sucks you missed the game last night steve.
buy your next xbox at walmart!
boo on the red ring of death!
Hebiki Design Works
Custom R/C Vinyl Graphics & Apparel: Your gear, your way!
Web Design - Web Development - Logo Design - Graphic Design
www.facebook.com/HebikiDesignWorks
Hebiki is offline   Reply With Quote
Old 07-20-2007, 10:26 AM   #4988
The Evicerator
Jack,
You change the profiles in exactly the same manner as with the GTB.
It is all outlined in the "Advanced Programming: Profile Selection and Proper Gearing" instruction Sheet which should have been included with your XBR ESC.
Steve Weiss
Old 07-21-2007, 08:44 PM   #4989
TFR
TFR's Avatar
Steve,
Does the power trans-cap module's positive and negative wires suppose to be as short as possible or it does not matter? My Cyclone layout does not let me have short wires!
Muchmore l AHRP l Xenon l Futaba
TFR is offline   Reply With Quote
Old 07-22-2007, 10:06 AM   #4990
The Evicerator
TFR,
If you're going to use 16 awg wires the length that comes on the transcap is as long as you can go.
If you go to larger gauge wires you can run slightly longer wires... but we're not talking lots of extra length
Originally Posted by TFR View Post
Steve,
Steve Weiss
Old 07-22-2007, 05:22 PM   #4991
Guo Chean's Avatar
Send a message via ICQ to Guo Chean Send a message via Yahoo to Guo Chean
Hey Steve, just a quick question what is the stock timing for 13.5? i forgot to mark down before i clean and adjust my motor. thanks
[FONT=Comic Sans MS][SIZE=3][COLOR=red]|HotBodies|HPI|Full Throttle Motorsports|KO PROPO|DSM|Nosram|JACO|MUCH MORE RACING|Schacht Design Works|[/COLOR][/SIZE][/FONT]
Guo Chean is offline   Reply With Quote
Old 07-22-2007, 10:23 PM   #4992
TFR
TFR's Avatar
Steve,
Doing some bench test on my new installed, Novak GTB with 10.5SS. When I hold full throttle position for 3 sec or so, the ESC would stutter to a slower speed then goes back to full throttle again, or when I hold to around 30-40% throttle the motor would stop and red led blinks. Trouble shooting says about the sensor cable, I did shorten the cable and made sure 6 pins has contact. What else can be wrong?
Any help is appreciated...
Old 07-23-2007, 09:25 AM   #4993
The Evicerator
TFR,
There is a possibility that when you shortened your sensor wires one of your solder joint might not be very good....? Maybe you can check them....?
Also, you did lengthen then wires on the transcap... did you use larger guage wires?? You've got to go to at least 14 AWG if you're going to go longer than the stock wires.. if not maybe even 12 awg.
Hope this helps!
Steve Weiss
Old 07-23-2007, 11:06 AM   #4994
TFR
TFR's Avatar
TFR,
Hope this helps!
I was testing it with a 4 cells pack that only has about 1000Mah in it, was the pack not good enough for the red led to flash? Is there a replacement connector and pins for the sensor to purchase at Novak?
Thanks again.
Old 07-23-2007, 11:17 AM   #4995
The Evicerator
Unfortunately we do not offer a replacement harness for our motors...we do offer double-ended sensor harnesses for use with other brand's motors that have connectors on the motors... maybe you could use one of those ...?
#5355 for 9"
#5356 for 4"
It's possible that your battery pack may not have had enough power to run the system consistantly... I would definately re-test using a fully charged 6 cell pack.
Steve Weiss
STUFF FOR SALE """"LQQK """" EZRC R/C Items: For Sale/Trade 1 03-13-2007 07:20 PM
"""NEW""" Collari .21 3 port buggy motor lc21-b3 goneRVing R/C Items: For Sale/Trade 7 12-20-2006 06:25 PM
STUFF FOR SALE """"LQQK """" EZRC R/C Items: For Sale/Trade 11 10-22-2006 09:49 PM
""" XRAY FK05 """ excellent cond/super clean/stock evostyle R/C Items: For Sale/Trade 9 06-29-2006 10:04 PM
Let's send Steve Weiss (Evicerator) to Cleveland!!! TeamButter Electric On-Road 8 11-02-2004 11:32 PM
