Old 07-12-2007, 11:58 PM   #4951
The Evicerator
Originally Posted by tfrahm View Post
I originally posted this in another thread, but realized this is a better place to ask....
I've been racing my XXX-S locally with a GTB/13.5(bonded) setup. I had all the usual issues -- ran too hot until I geared down to around 6.2 FDR with rubber tires and finally got the temps down to around 150-160 (90+ F degree weather)...
SO - Tonight I replaced the rotor with a sintered rotor... (I've worked with brushed motors for 18 years or so, and I'm spoiled with having my Turbo Dyno 45 to allow me to test motors, etc.) When I first tested the converted motor (ONLY on the workbench so far) -- I thought I'd done something wrong... It sounded so SLOW compared to the way the bonded rotor sounded... Fully installed in the car, I realize it's working fine, but MAN! it sure is different! Before, the drag brakes (even manually applied brakes) were WEAK -- drag brake was almost unnoticable! NOW - ZAP! it appears to act almost like a brushed motor...
In reading about gearing recommendations, I always thought the sintered rotor versions "allowed" taller gearing -- now I am starting to think they MUST HAVE taller gearing to achieve the same speed...?
I'm guessing I will need to go from 6.2 FDR (bonded) to around 5.0 FDR (sintered) for our relatively small parking lot track with rubber tires...?
I won't get to track test until Sunday at the next HobbyTown races, so I want to make sure I'm understanding this right...?
Your thoughts?
Yeah, that gearing sounds about right.
I have heard most people seem to have success in the 4.5 to 5.0 FDR ranges with sintered rotors.
Steve Weiss
TEAM ASSOCIATED -- REEDY -- SANWA -- PROTOFORM -- 1UP Racing -- ActivRC -- P1 BRAND -- TEAM KINWALD -- TEAM STEVE INTERNATIONAL
Steve Weiss is offline   Reply With Quote
Old 07-13-2007, 12:01 AM   #4952
The Evicerator
Very nice Mr. Dawson!
As far as the sintered rotor is concerned, yes, it is a smaller diameter than the bonded rotor.
Steve Weiss
Old 07-13-2007, 08:35 AM   #4953
chris72983's Avatar
[COLOR="Magenta"][FONT="Arial"]Schumacher Mi3[/FONT][/COLOR]
[FONT="Arial"][COLOR="Lime"]Jammin X1CR[/COLOR][/FONT]
[COLOR="black"][COLOR="Red"]North Hills Hobbies (601-696-9767) Meridian, MS[/COLOR][/COLOR]
chris72983 is offline   Reply With Quote
Old 07-13-2007, 12:14 PM   #4954
GCracker's Avatar
Steve, I bit the bullet and got a #1711 and 13.5SS for BCR this weekend, whats your recommendation sir with the gearing?
GCracker is offline   Reply With Quote
Old 07-13-2007, 12:22 PM   #4955
HB Moose's Avatar
GG-- Didn't you quote Steve's answer in the question? I ran 4.97 at La Mirada last Sunday.
HB Moose is offline   Reply With Quote
Old 07-13-2007, 12:33 PM   #4956
GCracker's Avatar
Ya but that straight away will never be repeated again..........ever that was 180+ft with a huge sweeper I think that will be a little overkill for BCR
Im not sure I can gear my car low enough my smallest spur and largest pinion combo 118/42 only gets me to 5.14 FDR
Old 07-13-2007, 09:01 PM   #4957
The Evicerator
You should be ok with that 5.14 gearing...like I said it's just ballpark estimate.
Steve Weiss
Old 07-14-2007, 10:17 PM   #4958
Guo Chean's Avatar
Send a message via ICQ to Guo Chean Send a message via Yahoo to Guo Chean
Hi Steve,
here is the problem i have right now when i using Novak SS13.5 with the combination of Nosram ISTC spec(similiar to LRP TC spec) throttle profile 2-8-2-2, FDR gear is 4.56, radio brake EPA 60%, i have very good braking at the begining of race but after 3 min race or qualifying the motor seem to be having fade brake until i can feel my car totally no brake at all, and i did check the temp was around 160F and also i did put a novak 30X30mm fan to blow the motor to keep the temp down it should't happen like that! some more is new i just got it from towerhobbies. thanks
[FONT=Comic Sans MS][SIZE=3][COLOR=red]|HotBodies|HPI|Full Throttle Motorsports|KO PROPO|DSM|Nosram|JACO|MUCH MORE RACING|Schacht Design Works|[/COLOR][/SIZE][/FONT]
Guo Chean is offline   Reply With Quote
Old 07-15-2007, 01:34 AM   #4959
The Evicerator
You got the 13.5 Pro with the sintered rotor? If not you need to gear down quite a bit to keep the motor cooler
If you have the sintered rotor you might want to gear down a tooth or two just in case.
Also, how hot is your ESC getting?
I think that the punch/speed setting of 8 might be a bit much... I would tone it down to about 4 or so... that setting they are playing with causes extra current draw and that might be what is causing your brake fade.
Originally Posted by Guo Chean View Post
Hi Steve,
Steve Weiss
Old 07-15-2007, 08:29 AM   #4960
Guo Chean's Avatar
i believe i got the latest 13.5 version it come with ribbed can, orange timing ring. what temp you would sugguest to stay? the esc is about 50 to 70C before thermal shut down. i will try to tone it down and see still got any brake fade or not thanks for helping.
Old 07-17-2007, 11:28 AM   #4961
The Evicerator
I'm baaaaaaaaaaack
Steve Weiss
Old 07-17-2007, 11:56 AM   #4962
BillyCaldwell's Avatar
Trader Rating: 32 (100%+)
Send a message via AIM to BillyCaldwell
welcome back
Maclin | VP-Pro USA
BillyCaldwell is offline   Reply With Quote
Old 07-17-2007, 01:41 PM   #4963
Aid1970's Avatar
Originally Posted by Aid1970 View Post
thanks for the reply Steve
it is the new system can i adjust the trim on the stick to give me a little more like a auto brake?
thanks
glad your back Steve can you help will i do any dammage??
Aid1970 is offline   Reply With Quote
Old 07-17-2007, 02:14 PM   #4964
The Evicerator
Aid,
You can turn the throttle trim back so that you're actually sitting in the brake side ...but it will change the throttle response a bit and make it so that it's not linear... you will actually have no response through the deadband until you reach the minimum drive again.
Steve Weiss
Old 07-17-2007, 02:19 PM   #4965
EWWWWOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOPPP PPPPPPPPPP!!!!!!!!!!!!!.....DUH!
Barry Baker is offline   Reply With Quote
STUFF FOR SALE """"LQQK """" EZRC R/C Items: For Sale/Trade 1 03-13-2007 07:20 PM
"""NEW""" Collari .21 3 port buggy motor lc21-b3 goneRVing R/C Items: For Sale/Trade 7 12-20-2006 06:25 PM
STUFF FOR SALE """"LQQK """" EZRC R/C Items: For Sale/Trade 11 10-22-2006 09:49 PM
""" XRAY FK05 """ excellent cond/super clean/stock evostyle R/C Items: For Sale/Trade 9 06-29-2006 10:04 PM
Let's send Steve Weiss (Evicerator) to Cleveland!!! TeamButter Electric On-Road 8 11-02-2004 11:32 PM
