Ask Steve "The Evicerator" Weiss >
Old 07-02-2007, 03:56 PM
  #4921
The Evicerator
Very nice tie-in to the up and coming TRANSFORMERS Motion Pictutre!
Steve Weiss is offline
Old 07-02-2007, 04:18 PM
  #4922
Trader Rating: 19 (100%+)
The Shopatron is where the Autobots and the Deceptagons(sp) get their hop ups....
I can't believe I know their names.......*shakes head*........
*Decepticons*
Advil is offline
Old 07-02-2007, 04:26 PM
  #4923
The Evicerator
Actually it's "Decepticons"... a "deceptagon" would be a ... decepta-sided object ... or some sort of ancient dinosaur I've never heard of
Originally Posted by Advil View Post
The Shopatron is where the Autobots and the Deceptagons get their hop ups....
Old 07-02-2007, 05:47 PM
  #4924
F. Mendoza's Avatar
Trader Rating: 79 (100%+)
F. Mendoza is offline
Old 07-02-2007, 10:29 PM
  #4925
BillyCaldwell's Avatar
Trader Rating: 32 (100%+)
Thanks Steve, every now and then I bust out a golden nugget. Most of the time, not so much. Im gonna have to try to con a nice young lady into seeing the movie with me. I may have to trade for a couple movie draft picks of her liking and a yet to be mentioned dinner.
BillyCaldwell is offline
Old 07-03-2007, 09:19 AM
  #4926
VT,
The first place I would check would be your local hobby shop... they should be able to order one for you.
You can always check through tower hobbies or some other online shop... or you can buy through our website via the shopatron network!
Steve,
I think you nailed it. I took apart my motor last night and found out that the three main bolts that hold the motor together had loosened over time, so much so that I could actually spin the purple "velociti" sleeve. I took out the stock rotor and it was dinged up pretty good. I cleaned out all of the sand ... yes there was sand in my motor ... and re-assembled and tightened everything down. I ran it pretty hard last night w/no melted battery.
Due to the damage on my existing rotor, I have already ordered a new sintered upgrade. I will be rebuilding my existing stick packs to make them side by side. I guess after a year and a half of brushless bashing it is time for some maintenance on my car ...
Thanks again for your expert advice, it is very much appreciated.
One more thing: I was wondering is Novak working on anything to compete with the new Traxxas Velineon brushless, and the Mamba Maxx brushless. It looks like both of those are sensorless brushless and can run over 6 cells.
Thanks,
VT
vt_stone is offline
Old 07-03-2007, 09:39 AM
  #4927
The Evicerator
VT,
No problem, that's what we're here for!
And regarding your other question: We're always keeping our eye on what's going on in the industry !
Old 07-03-2007, 11:49 AM
  #4928
TFR
TFR's Avatar
Steve,
Was there ever a running change on the 3010 Novak GTB/SS10.5 Pro Brushless System combo that the lipo cut off was added in the GTB? Or is this combo always had the new GTB with lipo cut off?
Thanks,
Peter
TFR is offline
Old 07-03-2007, 11:51 AM
  #4929
The Evicerator
TFR,
The combos *should* have the GTB w/ lipo cut off in them... there should be rather prominent stickers on the box to that effect.
Originally Posted by TFR View Post
Steve,
Thanks,
Peter
Old 07-04-2007, 01:20 PM
  #4930
Default hvmaxx problem
please help! ive been refered very kindly here by ianjoiner(thanks).
today ive tried to contact novak but my mail wont go through([email protected],[email protected]).here is a copy of that mail in hope that someone may be able to help me.would be very greatful.
i really hope you can help.
i have purchased a hv-maxx setup for my hot bodies e-zilla.i
decided on this system because i am quite a novice when it comes to rc
cars but wished to improve my car.it seemed that brushless systems are
easier to maintain,so wanted to buy from a high quality maker.also
wanted to get the motor and speed controller together,so i wouldnt have
any incompatibity problems.this system seemed to be perfect for me.
i found installation tips from forums on the internet and installed
it with slight modification to the car chassis.
my e-zilla is standard apart from the batteries which are 12 sanyo
3600's.
from what i understand,the system i have purchased is the old version
you made. its got hv440 440kv 375w 0.76kt written on the side of the
motor.
now the problem i have is this:-
i have only run the system once.i turned it all on as normal and set
it up as the instrucions.selected throttle program #2. i took my car to
a large flat surface and did a few high speed passes(just slowing to
turn around and come back),each pass lasting 4-5 seconds.after about
30seconds of running, the car lost power.i checked the speed controller
the red light was on per normal,but if i pushed the controller to
accelerate the blue and green led came on. i have tried the system
since but
just get the light coming on and no movement from the motor.
please please help.i hope it is something really simple that i am
overlooking.
many thanks in advance
- help me obi-wan kenobi,you are my only hope.
twinpod is offline
Old 07-05-2007, 06:24 AM
  #4931
Aid1970's Avatar
Steve
can you help how can i get more drag brake on my 10.5 system it is on number 10 but it isnt enough for me.
cheers
Aid1970 is offline
Old 07-05-2007, 10:58 AM
  #4932
The Evicerator
Sorry about the email trouble...we're still working on getting our filters working correctly
First of all check to make sure that all of your connections are sound:
The sensor harness is plugged in all the way into the ESC and that the three main power wires are soldered correctly to the motor... make sure there aren't any stray wires/strands shorting from one terminal to another.
If all of that is in order there is a chance something might have been damaged somehow...
If you bought your system recently it should have been on of the newer systems with ribbed and bells and sintered rotors...
However, if it is an older system with the smooth endbells and the bonded rotors there's a chance that you may have a problem with the bonded rotor.
Did you use the stock gearing that comes with the truck? If so more than likely you were highly over-geared and that can cause damage to the system.
With the E zilla/E savage you're going to have to put a much smaller pinion gear on the truck to get closer to proper gearing.
If you do have the bonded rotor system I HIGHLY recommend upgrading to a sintered rotor being as that it will make your life alot easier as far as future problems are concerned!
I hope this helps!
If you have any more questions you can always try calling customer service at 949-833-8873
3600's.
motor.
since but
overlooking.
Old 07-05-2007, 10:59 AM
  #4933
The Evicerator
Aid,
Unfortunately 10 is the highest value that we have allowed for now in the GTB.
Do you have your throttle trim turned up by chance?
If you do that can reduce the amount of effective drag brake you are getting.
Also, if you have the bonded rotor in your motor an upgrade to the sintered rotor will give you much better drag brakes.
Originally Posted by Aid1970 View Post
Steve
cheers
Old 07-05-2007, 12:07 PM
  #4934
thanks steve,
yes mine is the old type hvmaxx motor.
what is the phone number from the uk please?
i think this repair is going to be expensive!! gutted cuz it cost 250 for 30seconds of run time haahaa!
so,when i get it repaired i should get a much smaller pinion?
thanks again.
twinpod is offline
Old 07-06-2007, 12:11 AM
  #4935
The Evicerator
Twin,
You should contact CML Distribution for warrantee in the UK... I don't have the # right now...
thanks steve,
thanks again.
