Old 05-21-2007, 09:37 PM   #4771
edseb's Avatar
No, the BL winds are in the can, which is kind of opposite of brushed motors. You can change the rotor and that changes the material, but the winds are in the can.
RC Car Action Editor and Photographer
Carl Hyndman
edseb is offline   Reply With Quote
Old 05-22-2007, 03:00 AM   #4772
Drewdc90's Avatar
Steve you have PM and Email regards nonworking GTB
-Xray--Nosram--Orion--Trak Power--Duratrax--Spektrum--Futaba-
Sunshine Coast QLD AUSTRALIA
"If you stand still long enough you'll go backwards"
Drewdc90 is offline   Reply With Quote
Old 05-22-2007, 01:07 PM   #4773
edseb's Avatar
Originally Posted by edseb
Little help. I've been gearing a 4300 with 6 cell at 5.3, what should it be geared at for 5 cell?
Any suggestions Steve?
Carl Hyndman
Old 05-22-2007, 01:48 PM   #4774
The Evicerator
Well, you *could* put a bonded rotor into one of those motors but I really don't recommend it...
You will get less power with the bonded rotor...but you will also be giving up efficiency, durability, and longevity of the magnet.
I recommend simply getting the right motor for your application
Carl was right that the winds in the motor are in the can and those are what make the biggest differences.
Without knowing what kind of application you are intending your motor for I cannot really recommend a motor... for instance most off-road applications only require 5.5R, 6.5R, or 7.5Rs
Carl, oh yeah, 5 cell gearing... general rule of thumb is up another 2 teeth on the pinion... but that's for the low turn mod stuff... the 10.5 might require more gear....at least that's a starting point
Originally Posted by catcars
I know alot about slotcar motors but very little about these brushless motors. One thing I noticed is just how many people are trying to sell their 3.5's/4.5's. Too much power is the common reason.
So my question is can one change the rotor or something to tone down the horsepower? Will a 10.5 rotor work in a 3.5 can?
thanks
Steve Weiss
TEAM ASSOCIATED -- REEDY -- SANWA -- PROTOFORM -- 1UP Racing -- ActivRC -- P1 BRAND -- TEAM KINWALD -- TEAM STEVE INTERNATIONAL
Steve Weiss is offline   Reply With Quote
Old 05-22-2007, 01:51 PM   #4775
Big Rigg's Avatar
carl, I've heard that with brushed motors and 5cell you should gear 5 teeth higher... for what that's worth
[url=http://www.corallyusa.com/][color=Red]- Corraly USA -[/color][/url]
[url=http://www.corallyusa.com/specializedrc/index.htm/][color=Red]- Specialized R/C -[/color][/url]
[url=http://www.thunderrc.com/eshop/][color=DarkRed]- Team Thunder RC -[/color][/url]
[url=http://www.cfxpaintworks.com/][color=DarkOrange]- CFX Paintworks -[/color][/url]
[COLOR=DarkSlateGray]- Team Ertrachter Factor - [/COLOR]
If my last name were Oxlong, I would name my kid Mike... yup Mike Oxlong
-Heywood Jablome
I don't want to pay for my sig, so yawl figure it out...
Big Rigg is offline   Reply With Quote
Old 05-22-2007, 01:53 PM   #4776
rocketron's Avatar
Trader Rating: 16 (100%+)
huummm only 5
- SchuurSpeed - 6X ROAR National Stock Champion
- Hobbywing North America Team Manager
rocketron is offline   Reply With Quote
Old 05-22-2007, 01:56 PM   #4777
Anyone can help??
With 5-cell Novak 4.5R (sintered) I drive a FDR of 6.6 at my Local Track.
Tomorrow I would like to test some runs with a 7x1 motor, any suggestions on a FDR for 5 cells??
Rob Janssen.
Rob Janssen is offline   Reply With Quote
Old 05-26-2007, 10:23 PM   #4778
The Evicerator
Oh yeah, I wanna thank Lunch Box for being an utter tool today.
Steve Weiss
Old 05-26-2007, 10:24 PM   #4779
The Evicerator
Rob,
I haven't really played with a 4.5 with 5 cells...most of the 5 cell running I have been doing is with the 3.5
for instance...at tamiya with 6 cells we would run a gear ratio of 10.1:1... with 5 cells and the same motor guys are running around 9.0:1
Most of the time on our medium sized tracks I would say we gear a 4.5 with 6 cells around 9.2 ...so with 5cells I would make a guess that I would gear around 8.3 or so...
It's hard to say what to recommend when I don't know what proper gearing for you track with 6 cells is...
I know on some large tracks I have run as low as 8.0 w/ a 4.5R... and using that as a refference I'd probably gear around 7.2 there with a 4.5
I hope this helps?
Steve Weiss
Old 05-27-2007, 05:45 AM   #4780
Trader Rating: 44 (100%+)
Default GTX question
hi Steve,
do you know why my GTX buzzes when i switch it on?
there's a high pitch buzz.
i'm trying to set it up for the very 1st time.
i notice that the sound goes away when i adjust my futaba throttle ATV (e.g. increase from 50 to 75%).
i thought ATV is used mainly for adjusting throttle servo end-points.
i know with my GP cars, if i reduce the ATV, then i reduce or eliminate buzzing completely, from the digital servo.
but in this case, it seems to be the opposite, i need to increase the end-point to reduce the sound
thanks in advance.
YOKObori MOkei
wyl03 is offline   Reply With Quote
Old 05-28-2007, 12:52 AM   #4781
The Evicerator
wyl,
You need to set your endpoints to their maximum points before you do the one touch setup.
This allows the ESC to be as smooth as possible!
Steve Weiss
Old 05-29-2007, 11:41 PM   #4782
Default Lost property...
Holy Cow!
The "Fearless-Leader's" thread on page four....hope he doesn't find out!
Graphitedust is offline   Reply With Quote
Old 05-30-2007, 08:58 AM   #4783
The Evicerator
I think everyone is catching up on lost sleep from the race
I'm sure things will be back to normal around here soon enough
Steve Weiss
Old 05-30-2007, 04:39 PM   #4784
Originally Posted by Steve Weiss
wyl,
tried it.
works a treat .. thks.
YOKObori MOkei
Old 05-30-2007, 04:53 PM   #4785
HB Moose's Avatar
e/ Raises Hand
Why is this thread called "Ask Steve 'The Evicerator' Weiss"? Mr. Weiss is currently being called Scuba Steve. Shouldn't it be "Ask 'Scuba' Steve Weiss"?
At least we need some un-informed guesses where these nicknames came from. The stranger the better
Bruce "Moose" Riedinger
HB Moose is offline   Reply With Quote
STUFF FOR SALE """"LQQK """" EZRC R/C Items: For Sale/Trade 1 03-13-2007 07:20 PM
"""NEW""" Collari .21 3 port buggy motor lc21-b3 goneRVing R/C Items: For Sale/Trade 7 12-20-2006 06:25 PM
STUFF FOR SALE """"LQQK """" EZRC R/C Items: For Sale/Trade 11 10-22-2006 09:49 PM
""" XRAY FK05 """ excellent cond/super clean/stock evostyle R/C Items: For Sale/Trade 9 06-29-2006 10:04 PM
Let's send Steve Weiss (Evicerator) to Cleveland!!! TeamButter Electric On-Road 8 11-02-2004 11:32 PM
