Ask Steve "The Evicerator" Weiss
#4741
Steve,
I didn't change the wires I just got the colors wrong. I guess what I'm trying to ask is if you can say solder A and B to one side of the motors Negative tab and solder C to the other side of the motors Negative tab. Or, do all 3 (A,B,C) need to be soldered to the same negative tab? Just trying to make the soldering of all 3 wires a little easier! There's not alot of room on one tab for all three wires.
Thanks....Greg
Thanks....Greg
#4743
The Evicerator
Greg,
Your method will work as well as Scottrik's!
#4745
How's the X-Ray working out for you Steve?
#4746
Steve...Can you tell Schumacher to hurry up with the Mi3
See ya in a few weeks....YEAH 5 cell brushless!
#4747
The Evicerator
Capelracer: It is done just as a precaution in case the setup is not done properly.
Donny: I'm liking it alot! I still have some stuff I want to figure out on it...but by and large I am very happy with it
PW: Sure thing! "HEY SCHUMACHER, HURRY UP WITH THOSE MI3'S! AND SEND ME MY TIRES DAMNIT!"
#4749
The Evicerator
Thanks Patrick!
Now if only I had some tires to put on this beast it might be worth something!
*grumble grumble grumble*
#4750
Steve, I have the Brushless system and want to put it in to my B4, however it wont fit due to cooling system, does novak offer a smaller solution to accommodate low profile bodies?
thanks
Tom
thanks
Tom
#4751
The Evicerator
Hey Tom,
There are a few things you can do to get it to run ok under your low profile B4 body.
The recommended method is to remove the fan from teh top of the ESC and mount it sideways next to the ESC so that it is still blowing air across the ESC.
Some people cut openings above the ESC to allow the fan to stick through the top but I'm not sure you like the idea of cutting up your body.
#4752
The Evicerator
whoa!
#4753
The Evicerator
DDP!
Wow...page 4?
I just wanted to let you guys know brian showed me some stuff he started getting together and wanted to share it with you all!
http://www.xfactoryrc.com/storeDDP.htm
He's got these cool scew kits coming out and I think he has plans on doing more screw kits for various different cars!
Check it out!
Check it out!
