Old 01-19-2006, 02:31 PM   #2746
Jon Kerr's Avatar
Trader Rating: 17 (100%+)
We're all gonna get fired for not getting anything done now. Thanks Steve!
Jon Kerr is offline   Reply With Quote
Old 01-19-2006, 04:30 PM   #2747
Scottrik's Avatar
Trader Rating: 245 (100%+)
OK--BACK TO WORK!!
I've got a Novak question for the Great One...
Soldered up a couple brand new IB3800 packs, my first 6-cell 3800's. They've been charged, one of them was used one run and re-charged. When I insert them in my Smart Trays (either one) the lights all come on when I push the button to start but all six lights go out immediately when I release the button. This does not happen with IB3800 4-cell packs or any of my other 4- or 6-cell packs.
They DO discharge on my Brand-X discharger/conditioner.
Stumped,
Scottrik
Scottrik is offline   Reply With Quote
Old 01-19-2006, 05:11 PM   #2748
The Evicerator
Make sure that you have the polarity of your pack correct. The Positive solder tab should be at the bottom right and the negative solder tab should be at the bottom left... if you not there are little pictures of battery bars on the smart tray as well... line those up with the battery bars on your pack and you should be fine!
Steve Weiss
TEAM ASSOCIATED -- REEDY -- SANWA -- PROTOFORM -- 1UP Racing -- ActivRC -- P1 BRAND -- TEAM KINWALD -- TEAM STEVE INTERNATIONAL
Steve Weiss is offline   Reply With Quote
Old 01-19-2006, 05:22 PM   #2749
Scottrik's Avatar
I was going to make a smart-assed comment about having used these bad boys for a year and a half on a couple dozen different packs...
...then I looked at the battery packs and see the soldering tabs run off the "wrong" side of the batteries. Both of 'em. At least I'm CONSISTENTLY incompetent.
Thanks Steve!
Scottrik
Old 01-19-2006, 05:25 PM   #2750
Andrew Swanson's Avatar
Send a message via AIM to Andrew Swanson Send a message via Yahoo to Andrew Swanson
3rd try 45 sec ill try more later too busy raiding :0
Andrew Swanson is offline   Reply With Quote
Old 01-19-2006, 10:10 PM   #2751
The Evicerator
raid raid raid!
Steve Weiss
Old 01-19-2006, 10:45 PM   #2752
DirtyDog3375's Avatar
Trader Rating: 37 (100%+)
Send a message via MSN to DirtyDog3375
Originally Posted by Evicerator
OMG!!!! Steve!!! what are you doing supplying these types of links for us. It is soooooo additcitive!!!!
Can't seem to get above 24 secs.
How on earth did you find it (it's off an Australian net provider)????
Do you have a little too much time on your hands, now that you don't have a ride yet???
:::Smokem Racing:::RCMaker.com.au:::Speedy RC.com.au:::
"It's more fun to drive slow cars fast, than fast cars slow"...
DirtyDog3375 is offline   Reply With Quote
Old 01-20-2006, 08:55 AM   #2753
Mr. Shookie's Avatar
R/C Tech Charter Subscriber
Send a message via AIM to Mr. Shookie Send a message via MSN to Mr. Shookie
FEEEEEEEEEEEEW,
nearly page two....
-Shookie <><
All who love the LORD JESUS I praise with you.1 Cor 10:31
Team HOLY Rollers (Team Manager)
The Church is a Hospital for Sinners not a Museum for Saints.
RcTech Feedback <>< RC Tech Subcriber #92
Mr. Shookie is offline   Reply With Quote
Old 01-20-2006, 09:50 AM   #2754
imjonah's Avatar
Default Problems-XXX-S One Way
Last year I bought two one ways on E-bay from different people.
I am confident I did not install them backwards. I burned out both of them after about 15 minutes or less track time. When I removed them from the car little rollers from the bearings fell out.
1. Do you know where I could buy just the one-way bearing itself to put in the outdrives?
2. Someone mentioned to me something about you having to make some small modification of the main chassis of the XXX-S for the one way assembly to mount correctly, this did not make much sence to me.
3. Is there something I am doing wrong or do you have any tech info about setting up a one way, that might prevent this from happening.
4. I am not a very experienced driver(I know they say one-ways are hard to drive) but the little bit of track time I had running the one way, I liked the way the car handled. I have a tendancy to enter the corner a little to fast and the extra off power steering would help I think.
5.One thing that is important to me is reliability if the one way is inherently unreliable than I will forget about it and go back to a diff.
Thanks in Advance.
imjonah is offline   Reply With Quote
Old 01-20-2006, 10:02 AM   #2755
AdrianM's Avatar
Almost everyone has abandoned one ways in favor of spools. The only time one-ways are still in use occasionally are when you run carpet with rubber tires and even then spools are usually faster.
Adrian Martinez
Old 01-20-2006, 10:24 AM   #2756
Maybe in the US, but we still use one-way with rubber on carpet most of the time in europe. Marc R won the recent DHI cup & carpet world cup with one-way. Also Hara won JMRCA last year with one-way.
caveman is offline   Reply With Quote
Old 01-20-2006, 01:27 PM   #2757
Scottrik's Avatar
As I was starting out racing TC's I bought two different TC-3 packages (a BMI chassis and a Warpspeed Demon chassis) from two different racers who were both relatively experienced. They both had one-way front diffs and BOTH made the same error. They both had the "normal" outdrive bearings (as one would find in the kit for the diffs) that had been pressed onto the one-ways where the correct bearing is a close fit but goes on by hand. The "normal" bearings have the usual chromed outer race surface while the HD one-way bearings have a brushed or matte silver outer race surface. The one-way's come with the correct carrier bearings, but replacement bearing kits, etc do not. The only source I could find for the correct bearings is Associated.
The long and short of it is that the one-way bearings failed VERY quickly--one lasted a few races, the other just a few heats. I'm guessing these "normal" bearings were pressed onto the on-way body (probably with a vise) and there was enough interference that it compressed the body onto the bearing creating too tight of a fit. Since this problem has been identified and corrected I've not had a problem in over a year of active racing.
I'm not aware of anyplace you could buy just the appropriate one-way bearing. Be aware that this would require a fairly specialized puller to get the old bearing out and a press to properly install and seat the new bearing. If you DO find a source please shout out. I'd buy a couple just for the hell of trying it as I have two ruined one-ways sitting on my desk.
Scottrik
Thanks in Advance.
Old 01-20-2006, 02:00 PM   #2758
Josh Numan's Avatar
Spools??? Wow.......
Josh Numan is offline   Reply With Quote
Old 01-20-2006, 03:53 PM   #2759
LawL
Old 01-20-2006, 05:57 PM   #2760
Trader Rating: 62 (100%+)
There are two great tips on '4wdrc.com' on how to prevent your xxx-s one-ways from blowing up.
TEKNO RC * TLR * EXOTEK
patrick is offline   Reply With Quote
STUFF FOR SALE """"LQQK """" EZRC R/C Items: For Sale/Trade 1 03-13-2007 07:20 PM
"""NEW""" Collari .21 3 port buggy motor lc21-b3 goneRVing R/C Items: For Sale/Trade 7 12-20-2006 06:25 PM
STUFF FOR SALE """"LQQK """" EZRC R/C Items: For Sale/Trade 11 10-22-2006 09:49 PM
""" XRAY FK05 """ excellent cond/super clean/stock evostyle R/C Items: For Sale/Trade 9 06-29-2006 10:04 PM
Let's send Steve Weiss (Evicerator) to Cleveland!!! TeamButter Electric On-Road 8 11-02-2004 11:32 PM
