Ask Steve "The Evicerator" Weiss >
Old 11-30-2005, 05:10 PM
  #2221
Jon Kerr's Avatar
Trader Rating: 17 (100%+)
Are you using the flatline trays for modified packs? GP or IB cells?
Jon Kerr is offline
Old 11-30-2005, 05:12 PM
  #2222
The Evicerator
Just the Smart Tray... to 0.9V per cell...either type of battery.
Steve Weiss is offline
Old 11-30-2005, 05:13 PM
  #2223
do they make a dumb tray along with the smart tray?
Barry Baker is offline
Old 11-30-2005, 05:17 PM
  #2224
Jon Kerr's Avatar
Jon Kerr is offline
Old 11-30-2005, 05:21 PM
  #2225
STLNLST's Avatar
Trader Rating: 29 (100%+)
WHAT UP FOOL? YOU STILL COMING DOWN HERE FOR THE NORTHWEST CARPET CHAMPS?
STLNLST is offline
Old 11-30-2005, 05:29 PM
  #2226
be there next wed. fooooooooooooooooooooooooooooooo
Old 12-01-2005, 07:51 AM
  #2227
STLNLST's Avatar
Cool!!!
STLNLST is offline
Old 12-01-2005, 01:38 PM
  #2228
The Evicerator
Old 12-01-2005, 01:46 PM
  #2229
AdrianM's Avatar
Originally Posted by STLNLST
Cool!!!
That should be, "Cooooooooooooooooooooooooooooooooooooooooooooooo. .."
AdrianM is offline
Old 12-01-2005, 02:42 PM
  #2230
STLNLST's Avatar
shhhhhhhhhhiiiiiiiiiiiiiiiii
STLNLST is offline
Old 12-01-2005, 04:14 PM
  #2231
R/C Tech Elite Member
Randy Caster's Avatar
Trader Rating: 47 (100%+)
WWWWWWWWWWHHHHHHHHHHHHHAAAAAAAAAAAAAAAAAATTTTTTTTT TTTTTTTTTSSSSSSSSSSSSSSSSSSS UUUUUUUUUUUUUUUUUPPPPPPPPPPPPPPPPPP SSSSSSSSSSSSSSSSSTTTTTTTTTTTTTTTTTTTEEEEEEEEEEEEEE EEEEEEVVVVVVVVVVVVVVVVVVVVVEEEEEEEEEEEEEEEEEEEE??? ?????????????????????
HHHHHHHHHHHHHHHHHHHHHOOOOOOOOOOOOOOOOOOOWWWWWWWWWW WWWWWWWW IIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIISSSSSSSSSSSSSSSSS SSSSSS YYYYYYYYYYYYYYYYYYYYYYYYOOOOOOOOOOOOOOOOOOOOOOOOUU UUUUUUUUUUUUUUUUUUUUUUUUURRRRRRRRRRRRRRRRRRRRRRR DDDDDDDDDDDDDDDDDDDDDDDDAAAAAAAAAAAAAAAAAAAAAAYYYY YYYYYYYYYYYYYYYY GGGGGGGGGGGGGGGGGGGGGGGOOOOOOOOOOOOOOOOOOOOOOIIIII IIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIINNNNNNNNNNNNNNN NNNNNNNGGGGGGGGGGGGGGGGGGGGGGGG BBBBBBBBBBBBBBBBBBBBBBBBUUUUUUUUUUUUUUUUUUUUUUUDDD DDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDD DDYYYYYYYYYYYYYYYYYYYYYYYY???????????????????????? ?????????
Randy Caster is offline
Old 12-01-2005, 05:01 PM
  #2232
PaZ
PaZ's Avatar
this has got to stop ladies sumone always has to take it just tttttttttttttttooooooooooooooooooooooooooooooooooo oooo ffffffffffffffffffaaaaaaaaaaaaaaaaaaaarrrrrrrrrrrr rrrrrrrrrrrrrrrrrrrrrrrrrrr
PaZ is offline
Old 12-01-2005, 10:17 PM
  #2233
I think it's the other way around...I wonder if I could make a southpark Fred Flinstone
DIRT is offline
Old 12-01-2005, 11:51 PM
  #2234
Hi Dirt, Here's a question for the bored:
What causes a car (sedan) to over-rotate in the last third of a turn. That is, the car turns in well in the first third, corners OK through the second (doesn't really carve well around the corner, just sorta on the edge), then over-rotates in the last third. It begins to oversteer unless you really let up on the throttle when you ought to be mashing it. Read into it: kills corner exit speed.
I suspect that its a poor balance between front and rear, but I'm not sure what to go after to correct it.
Is this a function of springs, oil, droop, ride height or what? Is too much weight being transfered forward and not enough weight remaining rearward? You thoughts?
By the way, you other guys can comment too ya know..... LC
Graphitedust is offline
Old 12-02-2005, 01:16 AM
  #2235
Hmm...could be a number of things..if the rear is to soft it could be bottoming out either on the track or on the stops,,the rear diff could be to loose..
and it diffs out...to much weight in the rear..shocks need more progression...
Things to try,,raise rear ride height,,more rear camber change,,lean shocks in,,thicker rear oil...Start there...let me know what happens..L8
DIRT is offline
