Traction compound techniques >
Old 05-04-2011, 11:33 PM
  #16
Originally Posted by Fastfreddy74 View Post
http://www.simplegreen.com/about_us_global_partners.php
Select your country in the dropdown menu
thank you , turns out there is a shop in my local city who sell's it
sidecarphil1 is offline
Old 05-04-2011, 11:51 PM
  #17
andrewdoherty's Avatar
Trader Rating: 47 (100%+)
I have found that cleaning my tires with the tire sauce I am using has improved traction. I only use motor spray or similar solvents when I am trying to reduce grip.
andrewdoherty is offline
Old 05-04-2011, 11:55 PM
  #18
CraigM's Avatar
Trader Rating: 34 (100%+)
Lately I've had good results by cleaning the tyres with a small amount of whatever additive I'm about to apply. Then when the time comes I cook for 20 mins at 60 deg before I go out.
CraigM is offline
Old 05-05-2011, 12:53 AM
  #19
Pro10noob's Avatar
I use Motip brake cleaner after every run.
Used other brands but had some bad experience with them.
Let them dry and the apply LRP tire sauce.
Put i little piece of cloth on it and warm them up to 60.
This i do for every run.
When storing the tires, i clean them with brake cleaner again and then put on tire sauce and wrap them in householdfoil.
This stays on until i go racing again.
It keeps the tires fresh even after a long period of not using them.
regards Roy
Pro10noob is offline
Old 05-05-2011, 10:45 AM
  #20
So which of the simple green products is preferred?
John Pape is offline
Old 05-05-2011, 10:47 AM
  #21
MikeXray's Avatar
Trader Rating: 73 (100%+)
regards Roy
I'm curious to what ingredient the brake cleaners you are using have, there must be one that prevents the tires from drying out.
MikeXray is offline
Old 05-05-2011, 11:01 AM
  #22
Pro10noob's Avatar
Don't know what is in it
I know it works
That is enough for me
Check link http://www.motip.com/?page=23&id=745
Perhaps you can find something interesting on the data sheets.
I use it for almost everything i have to degrease or clean.
Like bearings,inlet manifolds,carburators and so on.
It isn't agressive for rubber, otherwise it would damage your dustcaps on the brake calipers or brake cilinders and that is what it is used for in the first place.
regards Roy
Old 05-05-2011, 11:08 AM
  #23
i havemoved from Motip brake cleaner as it is greasy , now use Landrover bake cleaner , it is made by Loctite and it is great , doesnt leave the tyres greasy
Old 05-05-2011, 11:24 AM
  #24
Pro10noob's Avatar
Hey Phil,
Check the data sheet..
It won't leave any residu so no grease or anything.
Never had that here that the tires where left greasy after using Motip.
I also use the break cleaner from CRC and that one has a strange smell on it like a strong cleaning fluid.
If you use the CRC your tires have a light white coat on it.
regards Roy
Old 05-05-2011, 11:44 AM
  #25
Hey Phil,
regards Roy
I will let you try the Landrover stuff, Vasco was using it on sunday on Ronald Bestmans car it was so good ;-)
this IS the best cleaner i have used and i clean a lot of brakes LOL
Old 05-05-2011, 01:21 PM
  #26
The only brake cleaner product I can find from Loctite is this one.
http://65.213.72.112/tds5/docs/7235-EN.PDF
I wonder if it is the same thing.
SeanV is offline
Old 05-05-2011, 01:29 PM
  #27
he landrover part number is STC50544
if this helps ?
Old 05-05-2011, 02:18 PM
  #28
StarrRacing's Avatar
Where do you get the Landrover Brake Cleaner?
I called my local dealer, and "they" don't even use it..??
Do you order it off the internet?
StarrRacing is offline
Old 05-05-2011, 11:27 PM
  #29
I work at Landrover , so we have it for the guarantee claims , we can only claim for genuine parts on guarantee so we have it but never use it
If you ask them to order it then they can get it BUT it comes in boxes of 12 and they are quite expesnsive
Old 05-06-2011, 12:29 AM
  #30
Anyone used lighter fuild to clean there tires . Is seems to make the
Tires sticky ...
mwoods is offline
