cycling batteries ? >
cycling batteries ?
cycling batteries ?
Old 09-22-2004, 10:56 AM
Default cycling batteries ?
When I cycle I use no repeaks in my settings, a charge and then a 14sec. delay and into discharge. By doing this are my numbers better or worse than what the pack is? thanks
impdog is offline
Old 09-22-2004, 06:41 PM
anyone got a answer?
impdog is offline
Old 09-22-2004, 06:59 PM
JDXray's Avatar
I am alittle confused. When i cycle, it charges once and then has a 180sec cool down time and then discharges. 14secs seems kinda fast. Your cells probably be very hot.
Jon
JDXray is offline
Old 09-22-2004, 07:02 PM
danjoy25's Avatar
Trader Rating: 38 (100%+)
Default Re: cycling batteries ?
Need more info:
What amps do you discharged at?
14 sec delay seems to short, are the pack hot just before the discharging starts. Numbers might be worse by using only 14 sec delay as packs will be very hot. It will also depend on the amps you disharge. 30 amps is the industry standand.
danjoy25 is offline
Old 09-22-2004, 07:07 PM
Iam discharging @ 27amps ,charge at 6 with 03 peak det. bats are about 125 130 degress before they go into discharge cycle..
impdog is offline
Old 09-22-2004, 07:09 PM
JDXray's Avatar
well can you charge at 30? and try .04 cutoff at 6 amps.
JDXray is offline
Old 09-22-2004, 07:14 PM
danjoy25's Avatar
Do you have matched packs? What charger are you using?
danjoy25 is offline
Old 09-22-2004, 07:20 PM
Iam cycling with a turbo 35 and yes we race with matched packs
impdog is offline
Old 09-22-2004, 07:40 PM
danjoy25's Avatar
Thumbs up
You should check the matchers website and find out the steps they use to get the numbers.
danjoy25 is offline
Old 09-22-2004, 07:59 PM
imprsme's Avatar
Trader Rating: 89 (100%+)
One thing to remember is...
As a pack your numbers will not be what they were as individual cells. IR will be slightly higher because of the battery bars. runtime will be slightly lower also.
imprsme is offline
Old 09-22-2004, 08:11 PM
Iam not overly unhappy at all with the numbers I have gotten over the years I was wondering if they were inflated or not? almost all packs fall short of there printed lables somewhat...????
impdog is offline
Old 09-22-2004, 08:21 PM
crimson eagle's Avatar
This is a way bigger subject than can be questioned and answered with two lines.
First I would suggest you ask yourself what you are trying to achieve here. Without knowing this the asking "what is the best way" cannot be very well answered. I guess that you are trying to establish which cells are the best or monitoring cell performance over time.
Knowing this will give you a better basis to frame an answer.
My answer bearing all this in mind is that it doesn't matter too much (within limits) how you do discharge your cells as long as you do it the same way every time. Now it may be beneficial to do it the same as many others do it so you have a frame of reference and comparison.
I like to duplicate the matchers cycling methods as much as possible, this way I can compare my cells with the numbers on each cell.
Chris.
crimson eagle is offline
