Old 07-25-2011, 12:25 PM   #31
R Dodge's Avatar
Exactly as promised, dialed!
★RCAmerica •Xray •Hudy •Motiv •PROTOform •Gravity •Avid •TQ Wire •Sanwa •BSR •ProLevelRC •2mmDesigns •Timmy •5Nines★
R Dodge is offline   Reply With Quote
Old 07-27-2011, 09:02 PM   #32
Guys,
I have the first version of the Xray XII not the "link" version. Can I install this conversion kit on the older version, too?
thanks for info.
tomekz is offline   Reply With Quote
Old 07-27-2011, 09:39 PM   #33
OVA
OVA's Avatar
Trader Rating: 79 (100%+)
Originally Posted by tomekz View Post
Guys,
thanks for info.
yes I think so..only thing you needs is the front end and rear pod plates assy and side link as far I can see...
OVA is offline   Reply With Quote
Old 07-28-2011, 12:21 AM   #34
This is what you'll need for a t bar version of the car. Just went through and knowing what you need from an xray 12 link car and what the t bar exploded veiw does not have, I put together the list. I didn't bother with hardware.
XRA373090 pivot socket
XRA371190 side links
XRA303241 pivot balls
XRA376360 Standoffs
XRA373590 plastic spacer
XRA376350 Graphite antenna holder (or not if you don't intend to use normal battery position)
JoelV is offline   Reply With Quote
Old 07-28-2011, 06:10 AM   #35
So, I need these parts to fully complete the conversion together with the SpeedMerchant kit?
Is this all or will I need something else?
Thanks,
XRA376360 Standoffs
Old 07-28-2011, 07:28 AM   #36
jmellipse's Avatar
No, that list is what you need if you have a Xray T-bar car !
You don't need anything when you have a Xray Link car.
How are the rear axles from Xray holding up these days ?
jmellipse is offline   Reply With Quote
Old 08-03-2011, 02:01 PM   #37
theisgroup's Avatar
hey guys, check out the speedmerchant thread. it looks like the xray conversion did well this past weekend at the ROAR NATs
http://www.teamspeedmerchant.com/news.html
yang lai
Team Tamale | Team Tekin | RCAmerica | Speedmerchant | Speedzone RC | EA Motorsports | Ko Propo USA | eXpress Motorsports | Parma/PSE
theisgroup is offline   Reply With Quote
Old 08-03-2011, 04:02 PM   #38
BBSpence's Avatar
Trader Rating: 46 (100%+)
I have to say, the car ran great. I built the car at the track on Thursday and was able to get 2 practice runs on it. I tried to make changes with every run, and the car got better every time. Can't wait to run it on carpet. Thanks again Bruce, see you in Vegas!
BBSpence is offline   Reply With Quote
Old 08-05-2011, 08:16 AM   #39
Just got the conversion set. Whar would be a good start-setup. Sidesprings, sidedampertubes, centerdamper etc.
My current Xray set-up, so what need to be changed with the SM conversion:
DbPink front
Pink rears
Active caster 7,5 degrees
Total caster 3,0 degree
Standard hight steeringblock
Composite pivot ball's in the steering block with 10.000
Gold Xray front spring (soft, c=3,5)
No shims on top of and beneath steedringblock
No bracebar
Centerdamper with 600 and black spring, std. piston and std. mounted
Drop rearpod 1 mm (0 mm when loaded)
350 in sidedamper
0.022 (hard) SM springs
Front width +0.5 mm each side
Rear 171 mm
4,5T motor and Nosram Pearl Evo v2 speed control
Technical track with 1 highsppedcorner, long straight, 6 tight corners and 3 mediumspeed corners. Medium grip.
Kind regards; Jens
Last edited by jensroland; 08-05-2011 at 08:18 AM. Reason: missed some information
jensroland is offline   Reply With Quote
Old 08-05-2011, 09:24 AM   #40
OVA
OVA's Avatar
DbPink front
Pink rears
No bracebar
350 in sidedamper
Rear 171 mm
Kind regards; Jens
It's your lipo batt. is in the middle or off set c/t center from the mono shock or in the rear? Thanks
Old 08-05-2011, 10:50 AM   #41
On my Xray chassic I have Ran the Lipo 3,7 V (Nosram) in "normal" position - acros in the rear in the "front" position.
I intend in my new SM conversion chassis to ran it in-line in left side 8servi is mounted to the right).
By the way, the track is an indoor carpet track (as described above) ... about 105 m long ... eguilant about 320 feet
Kind regards; Jens
Old 08-05-2011, 02:18 PM   #42
Default Track
Hey Jens
Picture of track in Brøndby , lap time around 10 sek
Johnsen
johnsen-dk is offline   Reply With Quote
Old 08-05-2011, 05:12 PM   #43
nashrcracer's Avatar
R/C Tech Charter Subscriber
Originally Posted by wingracer View Post
Looks sweet. If I had an Xray, I would get one.
How about one for a CRC
hmmmm heard that is in the works.....
RC50 As you come into this world, something else is also born. You begin your life, and it begins a journey towards you. It moves slowly, but it never stops. Wherever you go, whatever path you take, it will follow — never faster, never slower, always coming. You will run, it will walk. You will rest, it will not. One day, you will linger in the same place too long — you will sit too still, or sleep too deep. And when, too late, you rise to go, you will notice a second shadow next to yours. Your life will then be over.
nashrcracer is offline   Reply With Quote
Old 08-05-2011, 10:58 PM   #44
http://www.teamspeedmerchant.com/sho...l/smr6010.html
WGT conversion now available as well.
Old 08-06-2011, 01:14 AM   #45
Thanks for the picture of the track Johnsen. See you there soon
Jens
