Old 05-02-2011, 11:48 AM   #1
ground-round's Avatar
Trader Rating: 18 (100%+)
Default Set Up changes using front gear diff vs. spool
Running an Xray T3 on carpet - I jumped on the bandwagon and bought a gear diff for my car to replace the spool. Question - what changes (if any) have you Xray guys had to make to your setups to accommodate what I'm assuming will be massive more turn-in that the diff is going to give you? Any advice would be appreciated.
ground-round is offline   Reply With Quote
Old 05-03-2011, 03:44 AM   #2
Robert_K's Avatar
I've changed from spool to geardiff with 200.000 in it, And noticed a slight difference in onthrottle corner exit. The car has a bit more steering and feels less stable. Also the brake is a little less "hard". But overall you have a bit more cornerspeed, and you're front axles wont wear as hard, as with an spool.
Hope this helps
Regards Robert
Sponsored by: Schumacher Racing and Dualsky
Supported by: Shepherd Benelux and Thunder Tiger.
Robert_K is offline   Reply With Quote
Old 05-03-2011, 03:16 PM   #3
So are you changing your setup to adapt to the unstable feeling or are you altering your driving to compensate? One thing I like about my X ray is the fact that I can drive it pretty hard into a corner and still have all four wheels underneath me. Does the front diff take this feeling away? I suppose track time will tell, but just curious as to what I can expect next week at my club race.
Old 05-03-2011, 07:58 PM   #4
Chubba's Avatar
hi there, I have changed the rear ball diff to the spec r gear diff and the front has the original compsite solid axle. If I was to change the front to the orginal ball diff which i have spare what would be the difference? thanks
[Mugen MRX 5] [Yokomo R12] [Xray T3 2011] [Xray X10 Link] [KM HK-1]
Chubba is offline   Reply With Quote
Old 05-04-2011, 12:08 AM   #5
I think with the front gear diff the touring (I am driving a TC6 now) feel more like a 1/12. Lot of front end grip on mid corner-exit. Run a little thicker oil (running 500k now) will take a little bit of that "unstable" feel out.
http://www.gpm-parts.com
gpm-parts.com is offline   Reply With Quote
One Way vs Diff vs Solid ?? bboy Nitro On-Road 10 09-06-2008 06:59 PM
