Old 11-02-2011, 03:52 AM   #31
Suspended
Thumbs up
I also forgot :
#20: run less steering expo (-40% to -10%)...
bertrandsv87 is offline   Reply With Quote
Old 11-02-2011, 11:53 AM   #32
C&B RC's Avatar
"Playing the devil's advicate"
So does the opposite hold true then?
To increase traction, do the opposite of the list?
The hardest thing to tuning is diagnosing the problem correctly at least for me.
It's all fun & games til the flying monkeys show up!
C&B RC is offline   Reply With Quote
Old 11-02-2011, 03:54 PM   #33
Suspended
I would say that in some cases, but not all...
Old 11-03-2011, 05:32 AM   #34
For the life of me I don't understand how you get grip roll in a TC. What are your camber settings, toe out/in settings, ride height and front castor blocks?
scoop is offline   Reply With Quote
Old 11-03-2011, 06:09 AM   #35
cwoods34's Avatar
On a high bite track it's fairly easy...... It deals more with droop and roll center than anything.
Stop holding bitterness deep in your bum soul.
cwoods34 is offline   Reply With Quote
Old 11-03-2011, 06:58 AM   #36
poochy's Avatar
Originally Posted by [email protected] View Post
I mean I have told a description when it is happening only. Its not sudden. It happens just before apex and mostly it happens with initial little bump on front right tire at right handed turn. (By little bump I mean taking it across 3-5mm curb)
Iam using old blue Xray springs which are one level stiffer than white which were used by most racers.
My friend was having the same issue as me and he is using front sway bar.
My tires walls were not completely glued to disc so maybe that was the biggest problem.
if its front tire traction corner entry before apex then maybe try thicker front oil also
poochy is offline   Reply With Quote
