Need advice on lathe
I am lookin to buy a lathe. Can I get one that will work on both stock and mod motors?
Also, can I run one off of a 7.2v 1800 Ni-CD stick pack? What one would you guys recommend? Thanx, I appreciate the help. And I dont mind spending the cash on getting a good one. |
Hudy makes a great unit, pick up the set up station while your there :lol:
http://www.hudy.net/flash_stuff/all_in/index.htm |
When it says for mod motors only, does that mean only 10 turn mod motors, or will it work on my 27 and 19 turn motors?
Thanx. |
A mod lathe will cut any arm out of a can. They make a stock can holder that cuts a non rebuildable stock motor.
the Hudy "Advanced" is a great lathe.
Thanx guys, I appreciate the help. I am gonna call my LHS and place an order.
as far as batteries..........a decent 4 cell pack will run the lathe at the right speed. Any more cells and it tends to turn the motor toooo fast.
Get some old motors and start practicing. |
i ahve an xipp and im very happy with it...dont really know how much the hudy is and they also make a great product...just get a diamond bit...makes all the difference...and if you have a comp. electronics charger or an lrp pulsar comp, i kow they can power any lathe.
I just got an Integy Auto-lathe and I have to say it's awesome!!
Carbide V-blocks w/ oil reservoirs, carbide bit, drive o-rings, metal shims, adjustable feed speed, sturdy METAL carrying case AND FULLY AUTOMATIC, ALL FOR $153.00!!- what more can you ask for? Check it out on www.integy.com - jaYBee |
